Are there any HA users using the Enphase IQ EV charger? I’m wondering if it integrates or provides any information through the Envoy integration, or would we need a separate integration?
Use case: I’d be interested in seeing effective kW charging rate, especially when the charger is setup to use only excess solar power. Perhaps setting up notification when charging starts, etc.
Id be interested in this as well, but I’m not too hopeful. The Enphase integration connects to the local Enphase controller, but the EVSE seems to talk directly to the cloud.
Basically, you’ll need your site id, evse serial number and the set of cookies from a valid enlighten session, and can put something like the code below into your configuration.yaml.
To make a sensor that determines how much power you’ve added in the current charging session, with properties for the charging status and the plugged-in status:
I’m not seeing a way to edit my original reply, so I just wanted to add that the payload for the start_charging command has changed. The “chargingLevel” should now be the max amps for your charger instead of 100%. So:
