I have two of the above both running the latest 1.10 firmware and configured exactly the same with binary reporting and added securely. Motion sensor is working great on both but the luminance, humidity and temperature graph differently when I click on each entity as shown below. What controls that?
Are they both powered through USB? I have read somewhere, that the luminance, humidity and temperature will only report in case of significant changes, whereas they will report close to if not real time when USB powered. Might be the difference you experience, if one is USB powered, and the other runs on USB power.
@WonderMoose Thanks for the feedback, much appreciated. Both devices are battery powered so it is a bit weird. I’ve added a history graph as a workaround for now until I figure it out.
Hmmm, back up the bus! Just clicked on it now to give you another screen shot and now I’ve got both graphs! Go figure.
