I’m currently in the market for a new ducted reverse cycle system for my home and are interested in integrating it with Home Assistant.
A number of installers in my area are pushing Fujitsu systems which use the Fujitsu AnywAiR controller (Ducted Controller | anywAiR® Technology | Fujitsu General). As far as I can ascertain this is a rebranded Advantage Air MyAir controller. I’ve done a lot of searching around on the forums and the Google and haven’t been able to find a lot of information outside of the marketing material.
I was wondering if anyone here had an AnywAiR controller in their home and had they succeeded in integrating it with Home Assistant?
So I have the AnywAiR controllers installed in my home and I have been able to set them up using hte existing Advantage Air integration that already exists: Advantage Air - Home Assistant
I inspected the traffic going from the app using an app and found that they use the a different port to the default in the Advantage Air i.e. port 10211
Then try to setup the advantage air integration by entering the ip address and replacing the port with 10211
The only thing I have found is that zones that don’t have an associated thermostat are not showing up as controllable but everything else is working fine.
Hey, @zecuria was there anything else you did that was special?
I just got Fujitsu AnywAir installed in house, I can easily find IP address of device (tablet). I made it static as well. I did some traffic checking and it looks like my phone sends a message to device via port 10211 as well. But I tried entering that in Advantage Air integration but just keep getting “Failed to connect”. I’m thinking have Fujitsu done something different to lock it down? What did you use for traffice sniffing? I’m just using wireshark but maybe it’s reporting wrong port?
e.g. {"aircons":{"ac1":{"info":{"activationCodeStatus":"noCode","airconErrorCode":"","deleted":8,"deleted":64,"cbType":50,"climateControlModeIsRunning":fals/…
Hey, just wondering if you ever got this working and how you are finding the anywAiR system. I’m looking at installing one. Lack of integrations is a massive negative tho.
Hey, yep got it working. See more details and conversation as part of github issue.
I think the anywAir system goes to sleep so something and can’t communicate with it. But once you connect, the integration keeps it awake and its been working great. Once setup can easily control all areas and set zones etc. See attached picture.
Only thing to note. When I’ve had my Home Assistant server randomly shut down (turned off power) and integration hasn’t talked to anywAir for a while. The integration can’t talk to anywair again on first boot. I just need to restart home assistant and fiddle with anywAir a bit to get them talking again, but once connected again runs fine. This has happened two to three times over the month but it’s always after I’ve reset power.
Things should be stable for now but that’s the only thing, read the github issue more but something with these specific tablets provided, need continuously pinging to keep connection alive or something. The integration does that for you in a way. It’s just if integration is down for while, you might have issues with me to get them talking again.
Great, thanks for the reply. Im going to be getting a system installed in the coming weeks so will report back on how I get on with getting this running
Installed today and changing to the port you mentioned above allowed me to connect! Im a home assistant nob so need to do some research into how you created the cart in your image above
Hey, hope it’s working well. Here is my YAML config for that widget on the dashboard. So you should be able to replicate. Just change sensors as your’s etc. Just not I’m also using some custom UI components from HACS store like mushroom cards and multiple-entity-row, but you will be able to see that all in the YAML config below.
I got mine connected today, as @apat183 said, looks like the tablet goes to sleep, I tried sending commands form the app on my phone just before trying to connect but still it would respond.
What it worked for me was to send a ping to the port via windows powershell, first attempt came negative response, second attempt was positive and did the home assistant connection straight after and it worked
