Does anyone know how to get the old_state of an input_slider? I want to be use the input_slider to control the volume of an amplifier using lirc. Thus I need to know what the last value of the slider was to know whether it went up or down and to thus send the correct command.
Thanks for the responseā¦I thought I had posted a reply to you. Doh!
Iāve spent some time learning HA and I still think the from_state value is not made available ie it is not a state property.
Here is the automation:
automation 3:
alias: Sony Amp Volume Set
platform: state
entity_id: input_slider.ampvol
service: notify.notify
message: āVolume has gone from {{ states.input_slider.ampvol.from_state}} to {{ states.input_slider.ampvol.state}}ā
The message I receive is:
Volume has gone from to 14.0
It doesnāt matter whether I use from_state or old_state.
I can make automations work when the trigger is from a value to another value so the triggering code āknowsā the old_state but I need to know simply if the difference between old_state and current state is positive or negative. Thus I would know whether to turn volume down or up.
automation 3:
platform: state
message: 'Volume has gone from {{ trigger.from_state.state }} to {{ trigger.to_state.state }}'
Hi. Just for anyone elseās benefit Davidās answer is almost right. This requires the data_template to be used thus the following does work OK:
automation 3:
platform: state
data_template:
message: 'Volume has gone from {{ trigger.from_state.state }} to {{ trigger.to_state.state }} '
Ok so one tiny step forward. Now Iām trying to build an if statement into the data_template but it fails. This is the automation:
automation 3:
platform: state
data_template:
message: {% if trigger.to_state.state | int - trigger.from_state.state | int < 0 %}
'Volume has gone DOWN! '
{% else %}
'Volume has gone UP! or stayed the same'
{% endif %}
The error log shows the following and homeassistant does not start:
16-08-31 20:21:52 homeassistant.util.yaml: while scanning for the next token
found character '%' that cannot start any token
in "/home/hass/.homeassistant/configuration.yaml", line 65, column 17
automation 3:
platform: state
data_template:
message: >-
{% if (trigger.to_state.state | int - trigger.from_state.state | int) < 0 %}
{% else %}
{% endif %}
The main issue is that your message (the entire if-statement in your case) either needs to be quoted, or started with > followed by a newline. Using >- instead of just > strips unnecessary newlines and spaces from the text being shown.
I also wrapped your if between parentheses so the entire thing gets compared to 0, not just the from state. Or you could use the following if instead: if trigger.to_state.state | int < trigger.from_state.state | int
Finally, I just fixed the indentation here and there.
Wow! You are a champion. Thanks. Worked perfectly and I will give me a rap on the knuckles for not carefully looking at syntax. Thanks againā¦now to send the correct lirc commands
