baz123
(Brian)
November 21, 2023, 1:24pm
1
Continuing the discussion from ApexCharts card - A highly customizable graph card :
Went through the linked thread looking for this. Eventually found the contribution above
Thought I’d break it out so it might be more easily found for others. This is for a chart for Octopus Agile (etc) prices using the Octopus HACS integration.
Thanks @ppmt for the pointer. It was tricky to find! I adjusted it to suit what I wanted, but that is easy enough with this card!
type: custom:apexcharts-card
experimental:
color_threshold: true
header:
show: true
show_states: true
colorize_states: true
title: Today's Agile Rates
stacked: false
graph_span: 24h
span:
start: hour
now:
show: true
label: Now
color: black
yaxis:
- min: ~0
max: ~35
decimals: 1
series:
- entity: sensor.octopus_energy_electricity_xxxxxxxxxx_current_rate
type: column
color: gray
opacity: 1
stroke_width: 0
unit: p/Kw
show:
in_header: false
legend_value: false
header_color_threshold: true
color_threshold:
- value: -100
color: cyan
- value: 0
color: green
- value: 20
color: orange
- value: 30
color: red
- value: 40
color: purple
data_generator: |
return entity.attributes.all_rates.map((entry) => {
return [new Date(entry.valid_from), entry.value_inc_vat];
Of course that will break with the updated Agile integration which changes where the values are stored.
If you use the newly updated code, duplicate the series filed with the next day rates and then you will get the full 24 hours.
header:
show: true
title: Electricity Future Price
series:
- entity: >-
event.octopus_energy_electricity_METER_current_day_rates
offset: '-15m'
type: column
unit: p/kWh
float_precision: 3
stroke_width: -4
extend_to: end
color_threshold:
- value: 0
color: lightblue
- value: 0.1
color: lightgreen
- value: 10
color: green
- value: 25
color: yellow
- value: 40
color: red
- value: 60
color: pink
data_generator: |
return entity.attributes.rates.map((entry) => {
return [new Date(entry.start), entry.value_inc_vat*100];
- entity: event.octopus_energy_electricity_METER_next_day_rates
offset: '-15m'
type: column
unit: p/kWh
float_precision: 3
stroke_width: -4
extend_to: end
color_threshold:
- value: 0
color: lightblue
- value: 0.1
color: lightgreen
- value: 10
color: green
- value: 25
color: yellow
- value: 40
color: red
- value: 60
color: pink
data_generator: |
now:
show: true
label: now
yaxis:
- min: ~0
max: ~40
decimals: 0
align_to: 5
graph_span: 14h
span:
start: minute
offset: '-1h'
experimental:
baz123
(Brian)
November 23, 2023, 6:57am
3
Yes, I noticed that so didn’t upgrade the integration!
I’ll update the post once I update both which will be easier with that, so many thanks
krikey
(krikey)
January 26, 2024, 3:34pm
4
Im new to HA but am struggling with both examples above.
In example 1 I swap out the sensor for my own but the graph doesnt get populated.
In example 2 I see that its using events but I dont have an event set up, could you perhaps elaborate on how to do this?
This is great - saved me loads of effort!
Worth noting, that all the duplication can be removed by use of “all_series_config”:
header:
show: true
series:
- entity: >-
now:
show: true
label: now
yaxis:
- min: ~0
max: ~40
decimals: 0
align_to: 5
graph_span: 14h
span:
start: minute
offset: '-1h'
experimental:
all_series_config:
offset: '-15m'
type: column
unit: p/kWh
float_precision: 3
stroke_width: -4
extend_to: end
color_threshold:
- value: 0
color: lightblue
- value: 0.1
color: lightgreen
- value: 10
color: green
- value: 15
color: yellow
- value: 20
color: red
- value: 50
color: pink
data_generator: |
