My (unchanged) implementation has stopped functioning. It appears that there was a change in v56 so maybe it’s related to that. Just wondering if anyone has the same issue with devices not updating their status before I submit a ticket.
Thanks!
Thanks!
I don’t use it, but I am in the process of creating a new Unifi tracker. https://github.com/home-assistant/home-assistant/pull/10097
This is useful if you don’t want to run the unified controller, meaning you most likely aren’t using other ubiquiti hardware.
Easy to test and I would love feedback.
Place the unified_direct.py in the pull request above inside YOUR_CONFIG_DIR/custom_components/device_tracker/
Then add unified_direct to your config like mentioned in the pull request.
No issue here
Unifi 5.6.19
HA docker 0.56.2
