Tried your setup and works great. Getting an error on the timedate template though, you get the same?
Not comfortable with code so don’t really know how to interpret it…
Template variable error: ‘dict object’ has no attribute ‘DepartureBoard’ when rendering ‘{{ (value_json.DepartureBoard.serverdate + ’ ’ + value_json.DepartureBoard.servertime) | as_timestamp | timestamp_local }}’
Any chance of getting an update of the REST config? Västtrafik seems to have changed API in their end and I can’t seem to get the config correct with the new urls
I’m so sorry for the loooong delay here.
I finally found some time to look at this. You will find my updated sensor here, and this is my card used to display the values:
That is some great work @EdwardTFN, thank you so much! As your solution is superior to the one included in HASS in every way, do you think it would be possible to have yours replace the one in HASS?
