Anybody else seeing a SEGV on 0.51.1?
My HASS died last night:
Aug 14 00:00:33 Pegasus hass[983]: INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=sensor.dark_
Aug 14 00:00:36 Pegasus hass[983]: INFO:homeassistant.components.http:Serving /api/camera_proxy/camera.living_room to 1
Aug 14 00:00:42 Pegasus hass[983]: INFO:homeassistant.components.http:Serving /api/camera_proxy/camera.living_room to 1
Aug 14 00:00:43 Pegasus systemd[1]: [email protected]: Main process exited, code=dumped, status=11/SEGV
Aug 14 00:00:43 Pegasus systemd[1]: [email protected]: Unit entered failed state.
Aug 14 00:00:43 Pegasus systemd[1]: [email protected]: Failed with result 'core-dump'.
I don’t see an issue for this or any other reports here or in Discord so I’m hoping it was just a glitch. I updated to 0.51.2 and I’m monitoring.
I would suspect you may have file system corruption.
I have seen this as well on both versions - as I run on a Nuc I doubt its related to anything pointing to corrupted sd cards …
Yeah, I run on a Beebox which is a lot like a nuc, , I have an SSD. I haven’t seen this since though so fingers crossed …
