Anyone managed to integrate eToro to HA?
It would be nice to take take a periodic reading of my account and save the details in HA.
this thread explains how to extract info through API … I guess a REST sensor will do the trick but I have no idea how to implement it
RESTful integration should do the trick indeed
I briefly looked at the data and I assume you would need a sensor per instrumentID so if these are stable then that should work
can you guide me how to build the sensors for the instrument ID? ![:slight_smile: :slight_smile:](https://community.home-assistant.io/images/emoji/twitter/slight_smile.png?v=10)
It should (!) be something as per below but the site is rejecting the rest request (not allowed). So if you have another way to access/download the data then we can have a further look
- platform: rest
scan_interval: 3600
resource: "https://www.etoro.com/sapi/trade-data-real/live/public/portfolios?format=json&cid=3180395"
value_template: "OK"
json_attributes:
- AggregatedPositions
As an example for when you have proper access to the data…
I put the data in a file in folder www, called testing.json (arbitrary)
The used this:
- platform: rest
scan_interval: 3600
resource: "http://192.168.1.20:8124/local/testing.json"
value_template: "{{ value_json.AggregatedPositions.0.NetProfit }}"
json_attributes_path: $.AggregatedPositions.0
json_attributes:
- Direction
Which gives me:
EDIT: So the 0 in the path points to the first group in AggregatedPositions… as the InstrumentID is not a group one has to extract 0 as a sensor, then 1 …etc… hence me mentioning that the resultset should be stable.
Note that one can e.g. use the InstrumentID as State to identify the individual sensors
thanks … i thought that it would be possible to use the text returned when using your URL in a web browser, and parse it into sensors.
thanks, will take a look at your suggestions and revert!
can you maybe put the value_template in the first example shown in this and create sensors?
One can do a lot … but I cannot get the data through the website, this is part of the debug log
<span class="error-description">Access denied</span>
<span class="code-label">Error code <span>1020</span></span>
</h1>
<div class="large-font">
<p>You do not have access to www.etoro.com.</p><p>The site owner may have set restrictions that prevent you from accessing the site. Contact the site owner for access or try loading the page again.</p>
</div>
</div>
</div>
<div>
<div class="clearfix section">
<div class="column know-more">
<h2 class="large-font">Additional information</h2>
<p>The access policies of a site define which visits are allowed. Your current visit is not allowed according to those policies.</p><p>Only the site owner can change site access policies.</p>
</div>
So… although I can;t care less about eToro… I was interested in the access issue and managed to circumvent it
… learning-moment for me too
So… below works, produces the first two sensor/InstrumentID from the page
rest:
- authentication: basic
scan_interval: 3600
verify_ssl: false
headers:
Content-Type: application/json
User-Agent: Home Assistant
Accept-Encoding: identity
- name: ID0
value_template: "{{ value_json.AggregatedPositions.0.InstrumentID }}"
json_attributes:
- NetProfit
- Direction
- name: ID1
value_template: "{{ value_json.AggregatedPositions.1.InstrumentID }}"
json_attributes_path: $.AggregatedPositions.1
json_attributes:
- NetProfit
- Direction
great! I was very near but didnt manage to make it work!
will try it out tomorrow and will let you know how it goes!
Just tried it now … a direct copy and paste of your code so that first I try to understand what is going on but it is not working ![:frowning: :frowning:](https://community.home-assistant.io/images/emoji/twitter/frowning.png?v=10)
does it normally update immediately after HA restart?
Odd… can you please add this to the logger section in configyaml and restart?
homeassistant.components.rest: debug
I just extended it with two new sections…all fine
rest:
scan_interval: 3600
verify_ssl: false
headers:
- name: ID0
json_attributes:
- NetProfit
- Direction
- name: ID1
json_attributes:
- NetProfit
- Direction
- name: ID2
value_template: "{{ value_json.AggregatedPositions.2.InstrumentID }}"
json_attributes_path: $.AggregatedPositions.2
json_attributes:
- NetProfit
- Direction
- name: ID3
value_template: "{{ value_json.AggregatedPositions.3.InstrumentID }}"
json_attributes_path: $.AggregatedPositions.3
json_attributes:
- NetProfit
- Direction
I checked this morning and now it is OK without doing any changes … i think I had to wait a bit more ![:slight_smile: :slight_smile:](https://community.home-assistant.io/images/emoji/twitter/slight_smile.png?v=10)
can you maybe what the following really mean? because my account it slightly different from the one being used in your example:
sorted mate … understood how it is working!
thanks!
Ah, I thought your portfolio was made public …
use a json viewer (if not already done so) e.g. Online JSON Viewer (stack.hu)
thanks managed to do what I need.
this is unrelated but I would like to avoid opening a new thread. now I renamed the sensor name but the old ones are still in HA and cannot be deleted (grayed out) will these be removed automatically?
I only try things out on a dev instance that I refresh to my liking … having a container setup this is pretty easy
so there is not way to remove it?
