Chykan
(Hunter)
June 13, 2024, 3:50pm
3564
I managed to fix the graphs:
See the link below for the full code.
I have had Home Assistant for a bit over two years now and there does not seem to be a way to make an accurate (Monthly) rain graph, from the data given from my Netamo Rain Sensor.
I have also found very few posts directly relating, to what you would think being a simple task to create a rain graph in Home Assistant. I may also be a Luddite.
I have put this post together to capture the code I have used for any other Newbies that need a template to start with but would also like any advice you …
@MelleD following the above, yes you can show the minimum value in the header, you will need to put a second series in your chart and hide it. The value can then be shown in the header.
