Servus,
I real love this - thx to all who contribute to make this possible .
After about 1 month of HA and some weeks playing arround like a nerd, i think i have the first chart to share. Also because i have looked arround and have not found something similar and ready ( its never ) to start with.
I have a sungrow inverter and they have some rather nice Mobile App.
So i tried to copy a statistics part ( sort of ) .
This is the result
( 21.12 was the best PV Day in December - and the shortest day … )
So what is needed .
A Counter
2 Buttons (to increase and decrease the counter )
a Card which shows the date ( now - counter )
a apex chart sourounded by a template to look for changed counter
A lot of time and look arround for the simplest stuff why it is not working gg
Here is the complete code.
type: vertical-stack
cards:
- type: horizontal-stack
cards:
- show_name: false
show_icon: true
type: custom:button-card
entity: input_number.daily_offset
show_state: false
tap_action:
action: perform-action
perform_action: counter.decrement
entity_id: counter.dail_offset_value
data: {}
hold_action:
action: none
icon: mdi:less-than
triggers_update: all
primary: >-
{% set offset_val = states('counter.dail_offset_value') | int(0) %}
{% set offset = now() - timedelta( days = offset_val, hours = 0,
minutes = 00 ) %} {{
as_datetime(offset).strftime('%d/%m/%Y')
secondary: ""
multiline_secondary: false
tap_action:
action: none
hold_action:
action: none
double_tap_action:
action: none
layout: vertical
fill_container: false
- show_name: false
show_icon: true
show_state: false
tap_action:
perform_action: counter.increment
data: {}
hold_action:
action: none
icon: mdi:greater-than
- type: custom:config-template-card
card:
type: custom:apexcharts-card
apex_config:
tooltip:
shared: true
intersect: false
x:
format: HH:00 - HH:59
show: true
legend:
show: false
chart:
height: 250px
grid:
show: true
strokeDashArray: 0
borderColor: "#444444"
position: back
xaxis:
lines:
show: true
yaxis:
lines:
show: true
yaxis:
forceNiceScale: true
tooltip:
enabled: false
xaxis:
tooltip:
enabled: false
type: datetime
axisTicks:
show: true
tickAmount: 6
labels:
format: HH:mm
lines:
show: true
fill:
type: gradient
gradient:
type: vertical
shade: dark
stops:
- 0
- 90
opacityFrom:
- 1
- 0.2
opacityTo:
- 0.2
- 1
update_interval: 30m
span:
start: day
graph_span: 24h
header:
show: true
show_states: true
colorize_states: true
series:
- entity: sensor.battery_charging_power
color: green
invert: false
group_by:
func: last
duration: 10m
fill: last
offset: ${'-' + states['counter.dail_offset_value'].state +'d'}
type: area
opacity: 0.6
stroke_width: 2
show:
in_header: false
offset_in_name: false
- entity: sensor.battery_discharging_power
color: red
invert: true
group_by:
func: last
duration: 10m
fill: last
type: area
opacity: 0.6
stroke_width: 1
show:
in_header: false
- entity: sensor.total_dc_power
color: orange
name: PV Generiert
invert: false
group_by:
func: last
duration: 10m
fill: last
type: area
opacity: 0.6
stroke_width: 1
show:
in_header: false
- entity: sensor.daily_battery_charge
color: green
invert: false
group_by:
func: last
duration: 24h
fill: last
opacity: 0.6
stroke_width: 1
show:
in_chart: false
in_header: true
- entity: sensor.daily_pv_generation
color: orange
name: PV Generiert
invert: false
group_by:
func: last
duration: 24h
fill: last
opacity: 0.6
stroke_width: 1
show:
in_chart: false
in_header: true
- entity: sensor.daily_battery_discharge
color: red
invert: false
group_by:
func: last
duration: 24h
fill: last
opacity: 0.6
stroke_width: 1
show:
in_chart: false
in_header: true
entities:
- counter.dail_offset_value
My (in)complete Dashboard for Solar looks like this atm.
And it would be great if someone could use it, or even better make some improvements !
Have a great time in HA ,
Best regards, Dietmar
Have not checked a whole code.
Just 1 remark:
if you place a graph into config-template-card (CTC) and DO NOT declare sensors as “monitored” (i.e. in the “entities” option of CTC) - then the graph will not be updated real-time on every change of these sensors (may be not critical for rarely updating sensors). From other side, if you DO declare them - the whole graph card will be redrawn on every change (not just a curve; and may be even with changing a card’s height which causes a whole view’s flickering). Pro vs contra.
Hi ,
Thx for your reply.
I hope i do understand, but the template used is history per day only . So i ONLY want to refresh the chart if the count(date) changes, and NOT if an current entity changes. I had the chart entity in the “entries” of the template - and if new Data was incoming in refreshed - not need .
EDIT: I do work with offset Data only - so they do not change at all.
Servus,
I have made 2 Version of this Chart.
Make your counter start with 0 - it will show the current day …
I really shows that with PV Data the Statistics data are not very good to plot . I needed to use “mean” . The other types did something complete wrong ( more Battery KW load than from the panels - whichi is simple not possible in my case )
Left:
- Working with raw data
- More accurate and up-2-date on current summary on the header ( offset = 0 , current date )
- Scroll in “History” only as long as retention goes (10 days per default )
Right:
- Working with Statistics Data
- Not very accurtate and hours Late on the current day summary of the header
- Scroll in History as you have data
I think it is not possible to have both advantages in 1 chart .
I am still a nyb in HA - so i will keep both of them for now and will look into increasing the retention in the recorder , because i do not like the history graph so much . Need to look how granular this could be set …
Code “left”
cards:
cards:
- show_name: false
show_icon: true
show_state: false
tap_action:
data: {}
hold_action:
action: none
icon: mdi:less-than
primary: >-
secondary: ""
tap_action:
action: none
hold_action:
action: none
double_tap_action:
action: none
layout: vertical
- show_name: false
show_icon: true
show_state: false
tap_action:
data: {}
hold_action:
action: none
card:
now:
show: false
apex_config:
tooltip:
shared: true
intersect: false
x:
show: true
legend:
show: false
chart:
height: 310px
grid:
show: true
strokeDashArray: 0
position: back
xaxis:
lines:
show: true
yaxis:
lines:
show: true
yaxis:
tooltip:
enabled: false
xaxis:
tooltip:
enabled: false
type: datetime
axisTicks:
show: true
tickAmount: 6
labels:
format: HH:mm
lines:
show: true
fill:
type: gradient
gradient:
type: vertical
shade: dark
stops:
- 0
- 90
opacityFrom:
- 1
- 0.2
opacityTo:
- 0.2
- 1
update_interval: 10m
span:
start: day
graph_span: 24h
header:
show: true
show_states: true
series:
color: green
invert: false
group_by:
func: avg
duration: 5m
fill: last
extend_to: now
type: area
opacity: 0.6
stroke_width: 2
show:
in_header: false
color: red
name: Batterie Ent Laden
invert: true
group_by:
func: avg
duration: 5m
fill: last
extend_to: now
type: area
opacity: 0.6
stroke_width: 1
show:
in_header: false
color: orange
invert: false
group_by:
func: avg
duration: 5m
fill: last
extend_to: now
type: area
opacity: 0.6
stroke_width: 1
show:
in_header: false
color: green
invert: false
group_by:
func: last
duration: 24h
fill: last
extend_to: now
opacity: 0.6
stroke_width: 1
show:
in_chart: false
in_header: true
color: red
invert: false
group_by:
func: last
duration: 24h
fill: last
extend_to: now
opacity: 0.6
stroke_width: 1
show:
in_chart: false
in_header: true
color: orange
name: PV Generiert
invert: false
group_by:
func: last
duration: 24h
fill: last
extend_to: now
opacity: 0.6
stroke_width: 1
show:
in_chart: false
in_header: true
entities:
2nd:
cards:
cards:
- show_name: false
show_icon: true
show_state: false
tap_action:
data: {}
hold_action:
action: none
icon: mdi:less-than
primary: >-
secondary: ""
tap_action:
action: none
hold_action:
action: none
double_tap_action:
action: none
layout: vertical
- show_name: false
show_icon: true
show_state: false
tap_action:
data: {}
hold_action:
action: none
card:
now:
show: false
apex_config:
tooltip:
shared: true
intersect: false
x:
show: true
legend:
show: false
chart:
height: 310px
grid:
show: true
strokeDashArray: 0
position: back
xaxis:
lines:
show: true
yaxis:
lines:
show: true
yaxis:
tooltip:
enabled: false
xaxis:
tooltip:
enabled: false
type: datetime
axisTicks:
show: true
tickAmount: 6
labels:
format: HH:mm
lines:
show: true
fill:
type: gradient
gradient:
type: vertical
shade: dark
stops:
- 0
- 90
opacityFrom:
- 1
- 0.2
opacityTo:
- 0.2
- 1
span:
start: day
graph_span: 24h
header:
show: true
show_states: true
series:
color: green
invert: false
statistics:
type: mean
period: hour
align: start
extend_to: now
type: area
opacity: 0.6
stroke_width: 2
show:
in_header: false
color: red
invert: true
statistics:
type: mean
period: hour
align: start
extend_to: now
type: area
opacity: 0.6
stroke_width: 1
show:
in_header: false
color: orange
invert: false
statistics:
type: mean
period: hour
align: start
extend_to: now
type: area
opacity: 0.6
stroke_width: 1
show:
in_header: false
color: green
invert: false
statistics:
type: state
period: hour
align: end
extend_to: now
opacity: 0.6
stroke_width: 1
show:
in_chart: false
in_header: true
color: red
invert: false
statistics:
type: state
period: hour
align: end
extend_to: now
opacity: 0.6
stroke_width: 1
show:
in_chart: false
in_header: true
color: orange
name: PV Generiert
invert: false
statistics:
type: state
period: hour
align: end
extend_to: now
opacity: 0.6
stroke_width: 1
show:
in_chart: false
in_header: true
entities:
Servus,
It seems that i have changed some settings via MODBUS (ups) , and therefore my Inverter was degraded - my “Solarteur” fixxed it . But to get the idea that something is wrong HA helped a lot
. So i could just advise to show the Inverter State , my updated Dashboad:
Have a great time in HA .
Made some improvements.
Used other horizonzal / vertical stacks and card-mod to remove the Borders.
But now it is pure yaml only, but it looks much better .
This is the yaml Code for the middle Part with the Buttons for history scrolling
type: custom:stack-in-card
title: null
mode: vertical
card_mod:
style: |
ha-card { border: none; box-shadow: none; }
cards:
- type: custom:stack-in-card
mode: horizontal
card_mod:
style: |
cards:
- type: gauge
entity: sensor.battery_level
card_mod:
style: |
min: 0
max: 100
severity:
green: 70
yellow: 40
red: 20
needle: true
tap_action:
action: none
mode: horizontal
card_mod:
style: |
cards:
- show_name: false
show_icon: true
card_mod:
style: |
show_state: false
tap_action:
data: {}
hold_action:
action: none
icon: mdi:less-than
primary: >-
secondary: ""
card_mod:
style: |
tap_action:
action: none
hold_action:
action: none
double_tap_action:
action: none
layout: vertical
- show_name: false
show_icon: true
card_mod:
style: |
show_state: false
tap_action:
data: {}
hold_action:
action: none
card:
card_mod:
style: |
now:
show: false
apex_config:
tooltip:
shared: true
intersect: false
x:
show: true
legend:
show: false
chart:
height: 305px
grid:
show: true
strokeDashArray: 0
position: back
xaxis:
lines:
show: true
yaxis:
lines:
show: true
yaxis:
tooltip:
enabled: false
xaxis:
tooltip:
enabled: false
type: datetime
axisTicks:
show: true
tickAmount: 6
labels:
format: HH:mm
lines:
show: true
fill:
type: gradient
gradient:
type: vertical
shade: dark
stops:
- 0
- 90
opacityFrom:
- 1
- 0.2
opacityTo:
- 0.2
- 1
span:
start: day
graph_span: 24h
header:
show: true
show_states: true
series:
color: green
invert: false
group_by:
func: last
duration: 10m
fill: last
extend_to: now
type: area
opacity: 0.6
stroke_width: 2
show:
in_header: false
color: red
invert: true
group_by:
func: last
duration: 10m
fill: last
extend_to: now
type: area
opacity: 0.6
stroke_width: 1
show:
in_header: false
color: orange
name: PV Generiert
invert: false
group_by:
func: last
duration: 10m
fill: last
extend_to: now
type: area
opacity: 0.6
stroke_width: 1
show:
in_header: false
color: green
invert: false
group_by:
func: last
duration: 24h
fill: last
extend_to: now
opacity: 0.6
stroke_width: 1
show:
in_chart: false
in_header: true
color: red
invert: false
group_by:
func: last
duration: 24h
fill: last
extend_to: now
opacity: 0.6
stroke_width: 1
show:
in_chart: false
in_header: true
color: orange
name: PV Generiert
invert: false
group_by:
func: last
duration: 24h
fill: last
extend_to: now
opacity: 0.6
stroke_width: 1
show:
in_chart: false
in_header: true
entities:
Have a great time in HA,
