Anyone familiar with grocy? need help showing chores
hi
Ive set up 5 chores in the grocy integration and am showing them with the custom grocy card, all works fine.
the problem is the priority of these chores.
ID4 show everyday no matter what
ID1 show every 4 days unless ID2 is the same day, then show ID2, don’t show ID1 or ID3
ID2 show every 16 days unless ID3 is the same day, then show ID3, don’t show ID1 or ID2
ID3 show every 32 days, don’t show ID1 or ID2
ID5 show every 3 months no matter what
the use case is for following a feeding + supplement schedule for my gecko
each numbered block represents 4 days and there is key to show which supplement to feed.
same supplement 1,2,3,5,6,7
different supplement 4 (therefore 16 days)
different supplement 8 (therefore 32 days)
so what i’d like to do is on day 16 only show ID2 and on day 32 only show ID3
i hope ive explained this well enough
I’m not averse to abandoning grocy if this is easier to achieve with custom sensors or something
any help appreciated
thanks
I think you’d have to use a template sensor to build up a JSON attribute of what you wanted to show, based on those rules. You could then display this with List Card from HACS.
EDIT: I got curious, so this is how I’d do it. I got lazy and just did string compares with the dates.
{% set today = (now() | string)[:10] %}
{% set chores = state_attr('sensor.grocy_chores', 'chores')  %}
{% set id1 = chores | selectattr('id', 'eq', 1) | first %}
{% set id2 = chores | selectattr('id', 'eq', 2) | first %}
{% set id3 = chores | selectattr('id', 'eq', 3) | first %}
{% set id4 = chores | selectattr('id', 'eq', 4) | first %}
{% set id5 = chores | selectattr('id', 'eq', 5) | first %}
{% if id3.next_estimated_execution_time[:10] == today %}
  {{ [id4, id3, id5] }}
{% elif id2.next_estimated_execution_time[:10] == today %}
  {{ [id4, id2, id5] }}
{% elif id1.next_estimated_execution_time[:10] == today %}
  {{ [id4, id1, id5] }}
{% else %}
  {{ [id4, id5] }}
{% endif %}
Not sure I understand the feeding cycle though.
Thank you so much, I’ll have a proper look in the morning.
The feeding schedule looks more complicated than it is.
Each block corresponds to a number of days, I choose to use 4 days, so every 4 days (1 block) she gets fed and gets supplement A, Every 16 days (4 blocks) she gets fed and gets supplement B and every 32 days (8 blocks) she gets fed and gets supplement C
4 days is arbitrary, some keepers use 3 days or if the gecko is young they might use 2 days but the supplements remain the same… A Every feed, B every 4th feed and C every 8th
Bumping an old thread because I haven’t found one that addresses what I’m trying to do… I just want a template sensor (or, sensors), the status of which will be the chore name and due date if any chores are due within x days… where x is fixed, at probably something between 3 and 7.
Currently, I have 20 chores defined… but that number could grow. So using fixed references for ID # hasn’t worked well for me so far.
Don’t resurrect an old post. Make a new post that provides the information about your actual current system and your actual current goals, sufficient to help people help you.
