Anyone can help?
I have a problem with mqtt switch, the error I get is this , Error loading /config/configuration.yaml: mapping values are not allowed here
in “/config/switch.yaml”, line 2, column 12 , this is the code I put in switch.yaml :
 - platform: mqtt
       command_topic: "falirospitocom/hibernate"
       payload_on: "1"
       optimistic: false
   - platform: mqtt
       command_topic: "falirospitocom/suspend"
       payload_on: "1"
       optimistic: false
   - platform: mqtt
       command_topic: "falirospitocom/reboot"
       payload_on: "1"
       optimistic: false
   - platform: mqtt
       command_topic: "falirospitocom/shutdown"
       payload_on: "1"
       optimistic: false
   - platform: mqtt
       command_topic: "falirospitocom/lockcomputer"
       payload_on: "1"
   - platform: mqtt
       state_topic: "falirospitocom/volume"
       command_topic: "falirospitocom/volume/set"
       payload_on: "20"
   - platform: mqtt
       payload_on: "20"
   - platform: mqtt
       payload_on: "90"
Your indentation is off. It should look like this:
- platform: mqtt
  payload_on: "1"
  optimistic: false
- platform: mqtt
  payload_on: "1"
  optimistic: false
etc...
thank you so much
