were you able to make it work with your Hass.io instance? I’m able to connect and see in zigbee2mqtt the different events going in. However I’m stuck here.
What to do next to setup correctly the pin code and build automation around it?
Hi @ninja-2,
I am thinking of buying it to link it with my manual alarm control panel.
Do you know if it is possible to start making it ring lightly when someone enters the house, before the alarm gets off?
I didn’t find any option for this. The only noise that the keypad makes it’s when you press a button or when it activate/deactivate (with 6 key codes) the alarm.
