Hello!
I’ve an arduino analog input via home assistant.
Can someone help with the template sensor to do this??
Any reading from 0 to 34 id like to reflect ON state. At 35 and above I’d like a template sensor to change its state to OFF from ON.
sensors:
water_present:
value_template: >-
{% if states('sensor.sensor.water_present')|float < 35 }
ON
{% else %}
OFF
{% endif %}
Any pointers appreciated!
123
(Taras)
October 17, 2019, 12:44am
2
Given that you only want the sensor to have one of two possible states, ON or OFF, make it a Template Binary Sensor.
binary_sensor:
sensors:
water_present:
value_template: "{{ states('sensor.water_present')|float < 35 }}"
You can optionally add a device_class to enhance the binary_sensor’s appearance in the Lovelace UI.
binary_sensor:
sensors:
water_present:
device_class: moisture
EDIT
Sensor’s entity_id was incorrect and I just blindly copied it.
Changed:
to:
That was a quick reply, thanks for taking the time!
It worked. I had a blonde moment with a sensor name. I put “sensor.sensor_blah” instead of just “sensor.blah”.
But its working…
Much appreciated 123
(Taras)
October 17, 2019, 1:36pm
4
… and I just blindly copy-pasted the invalid entity_id.
I’ve corrected the example above.
BTW, there’s something not quite right about the template sensor in the example. It has the same name (water_present
) as the sensor being testing within the template (water_present
). One of them should be different, yes?
Working a charm! Thank you
