I am running HAOS w/ zwavejs and a Zooz USB stick. I was trying to update a Zen14 (outdoor plug) firmware and got an error message ~7% in “update failed”. I thought I would try a network heal for this device and try again, but got an error message that a heal was already in process. After ~8 hours I noticed the heal was still going on… I tried rebooting, unplugging the devices, and it still is showing an active heal is underway. I then took a look at the zwave logs and saw this:
2022-12-03T04:48:15.562Z CNTRLR « [Node 059] Received Firmware Update Get, but no firmware update is in progress
. Forcing the node to abort...
2022-12-03T04:48:16.288Z CNTRLR « [Node 059] Received Firmware Update Get, but no firmware update is in progress
2022-12-03T04:48:16.497Z CNTRLR « [Node 059] Received Firmware Update Get, but no firmware update is in progress
2022-12-03T04:48:16.720Z CNTRLR « [Node 059] Received Firmware Update Get, but no firmware update is in progress
2022-12-03T04:48:16.917Z CNTRLR « [Node 059] Received Firmware Update Get, but no firmware update is in progress
2022-12-03T04:48:17.125Z CNTRLR « [Node 059] Received Firmware Update Get, but no firmware update is in progress
2022-12-03T04:48:17.238Z DRIVER Dropping message with invalid payload
2022-12-03T04:48:17.463Z CNTRLR « [Node 059] Received Firmware Update Get, but no firmware update is in progress
2022-12-03T04:48:17.668Z CNTRLR « [Node 059] Received Firmware Update Get, but no firmware update is in progress
2022-12-03T04:48:17.875Z CNTRLR « [Node 059] Received Firmware Update Get, but no firmware update is in progress
2022-12-03T04:48:18.084Z CNTRLR « [Node 059] Received Firmware Update Get, but no firmware update is in progress
2022-12-03T04:48:18.290Z CNTRLR « [Node 059] Received Firmware Update Get, but no firmware update is in progress
2022-12-03T04:48:18.498Z CNTRLR « [Node 059] Received Firmware Update Get, but no firmware update is in progress
2022-12-03T04:48:18.707Z CNTRLR « [Node 059] Received Firmware Update Get, but no firmware update is in progress
2022-12-03T04:48:18.919Z CNTRLR « [Node 059] Received Firmware Update Get, but no firmware update is in progress
2022-12-03T04:48:19.124Z CNTRLR « [Node 059] Received Firmware Update Get, but no firmware update is in progress
2022-12-03T04:48:19.332Z CNTRLR « [Node 059] Received Firmware Update Get, but no firmware update is in progress
2022-12-03T04:48:19.543Z CNTRLR « [Node 059] Received Firmware Update Get, but no firmware update is in progress
2022-12-03T04:48:19.750Z CNTRLR « [Node 059] Received Firmware Update Get, but no firmware update is in progress
2022-12-03T04:48:19.956Z CNTRLR « [Node 059] Received Firmware Update Get, but no firmware update is in progress
2022-12-03T04:48:20.162Z CNTRLR « [Node 059] Received Firmware Update Get, but no firmware update is in progress
2022-12-03T04:48:20.371Z CNTRLR « [Node 059] Received Firmware Update Get, but no firmware update is in progress
2022-12-03T04:48:20.579Z CNTRLR « [Node 059] Received Firmware Update Get, but no firmware update is in progress
2022-12-03T04:48:20.792Z CNTRLR « [Node 059] Received Firmware Update Get, but no firmware update is in progress
2022-12-03T04:48:20.998Z CNTRLR « [Node 059] Received Firmware Update Get, but no firmware update is in progress
2022-12-03T04:48:21.206Z CNTRLR « [Node 059] Received Firmware Update Get, but no firmware update is in progress
2022-12-03T04:48:21.414Z CNTRLR « [Node 059] Received Firmware Update Get, but no firmware update is in progress
2022-12-03T04:48:21.622Z CNTRLR « [Node 059] Received Firmware Update Get, but no firmware update is in progress
2022-12-03T04:48:22.177Z DRIVER Dropping message with invalid payload
2022-12-03T04:48:22.563Z DRIVER Dropping message with invalid payload
2022-12-03T04:48:24.172Z DRIVER Dropping message with invalid payload
2022-12-03T04:48:24.534Z DRIVER Dropping message with invalid payload
2022-12-03T04:48:24.900Z DRIVER Dropping message with invalid payload
2022-12-03T04:48:36.663Z CNTRLR [Node 059] did not respond after 1/3 attempts. Scheduling next try in 500 ms.
2022-12-03T04:48:58.453Z DRIVER Dropping message with invalid payload
2022-12-03T04:49:01.206Z CNTRLR « [Node 059] Received Firmware Update Get, but no firmware update is in progress
2022-12-03T04:49:02.106Z CNTRLR « [Node 059] Received Firmware Update Get, but no firmware update is in progress
2022-12-03T04:49:03.113Z CNTRLR « [Node 059] Received Firmware Update Get, but no firmware update is in progress
2022-12-03T04:49:03.464Z DRIVER Dropping message with invalid payload
2022-12-03T04:49:11.130Z CNTRLR « [Node 059] Received Firmware Update Get, but no firmware update is in progress
2022-12-03T04:49:15.765Z CNTRLR « [Node 059] Received Firmware Update Get, but no firmware update is in progress
2022-12-03T04:49:20.645Z CNTRLR « [Node 059] Received Firmware Update Get, but no firmware update is in progress
2022-12-03T04:49:21.014Z DRIVER Dropping message with invalid payload
2022-12-03T04:49:21.729Z DRIVER Dropping message with invalid payload
It looks like zwavejs is blitzing my device trying to do a firmware update and being unsuccessful with aborting. Is there any way to kill this? Something like a force quit?
