I am new to HA, my current home automation is migrating to HA.
My config is an Intel NUC with Proxmox and hassio runs in one of the virtual machines.
I have an APC UPS in the power supply, I want that, just like I now monitor all with apcupsd, and if the battery voltage is too low I naturally want the nuc to be switched off.
for Proxmox that is no problem, proxmox also switches the virtual machines off etc.
But then I have to run apcupsd in proxmox.
Now I am wondering if I can also run apcupsd in hassio with the same usb connection, or are there other solutions?
Thanks in advance for thinking along and your advice.
You can simply install apcupsd on your Proxmox node and configure it to be reachable over the network. Configure HASS to use that particular host/port and youâre all set.
Iâve been using it like this for about 2 years now and itâs working like a charm
Would you mind one of you @syphernl or @dzjr detail me the solution ?
I have a HassOS+hassio on a VM on a Proxmox and I just bought an APC UPS and I am new to UPS stuff.
I donât know how to âconfigure apcupsd to be reachable over the networkâ and I donât know how to âconfigure HASS to use that particular host/portâ.
I read people telling not to install packages directly on proxmox system by fear to break it 'and indeed I break it when I tried to install some bluetooth drivers by compilation.
Does it mean I donât need to make the USB port of the APC connection passtrough for Home Assistant VM and the addon will get it anyway ?
Normally it wouldnât be a good idea to install stuff directly on the host, I agree. But I consider apcupsd a crucial service for which I make an exception (just like a monitoring daemon for instance). The advantage of running apcupsd on the host itself is that it can gracefully shutdown your system when the battery power is low.
Another advantage is that you wonât need to do any usb passthroughs, simply point your HASS apcupsd configuration to the host and it should work.
I got this message while starting the service in syslog but I assume thatâs not a problem : apcupsd.service: Canât open PID file /run/apcupsd.pid (yet?) after start: No such file or directory
As far as I can tell, I configured apcupsd directly on Proxmox node with NSIP = 0.0.0.0 in the apcpupsd.conf file and wrote in configurations.yaml file as apcups integration page ask and with the proxmox node local IP adress under âapcupsd: host:â.
At this step, I have tried this without ever installing the APC UPS DAEMON unofficial addon - as asked by the integration page - because it seems to me that it would install the full apcupsd service in hassio - which I didnât want (I will let proxmox alone stop the virtual and physical machines).
It seems as if APC informations are correctly monitored in the sensor entities created this way. So no need to install the APCUPS add-on if you only want to have APC reporting in Home Assistant when APS is installed elsewhere. So far so good.
