Anyone got the innova 2.0 connected in HA?
I will add some Innova Filomuro fancoils soon. Did you managed to get yours working with HA?
Thank you
Hello, I’m considering to order Innova Filomuro SW 400 M7, which should have a build in WiFi module. Did you manage to get this integration to work on the Filomuro?
Hi, did you find a solution for the Filomuro SW 400 M7?
hello all i’m a bit ahead of myself . I will be installing my innova in september
I eventualy bought the non-Wifi version. I did not manage to install them yet. Not sure how I will integrate it to HA. Maybe modbus is possible but I did not check the connections on the fancoil.
Hi @rivda !
Did you face some problems on finding your AC’s IP? Connected mine to innova app but cant see it on my router or anywhere
I’ve managed to connect them with the ModBus integration, in a very rudimental way. I am still strugling in reading the status and errors of the fancoils via ModBus, but I’ve been able to put them to work.
If anyone needs help I can share my experience.
Hello, Is there someone who has THE plugin to control the whole innova 2.0?
Hi, Somebody know how to connect to the new units ? DC Innova 2.0
I always get the message Host not found.
any luck connecting the innova 2.0, since i ordered one as well
I’m fairly new to the forum and I’m also trying to configure my new INNOVA 2.0 mini that I just installed.
The IP address I entered is correct, but I’m getting the following error message: ā€œConnection failedā€.
Is it possible to access the device via its IP address (I tried via the browser on port 80 without success)?
What can I check?
When I scan for open ports on the address 10.0.4.133, I get the message ā€œblocked.localā€!!! ??? I don’t see how to unblock it.
Thanks in advance to anyone who can point me in the right direction.
