Linkeing from a post I put up the other day about another issue, but noticing this plus the github issue:
Github:
opened 09:50PM - 13 Jun 23 UTC
integration: wyoming
### The problem
I have whisper running in a docker container on another machine… . The logs show only `INFO:__main__:Ready`. I have uninstalled and reinstalled several times. I have deleted and reinstalled the wyoming integration for whisper several times. Each time wyoming recognizes and integrates my whisper installation. However, it then immediately reports the entity as unavailable, and it never returns. I have piper running on the same machine without any integration problems.
I have set the integration to debug logs, but no error shows up. The problem showed up on the preceding HA version (2023.05) and persists after updating to the latest (2023.06).
### What version of Home Assistant Core has the issue?
core-2023.6.1
### What was the last working version of Home Assistant Core?
core-2023.5
### What type of installation are you running?
Home Assistant Container
### Integration causing the issue
wyoming
### Link to integration documentation on our website
https://www.home-assistant.io/integrations/wyoming
### Diagnostics information
The only entry for wyoming is to show that the integration started up.
### Example YAML snippet
_No response_
### Anything in the logs that might be useful for us?
_No response_
### Additional information
_No response_
My post here: ESp32 Voice Assistant - Help (No microphone seemingly..) - #22 by vexter0944
The reason I’m asking is not only the oddity around these containers are up and the integration comes up when added and so on, but that I cannot get a wakeword to work at all. And I wonder if it has something to do with these integrations showing unknown/unavailable all the time.
