Anyone have any experience of a Moes wall thermostat?
Hi there.
I am looking at adding some smart control to my central hearing and was thinking of swapping my programmable wall thermostat with a Moes thermostat - specifically, the BHT-002-GCLZ which is Zigbee based and used to control a gas boiler.
Any advice/comments, before I get one, would be much appreciated.
I have one in use for two years. It works. Just one annoying thing is very short time while backlight is on after changing something, and this time can’t be changed.
Thank you - that is good to hear.
Does the device come with any built-in intelligence?
My current programmable timer seems to work out of the box - i.e. you tell it what temperature you want it, at a certain time, and it gradually learns how early to turn the heating on to achieve this.
Does your thermostat offer something similar?
Yes, thera is a possibility to set 4 different temperatures for 4 times for workday, saturday and sunday.
So if you, say, set 17 degrees at 7am - does that turn on the hearting at 7am and run it until 17 degrees is reached.
Or, does it turn on the heating beforehand in an attempt to have the heating at 17 degrees when it gets to 7am?
I don’t use its internal scheduler so I really don’t know. I control it exclusively via HA, so I really don’t know.
