Apex Chart - Tooltip help
Searched and couldn’t the solution to these two items. Trying to have all series show up on the tooltip as well as removing the xaxis tooltip. Appreciate it!
type: custom:apexcharts-card
apex_config:
  legend:
    show: false
  tooltip:
    enabled: true
    shared: true
    fixed:
      enabled: true
      position: BottomLeft
header:
  show: true
  title: Temperature
  show_states: true
  colorize_states: true
graph_span: 7d
all_series_config:
  stroke_width: 2
  opacity: 1
  show:
    in_brush: true
experimental:
  brush: true
brush:
  selection_span: 24hr
  apex_config:
    yaxis:
      min: 30
      max: 120
yaxis:
  - min: 30
    max: 120
    decimals: 0
    apex_config:
      tickAmount: 9
xaxis:
  tooltip:
    enabled: false
series:
  - entity: sensor.bambu_lab_ams_temp_humidity_sensor_temperature_2
    type: line
    yaxis_id: first
    show:
      extremas: false
      legend_value: false
  - entity: sensor.bambu_lab_p1s_chamber_temp_humidty_sensor_temperature
    type: line
    yaxis_id: second
    show:
      extremas: false
      legend_value: false
  - entity: sensor.garage_temp_humidity_sensor_temperature_3
    type: line
    yaxis_id: third
    show:
      extremas: false
      legend_value: false
  - entity: sensor.bambu_lab_p1s_print_status
    type: area
    curve: stepline
    transform: 'return x=== ''running'' ? 90: 0;'
    opacity: 0.3
    stroke_width: 0
    show:
      in_header: false
      legend_value: false
  - entity: cover.meross_garage_door_opener_garage_door
    type: area
    curve: stepline
    transform: 'return x=== ''open'' ? 90: 0;'
    opacity: 0.4
    stroke_width: 0
    show:
      in_header: false
      legend_value: false
Solved removing the x-axis tooltip, needed to put it under the apex_config. Still can’t figure out how to have all series show up in the tooltip though.
apex_config:
  legend:
    show: false
  tooltip:
    enabled: true
    shared: true
    fixed:
      enabled: true
  xaxis:
    tooltip:
      enabled: false
header:
  show: true
  title: Temperature
  show_states: true
graph_span: 7d
all_series_config:
  stroke_width: 2
  opacity: 1
  show:
    in_brush: true
experimental:
  brush: true
brush:
  apex_config:
    yaxis:
      min: 30
      max: 120
yaxis:
  - min: 30
    max: 120
    decimals: 0
    apex_config:
      tickAmount: 9
series:
    type: line
    yaxis_id: first
    show:
      extremas: false
      legend_value: false
    type: line
    yaxis_id: second
    show:
      extremas: false
      legend_value: false
    type: line
    yaxis_id: third
    show:
      extremas: false
      legend_value: false
    type: area
    curve: stepline
    opacity: 0.3
    stroke_width: 0
    show:
      in_header: false
      legend_value: false
    type: area
    curve: stepline
    opacity: 0.4
    stroke_width: 0
    show:
      in_header: false
      legend_value: false
Did you find a way ?
I have seen one in the apex documentation burried quite deep
Do you see the custom tooltip example Link below that BLUE CUSTOM FUNCTION box?
Click there and you will get this completely indiviual one, but I have no clue if it is possible to do this inside apex Homeassitant HACS integration or not.
But here is your starting point from the first screenshot
I would simply like time and date - followed by the series name and value and an option to show all values of 1 time below each other in a box in the same order as they appear in the legend.
For if you are still having the same issue:
I also struggled with showing all series for the tooltip for quite some time. What finally solved it is grouping on the x-axis. The series most likely have an irregular time interval, thus do not share the same x axis points. (See the note below the example: tooltip – ApexCharts.js)
This can be fixed with the group_by function. Here is my example (only the necessary config):
apex_config:
  xaxis:
    tooltip:
      enabled: false # Disable the x-axis tooltip
  tooltip:
    shared: true # Share tooltip with all series
    intersect: false # Also show tooltip when not hovering exactly on a point
    fixed:
      enabled: true
      position: topLeft
    x:
      format: HH:mm (dd MMM) #Cleaner time formatting
      show: true
all_series_config:
  group_by: # Fix irregular time for the shared tooltip to work
    duration: 5min
    func: avg
    fill: last
Make sure to set the duration accordingly. Good luck!
Amazing! Thanks so much, this solved it!
edit: for some reason it randomly works. It seems to sometimes reverts back to only showing one data point
edit2: Seems like reducing the duration to 1hour rather than 5 minutes solved it! Resolution mightve been too high at 5 minutes.
Glad to hear!
And indeed resolution is key. If there are data points missing in the duration (eg, 5 minutes), it unfortunately reverts back for the whole set. It’s a bit of trial and error.
