You were right. The system dident have the correct local time. Tm_hours was off by 2. After changing it in rasp-config and restarting it the Västtrafik now shows correct time. You are awesome! Thank you for taking the time guiding me!
//Christian
//Christian
Great! Do you use this regulary to find the time?
Are you on iOS or android? If so then you can use automation apps like workflow or tasker to make favorite trips and get them instead of fiddle with VT or HA. That way you could get more departures then the only upcoming next departure.
Personally I’ve made an app for my apple watch that has my most common journeys (and much more, basically I have all of the VT app functionality in my watch). But it’s a hobby project and not available on the app store.
Hi @RitteT, could you explain it in more details? I use this component as well as Android. I would like to get more useful information regarding departure, however, the current component is quite limited.
If you use the app tasker you can pretty much extract what info you want.
I don’t have tasker, but on iOS I wrote a script in workflow that pulled out much more info than the component in hass.
Are you familiar with curl and parsing json?
Unfortunately, I’m not familiar with curl and json.
I guess it’s a little been harder then. You need to make network request and parse json. Not very difficult but could be confusing if you’re very new to it.
If you want to learn it, and give Tasker a shot I’ll gladly help you.
It would be nice if we could implement something like this in Home assistant. I´m using it today with the Iframe component but i cannot change the background color which is horrible.
Link to see departures
https://vasttrafik.weightpoint.se/?stopId=9021014006480000
Search for stops,
Is anyone using this and got this to work?
Seems the API has changed or something is broken?
I’m using it. It basically works, but I had to add the lines separately to the sensors, like:
- platform: vasttrafik key: !secret vast_key secret: !secret vast_secret departures: - from: Scandinavium, Göteborg name: vast_tram2 lines: - 2 delay: 0 - platform: vasttrafik key: !secret vast_key secret: !secret vast_secret departures: - from: Scandinavium, Göteborg name: vast_tram13 lines: - 13 delay: 0
But I haven’t investigated in details yet.
What card are you using to get it like that?
I’m using custom:flex-table-card
Could you share your yaml files? Or atleast the setup for the vasttrafik part?
I have copied your setup above but still doesnt work.
I have created the API as mentioned, even linked it to their applications Reseplanerare and Trafic situations but still doesnt work.
Im not to familiar with flex custom card
Sure, first make sure Sensor is ok for Västtrafik, and you can see the data in HA:
Then move on to the Flex-table-card:
Once those are OK, you can add a card to the UI. My card is:
type: 'custom:flex-table-card' title: Public Transport columns: - name: From Scandinavium attr: line - name: Direction attr: direction - name: Depart at prop: state entities: include: - sensor.vast*
Here:
sensor.vast* - will include every Västtrafik sensor component you have created, if you follow my naming rule:
Hi, noob here,
I set up Västtrafik developer account and added subscriptions to services to my ”app”. However it’s just showing ”unknown”. Anyone have an idea what’s up?
D
Thanks - helped a lot…
Did you ever find a solution for this? I’m having the same issue.
Also having this issue.
Long time since anyone replied…anyway.
I also had Unkown issue with my sensors, but after using the ID instead of the station name as Destination I got it working.
I know I’m 5 year late on this, but I’ve used the flex-table-card, which is quite flexible to use css, and got decent results:
type: custom:flex-table-card
title: Västtrafik - Svingeln
strict: true
max_rows: 20
sort_by:
- Departure+
entities:
include: sensor.vasttrafik_departure_table
columns:
- name: Sort column
data: Departure
align: center
hidden: true
modify: >-
Math.round((Date.parse((x.rtDate ? x.rtDate : x.Date) + " " + (x.rtTime ?
x.rtTime : x.Time)) - Date.now())/60000)
- name: Line
data: Departure
modify: x.sname
align: center
hidden: true
style: '''background-color: '' + x.bgColor + '';'' + ''color: '' + x.fgColor + '';'''
- name: Line
data: Departure
modify: >-
'<div style="padding: 1px 1px 4px 1px; height: 16px; color: ' + x.fgColor
+ '; background-color: ' + x.bgColor + '"> ' + x.sname +
' </div>'
align: center
- name: Direction
data: Departure
modify: x.direction
- name: Departure
data: Departure
align: center
modify: |-
if (typeof(x.rtTime) == "string" & typeof(x.rtDate) == "string")
var minutes = Math.round(Math.max(0,(Date.parse(x.rtDate + " " + x.rtTime) - Date.now())/60000));
if (minutes>=60 || isNaN(minutes))
{{ x.rtTime }}
else if (minutes == 0)
"Now"
else
{{ minutes }}
else
var minutes = Math.round(Math.max(0,(Date.parse(x.date + " " + x.time) - Date.now())/60000));
{{ x.time }}
"Now"
else
{{ minutes }}
- name: Platform
data: Departure
align: center
modify: >-
x.track + ' <ha-icon icon="mdi:' +
x.type.toLowerCase().replace("tram", "tram-side") + '"></ha-icon>'
css:
tbody tr:nth-child(odd): 'background-color: #535B64;'
tbody tr:nth-child(even): 'background-color: #3C4650;'
style: |
ha-card {
--mdc-icon-size: 16px;
It’s probably possible to scrape data from their website directly, but I’m using a rest sensor to fetch this info.
I’ve certainly lots of spaces for improvement, but my sensors settings are on github:
That rest sensor looks awesome!
I just got it working and I copied your css from flex-card as well.
Thank you for the great work!
