fminarro
(fgm)
December 15, 2022, 10:24am
1
I can access my hassio instance through the IP 192.168.1.100:8123, within my LAN, and I am trying to configure the reverse proxy to be able to access homeassistant from outside the home.
Homeassistant is installed in Docker, and in a Debian 11 server where I also have CollaboraOffice online and Nextcloud installed, and we access all of this from WLAN because we resolve DNS with NO-IP
I have added the domain that I have created of homeassistant in NO-IP so that the IP can be resolved
Within /etc/apache2/sites-available I have created the file homeassistant.conf
<VirtualHost *:80>
ServerName home-aaaaa.aaa.com
ErrorLog ${APACHE_LOG_DIR}/error.log
CustomLog ${APACHE_LOG_DIR}/access.log combined
</VirtualHost>
then i did
a2ensite home assistant
systemctl reload apache2
I generated the certificates letβs script with certbot --apache and it was successful, and an SSL file called homeassistant-le-ssl.conf was generated
<IfModule mod_ssl.c>
<VirtualHost *:443>
Include /etc/letsencrypt/options-ssl-apache.conf
SSLCertificateFile /etc/letsencrypt/live/home-aaaaa.aaa.com/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/home-aaaaa.aaa.com/privkey.pem
</VirtualHost>
</IfModule>
And I completed it with this code
<VirtualHost *:443>
ProxyPreserveHostOn
Proxy Requests Off
ProxyPass /api/websocket ws://192.168.1.100:8123/api/websocket
ProxyPassReverse /api/websocket wss://192.168.1.100:8123/api/websocket
ProxyPass / http://192.168.1.100:8123/
ProxyPassReverse / http://192.168.1.100:8123/
RewriteEngine on
RewriteCond %{HTTP:Upgrade} websocket [NC]
RewriteRule ^/?(.*) ws://192.168.1.100:8123/$1 [P,L]
<Location "/">
satisfy any
</Location>
<Location "/api">
satisfy any
</Location>
</VirtualHost>
</IfModule>
I try to access the link home-aaaaa.aaa.com and I get the following message: 400: Bad Request
Finally found a working configuration for an apache2 ssl proxy setup. Exactly what I needed. Thanks for posting this!
SSLStaplingCache shmcb:/var/run/apache2/stapling_cache(128000)
<VirtualHost *:1443>
ServerName myhostname.and.the.domain
ErrorLog ${APACHE_LOG_DIR}/haerror.log
CustomLog ${APACHE_LOG_DIR}/haaccess.log combined
ProxyPreserveHost on
<Location /api/websocket>
ProxyPass wss://ip.adress.of.homassistant:8123/api/websocket
ProxyPassReverse wss://ip.adress.of.homassistant:8123/api/websocket
satisfy any
</Location>
<Location />
ProxyPass http://ip.adress.of.homassistant:8123/
ProxyPassReverse http://ip.adress.of.homassistant:8123/
satisfy any
</Location>
RewriteEngine on
RewriteRule ^/?(.*) ws://ip.adress.of.homassistant:8123/$1 [P,L]
SSLUseStapling on
SSLCertificateFile /etc/letsencrypt/live/myhostname.and.the.domain/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/myhostname.and.the.domain/privkey.pem
</VirtualHost>
</IfModule>
rolfinoz
(Rolf)
January 7, 2023, 10:37am
4
Iβm having an issue with an Apache 2 reverse Proxy and HA.
I have no problem getting the the HA login page, but after I login it fails to auth and keeps re-trying.
I had a slightly different config, but I am using the one from above and it behaves exactly the same.
Looking at the developer console I can see that it is failing to post to /auth/token resulting in an uncaught promise.
I have tried adding specific ProxyPass rules for /auth but it makes no difference.
Does anyone know the secret to making HA work with an Apache2 proxy?
Everything working.
The homeassistant-le-ssl.conf file finally looks like this.
<VirtualHost *:443>
ProxyPreserveHostOn
Proxy Requests Off
RewriteEngine on
<Location "/">
satisfy any
</Location>
<Location "/api">
satisfy any
</Location>
</VirtualHost>
</IfModule>
And also inside homeassistant in the configuration.yaml file (in my case) I added the following:
http:
use_x_forwarded_for: true
trusted_proxies:
- 192.168.1.1
- 192.168.1.0/24
