Hey was wondering if there is a way to have two different values for the built in sensor card? I made a custom rounded temperature sensor that grabs my nest temp and rounds to .5 and removes the .0 if there is one. Makes for a nice text read out. The issue is though my sensor line is essentially straight without the decimals. I lose out from .1-.4 and .6-.9.
Is there a way without using some Frankenstein combo to have the direct sensor info do the graph and my custom do the text?
How is the readout done? With TTS and a template to put the temperature in the message? Or is it simply a case of asking for the sensor’s value? If the former, just format it in the template instead.
There are a few other things to consider here.
You can now set the precision for a sensor on the frontend, so you can use the raw sensor, but display it nicer.
You can also have two sensors: one for display and one for the readout.
Also sounds to me that you might be missing a unit of measurement somewhere.
I found the precision option on the sensor that I wasn’t aware of. It seems to be doing the trick. The graph line when I use the info direct from the thermostat is much more pronounced vs my custom sensor that shows minimal change.
