Spent the last four hours on this. I’m now stuck at an error that says
“AttributeError: module ‘esphome.components.display’ has no attribute ‘DisplayBufferRef’. Did you mean: ‘DisplayBuffer’?”
And want to pull my hair out.
No yaml, no logs, unable to help.
But does this help? ESP32 Water Leak Detector (with notification) — ESPHome
This is exactly the code I’ve tried to use. It doesn’t work. It appears an ESPhome update might have broken it.
Still no logs
I had a similar issue, turns out I had the old display driver in /config/esphome/custom_components
and it’s not compatible with new esphome.
