ApexCharts card - A highly customizable graph card
I installed the integration to test:
Config:
          - type: custom:apexcharts-card
            header:
              show: true
              title: Irradiance
              show_states: true
              colorize_states: true
            graph_span: 7d
            span:
              start: hour
            series:
              - entity: sensor.sun_irradiance_luedinghausen_broch
                data_generator: |
                  return entity.attributes.data.map(
                  (item) => {
                    return [new Date(item.datetime).getTime(), item.value];
The recorder is probably not enabled for your entity and that is why it probably doesn’t work. The card only works for recorder-enabled entities (I could probably fix that for data_generator, but for now that’s how it is :slight_smile: )
