Hi all,
I’m new here, so still learning the customs on this forum.
I have an issue with (the fantastic add-on!) Apex charts. In card configuration, some of the sensors are not found, resulting in the error message “Entity not available: sensor.aqara_temp_hum_slaapkamer_kimly_onno_temperatuur”.
If I call the sensor in the HA native chart card, it does show correctly.
I bought 4 identical Aqara sensors, only this one doesn’t show.
I’ll try add some pictures below.
Not urgent but nice to know:
- I’d like to have the y-axis metrics on each side (instead of both left)
- on my phone the graph doesn’t fit. Did anyone find an option to reduce the graph’s width?
The bathroom sensors do work, For this I use the following code:
type: custom:apexcharts-card
graph_span: 72h
yaxis:
- id: _temperatuur
decimals: 0
apex_config:
tickAmount: 6
- id: _luchtvochtigheid
decimals: 0
apex_config:
tickAmount: 4
apex_config:
chart:
zoom:
type: x
enabled: true
autoScaleYaxis: false
dropShadow:
enabled: true
toolbar:
show: true
autoSelected: zoom
xaxis.type: datetime
height: 250px
color_list:
- '#E60000'
- '#0096C7'
all_series_config:
stroke_width: 3
opacity: 0.3
type: area
header:
show: true
title: BADKAMER (slaapkamer entiteiten zijn verdwenen??)
show_states: true
colorize_states: true
series:
- entity: sensor.aqara_temp_hum_badkamer_temperatuur
yaxis_id: _temperatuur
data_generator: ''
curve: smooth
- entity: sensor.aqara_temp_hum_badkamer_luchtvochtigheid
yaxis_id: _luchtvochtigheid
data_generator: ''
curve: smooth
invert: false
Ouch: solved it. I made a typo creating the bedroom sensors, thats why it doesn’t show up after “sensor.aqara_temp_hum_…”. My bad!
The width-issue on a mobile device is solved by reducing the height: that way the width is also reduced.
Having the y-axis-metrics on both sides is actually quite easy after some googling: ad “opposite: true” to yaxis_id. This man is very happy!
graph_span: 72h
yaxis:
- id: _temperatuur
decimals: 0
opposite: true
apex_config:
tickAmount: 6
decimals: 0
apex_config:
tickAmount: 4
apex_config:
chart:
zoom:
type: x
enabled: true
dropShadow:
enabled: true
toolbar:
show: true
autoSelected: zoom
height: 150px
color_list:
- '#E60000'
- '#0096C7'
all_series_config:
stroke_width: 3
opacity: 0.3
type: area
header:
show: true
title: Slaapkamer
show_states: true
series:
- entity: sensor.aqara_temp_lum_slaapkamer_kimly_onno_temperatuur
data_generator: ''
curve: smooth
- entity: sensor.aqara_temp_lum_slaapkamer_kimly_onno_luchtvochtigheid
data_generator: ''
curve: smooth
invert: false
type or paste code here
