I have been able to add a type: energy-date-selection card to my normal dashboard but the sankey card seems to just ignore it. All sensors used in my sankey card have existed for months already.
Feature request: One thing that would be awesome, is to be able to set the width per section (as a % for instance). This would help me balance sections better depending on what’s in them.
update on my styling issue: we need to go into the shadow root…
type: custom:sankey-chart
title: Energie verbruik
card_mod:
style:
.card-header {
background-color: var(--background-color-off);
font-weight: 400;
font-size: 20px;
color: var(--text-color-off);
padding: 0px 12px;
margin: 0px 0px 16px 0px;
see: 🔹 Card-mod - Add css styles to any lovelace card - #3911 by arganto and thanks @arganto for solving this for me.
hi, the card its awesome, but we have a problem, can you help me?
the solar its not connected,
show_names: true
title: Live energy dashboard
energy-date-selection: true
wide: true
height: 400
min_box_height: 10
sections:
- entities:
- entity_id: sensor.solaredge_current_power
color: var(--warning-color)
- entity_id: sensor.actuele_energie
- entity_id: sensor.p1_meter_active_power
color: '#1fc527'
children:
- sensor.meterkast_power
- sensor.oplader_dashboard_tablet_power
- sensor.afzuiging_stand_1_power
- sensor.lumi_lumi_switch_n0agl1_bebc0900_electrical_measurement
- sensor.oplader_jonathan_power
- sensor.voorvensterbank_watt_power
- sensor.achtervensterbank_power
- sensor.deurbel_watt_power
- sensor.diepvries_power
- sensor.wasmachine_electrical_measurement
- sensor.droger_electrical_measurement
- sensor.koelkast_electrical_measurement
- sensor.tz3000_amdymr7l_ts011f_ce6b9c7b_electrical_measurement
- sensor.hybride_pomp_power
- sensor.shellyswitch25_e66d26_channel_1_power
- sensor.keukenkast_power
- sensor.lumi_lumi_switch_n0agl1_electrical_measurement
- sensor.grondspots_power
- sensor.plafondspots_power
- sensor.samsung_scherm_power
- sensor.vogels_boven_power
- sensor.vogels_onder_power
sensor.leidingwaterklep_en_ledstrip_regenton_waterniveau_channel_2_power
- sensor.vloerlamp_power_2
- sensor.keuken_google_power
- sensor.schuur_google_power
- sensor.chromecast_power
sensor.back_up_stroom_netwerk_apparaten_schuur_electrical_measurement
- sensor.keukenspots_level_on_off_power
- sensor.oplader_fiets_jonathan_active_power
- sensor.ledbalken_power
- sensor.google_nest_hub_voeding_jonathan_power
- sensor.google_nest_hub_voeding_karin_power
- sensor.afzuigkap_power
- Overig
- entities:
- sensor.leidingwaterklep_en_ledstrip_regenton_waterniveau_channel_2_power
- sensor.back_up_stroom_netwerk_apparaten_schuur_electrical_measurement
- entity_id: Overig
type: remaining_parent_state
color: '#e56353'
You have to add children to it. It doesn’t have any connections configured right now.
can you please share your full code? I am struggling with low and high tariff and it seems you have this nicely setup
I’m attempting to get the totals side done first before I narrow it down to the known areas and devices (With the helpful “remaining state” functions).
I can’t get two pieces to work, any help would be appreciated.
- At the leftmost column, I am trying to also show the “Totaal Ingekocht” from one column to the right.
Despite using this piece of yaml, the likes of which functions properly elsewhere in the card, I’m getting an error TypeError: e.attributes is undefined
yaml attempt 1
- entity_id: Inkoop
type: remaining_child_state
children:
- TotaalIngekocht
found a workaround, documentation suggests it would work better
Given that my solar inverter’s lifetime production includes both the energy given back to the grid and energy directly used in the grid, I am attempting to pass the direct usage (Direct Verbruik, which is the remaining_parent_state after production has been subtracted from the solaredge production) two levels down to be added into TotaalVerbruik. This gives Error: Entity Not Found Totaalverbruik.
In reading the documentation, I’m led to believe the sankey chart would automatically show a passthrough node.
As a workaround, I’ve created an extra dummy node in the layer in between. (Not shown in below yaml or screenshot)
Perhaps remaining_parent_node and skipping levels does not play nicely together?
yaml and screenshot
show_names: true
unit_prefix: k
round: 1
height: 1000
wide: true
energy_date_selection: true
sections:
- entities:
- entity_id: sensor.solaredge_lifetime_energy
type: entity
color: orange
children:
- DirectVerbruik
- TotaalGeproduceerd
- entities:
- entity_id: TotaalIngekocht
name: Totaal Ingekocht
children:
- sensor.energy_consumed_tariff_1
- sensor.energy_consumed_tariff_2
- entity_id: DirectVerbruik
- entity_id: TotaalGeproduceerd
name: Totaal Teruggeleverd
children:
- sensor.energy_produced_tariff_1
- sensor.energy_produced_tariff_2
- entities:
- entity_id: sensor.energy_consumed_tariff_1
children:
- TotaalVerbruik
- entity_id: sensor.energy_consumed_tariff_2
children:
- TotaalVerbruik
- entity_id: sensor.energy_produced_tariff_1
- entity_id: sensor.energy_produced_tariff_2
- entities:
- entity_id: TotaalVerbruik
I am working on am autoconfig option right now and some aggregation functions. An initial version will probably be released today or tomorrow. This should give you a config very similar to what you want and good starting point.
Hi Guys, need some help. Not sure what I am doing wrong. As soon as I change “energy_date_selection” to “true” it removes all the relation lines from the graph. Is this supposed to work like his? What am I missing here?
Looks like you have no data. Try changing the date in the date selection card
Thanks but unfortunately that is not changing anything. I will wait for your “auto config” option Thank you for the great work!
I saw the autoconfig was in the latest release. Tried it, but it continuously shows “Loading…” I did add a energy-date-selection
Any thoughts?
Do you get an error after 10s? If not then you must have the previous version cached.
There is an issue where the energy data doesn’t come and it loads for a while but it will timeout after 10 seconds. It happens extremely rarely on my setup so I haven’t been able to tackle it yet.
Is it possible to display a remaining_child_state
entity, without showing each individual child entity in a subsequent section? There are times when seeing the individual entities isn’t necessary.
So here’s an example of what I hoped might work:
sections:
- entities:
- entity_id: sensor.electrical_circuits_power
children:
- sockets
- entities:
- entity_id: sockets
children:
- sensor.electrical_circuit_9_power
- sensor.electrical_circuit_10_power
It doesn’t seem to work, so guessing this isn’t currently possible?
Nope. You have to display them, otherwise it gets to complicated to manage.
You would be better off creating a template entity for this.
No problem - sounds like the beta HA update for December allows you to create sum entities without needing to use a template, so that would likely make it pretty trivial.
Apologies, but am fully sure that I removed any browser cache (even used a browser which has never accessed Homeassistant before) and still get the below for longer than 10 seconds.
