Anyone successfully using an external database when HASS and MySQL are both separate docker containers?
I followed the guide but still can’t get my external db to work consistently. It seems after some time period, the db gets corrupted and tries to write way outside of it’s allotted space with the following error:
 [ERROR] InnoDB: Trying to access page number 72613888 in space 4294967294, space name mysql, which is outside the tablespace bounds. Byte offset 0, len 16384, i/o type read. If you get this error at mysqld startup, please check that your my.cnf matches the ibdata files that you have in the MySQL server.
CONFIG:
recorder:
  purge_interval: 50
  purge_keep_days: 180
  db_url: mysql://hass:[email protected]:8124/hass?charset=utf8
DOCKER COMPOSE:
  homeassistant:
    image: homeassistant/home-assistant
    container_name: homeassistant
    restart: always
    network_mode: host
    depends_on:
      - homeassistant_mysql
      - mosquitto
    volumes:
      - ./appdata/home-assistant:/config
    devices:
      - "/dev/ttyACM0:/zwaveusbstick:rwm"
    ports:
      - "${IP_ADDRESS}:8123:8123"
    environment:
      - PUID=${PUID}
      - PGID=${PGID}
      - TZ=${TZ}
  homeassistant_mysql:
    image: mysql:latest
    container_name: homeassistant_mysql
    restart: always
    network_mode: host
    volumes:
      - ./appdata/home-assistant_mysql:/var/lib/mysql
      - /etc/timezone:/etc/timezone:ro
    ports:
      - "${IP_ADDRESS}:8124:3306"
    environment:
      MYSQL_ROOT_PASSWORD: "test"
      MYSQL_DATABASE: "hass"
      MYSQL_USER: "hass"
      MYSQL_PASSWORD: "test"
      TZ: ${TZ}
