Anyone had luck with Popp Keypad?
No luck with Home Assistant/ozwcp here. I have tried to raise an issue and ask for help in OpenZwave’s mailing list, but the developer doesn’t recognise it as a fault on their end.
What happens when you try?
I think the secure inclusion fails. I successfully added it to Fibaro HC2.
Details:
Did you try the factory reset as they recommended?
Many times. I managed to include it to Fibaro HC2 with no problems, so I suspect either OpenZwave or the keypad is at fault. I would like to contribute to fix/work around the issue, but I need some support from the developers, and it seems like they don’t have time.
It would be very interesting to know if anyone else have similar experiences (or even more interesting if someone managed to add it :slight_smile: )
Fixed in https://github.com/OpenZWave/open-zwave/commit/2edc26684d91d808e2bebf172e0372a34258ef1c. Now, I need to find out how to use the latest version in Home Assistant :slight_smile:
How did you get it to work?
I’m not getting scene I’d all the time just only some times.
Gather the scene IDs in HA (hass.IO) and then an automation that should trigger but it doesn’t trigger. Its triggering to lock my danalock. Please help
See Popp Keypad :slight_smile:
