Anybody using the new OpenIPC based RunCam FPV as an IP Camera?
I am considering buying one of those new OpenIPV base RunCam FPV camera (RunCam WiFiLink(Based on OpenIPC) - RunCam Store) as it is actually designed to run OpenIPV and why not supporting the initiative.
I plan to use it as an IP camera with Home Assistant, not as an FPV camera.
but I still have doubts about two things:
  • I would rather buy the model without wifi module (WiFiLink-Cam-Y) as I will connect it with Ethernet and the wifi model with the fan take most of the space. But since there is not much doc I am not 100% sure I can get the video feed through Ethernet (might be just for debugging…)
  • How will it performs with night vision? from what I understand the IMX415 is pretty good at it but since the kit is node designed for it, I don’t know.
Thank you for you help !
