Anybody using 'Witty Pi 4 Power Management for Raspberry Pi'
I have found some devices in the ‘Witty Pi4’ family (Witty Pi 4: Realtime Clock and Power Management for Raspberry Pi | UUGear) that look like they could solve my issues with power outages.
They seem heaven sent but the code says its been tested on Raspberry OS only. Also it uses several GPIO pins which are not really supported by HAOS.
Has anybody tried using this, or similar, power management device?
My base issue is that we get a LOT of power outages here and I dont think the constant ‘crash down’ approach is doing things any good.
A conventional UPS might gracefully turn a unit OFF but if you want it too come back on when power is restored then they cant do that.
Made worse by Rpi needing to actually have its power plug removed / reinserted before it will wake up again.
Any suggestions ?
JC
Why not just get a decent UPS, which will keep your RPi on during the whole outage?
BebeMischa, well - it could be 24 hours or more so that would be an expensive UPS device and without any power in the house there is nothing it can do anyway.
JC
Ok, that was not clear from initial message - how important it is and how long the outages are :wink:
I am trying to protect against repeated ‘crash downs’ (caused by power outages) A UPS will / should allow gracefull shutdown but a major drawback with RPi is that there is no way no power it on again - typically its unpluged/replugged. The UPS will only do / simulate that if it runs completely flat.
I am pretty sure I curently have a corrupt SD card - at least the unit will not boot up unless some bits like Zigbee dongle are unplugged first. For this I have to physically interfere with the device. Not a good scenario.
JC
I would like to try this Witty system as I have HA on a boat. Did you have any success?
I have added an INA219 between the battery and the witty l3v7 so that I can monitor current. The INA219 is connected to a wemos d1 mini that tells HA if the current changes from negative to positive, ie the battery is discharging. If it is for 10 minutes then HA shuts down using an automation.
