Anyone can please support -
which app you are using to edit the file, mine is completely different
like this or
Not app, the forum, as you post it here.
The second one
Loads default set of integrations. Do not remove.
default_config:
Load frontend themes from the themes folder
Example configuration.yaml entry
frontend:
themes: !include_dir_merge_named themes
happy:
primary-color: black
accent-color: orange
sad:
primary-color: steelblue
accent-color: darkred
script: !include scripts.yaml
scene: !include scenes.yaml
cover:
  • platform: template
    covers:
    blind:
    device_class: blind
    friendly_name: “Main”
    open_cover:
    service: script.main_blind_open
    close_cover:
    service: script.main_blind_close
    stop_cover:
    service: script.main_blind_stop
you are my super hero, I am complying killed my self, it working now thanks a lot for your quicks support
Glad you got it going.
For reference, have a read of this to explain the formatting for the forum.
one last question how can i add more blinds where should i start my second blind?
If it’s following the same tyoe of config as the previous one, just add it underneath. Make it so the name of the new blind (where you currently have ‘blind’) is indented to the same point.
hope like this
You don’t need the second set of:
  covers:
I am not getting any error after restart the HA, but I can not see my office blind
cover:
  covers:
    blind:
      device_class: blind
      friendly_name: "Main"
      open_cover:
      close_cover:
      stop_cover:
  covers:
    blind:
      device_class: blind
      friendly_name: "office"
      open_cover:
        service: script.office_blind_open
      close_cover:
        service: script.office_blind_close
      stop_cover:
        service: script.office_blind_stop
I am getting error
It needs to be like this:
cover:
  covers:
    blind:
      device_class: blind
      open_cover:
      close_cover:
      stop_cover:
    office:
      device_class: blind
      open_cover:
      close_cover:
      stop_cover:
You might also want to change the first one to “main” rather than just “blind”. Then you will also need to adjust your script from earlier.
cover:
  covers:
    blind:
      device_class: blind
      friendly_name: "Main Blind"
      open_cover:
      close_cover:
      stop_cover:
    office:
      device_class: blind
      friendly_name: "Office Blind"
      open_cover:
      close_cover:
      stop_cover:
Like this now i am getting both blind my dashboard . just testing now
Hello sparkdave, code is working now. , need to fix my remote code. Thank you a lot for your support . you make my evening wonderful " you are the best " Have a nice evening, Always keen to learn from you,
No problem. If you don’t mind, please mark my post as the solution.
How to do that.
I did already , thanks once again
No, you still have your own post marked with the Solution tag.
The post that identifies the problem and offers a correction is the one that should be marked with the Solution tag (that’s sparkydave’s post).
If you haven’t read the forum’s FAQ, I highly recommend you take a few minutes to review it. It will help you understand the guidelines for using this community forum.
Thanks a lot pointing my mistake, fix it
