Anyone hacked Xiaomi Temp sensor with eink display?
Hi
Has anyone hacked Xiaomi Temp sensor with eink display?
I was wondering whether I could you them as a low energy display across the house - they look neat.
Last I heard (in May) in this video people were working on it but no success at the time.
I think it will be soon implemented in ESPhome:
https://github.com/esphome/esphome/pull/664
It is already working here:
But not testet, yet. I do have the same device, but the official app (Android) is not working. How can I set the time???
I think I did see this one having been cracked recently, not sure where it was though.
Too bad. It looks pretty neat as a small display :/.
Here you are https://github.com/h4/LYWSD02-home-assistant
Change your country in the app to China and it will work fine.
Hi, i’ve managed to get this one working from this guy h4, but my hass instance is getting stuck when i enable this module and restart hass. Why this could be happening?
Sometimes it works for some time and then it stops responsing, after one check, at least i cannot access it thought web ui. I’ve seen it reported temp and hum in the log.
post your log.
Hmm, that’s too bad. I added this custom component to my HA setup today. Hopefully it won’t be putting my HA down. I’ll be monitoring this.
It’s a bit weird you experience such issues as this component is asynchronous and looks ok from the coding point of view (altough I’m not HA integration expert here).
I’m really glad it exists, so I can see the readings in my HA. But what I don’t like is the fact it needs a template sensors to get the values separated. I’ll take this code and I’ll try to rewrite it and make it work like the “mitemp_bt” sensor (round one). Let’s see
Why not post an issue on github?
How I get it work with hass.io? Any idea?
I tried to add custom_components directory under config-dir (because configuration.yaml is there), but no success.
What did you put inside custom_components?
Hi!
That lywsd02 directory… Actually HA red that directory, tried to start that python code, but… There was include errors and it uses different Bluetooth library what does not exists at hassio installation. It would be better if this current mitemp_bt code would include that needed protocol (it’s little bit different than LYWSDCGQ) for Xiaomi LYWSD02 BLE Sensor.
I use this clock/thermometer with ESP32 running ESPhome. This way is better for me as I can have the RaspberryPi running HASS anywhere and just the ESP must be in the Bluetooth signal range. Also the installation is pretty easy.
I would be more interested in another way of hacking this device - according to Xiaomi you can pair some devices (toothbrush) so they can display some information directly on the clock. This would be awesome to have this clock as universal 7 segment “88:88” display to use!
Also I would welcome the time sync - the clock is running its internal RTC but it is slowly drifting. Even I have Yeelight lights that act as bluetooth bridge (so I can see the temp reading in Mi Home app even if I am out of range or have bluetooth disabled), the communication is unidirectional - the lights don’t connect to the clock and they don’t sync the time. As I don’t like (and need) to use mi home app my clock is slowly drifting from real time. In the event of DST they don’t adjust automatically etc. That is quite a bad product design to be honest…
Hey @Atlantis any details on the ESPHome config you used to flash and readout the info from the clock? And the info is than displayed in Home Assistant?
Hi, I use very simple code.
Those 3 sensors appear in HASS (temp+humidity+bluetooth RSSI)
esp32_ble_tracker:
  - platform: ble_rssi
    mac_address: 3F:5B:7D:71:XX:XX
  - platform: xiaomi_lywsd02
    temperature:
    humidity:
      name: "Clock humidity"
You can use GadgetBridge on Android to set the time very nicely.
I posted details on how to do this from a Pi on a ticket in github.
Summary,
  • get the MAC using sudo hcitool lescan,
    • note you may need to hcitool hci0 down then hcitool hci0 up the interface, then
  • use gatttool -b 00:00:00:00:00:00 -I
  • in that connect
  • use a web browser groovy console to execute some bit shifting hex magic, then
  • take the output and append
  • in gatttool to the command char-write-req 0x002f the magic value from above.
