Just starting to use HA and have it running on its own OS on a raspberry pi.
I want to install apexcharts, I cannot understand how to add the resources line either to lovelace (not familiar yet either what lovelace is and I can’t find any reference in the GUI, maybe it was incorporated at a certain release and no longer visible) So I wanted to try the steps via the gui
Blockquote>
Else, if you prefer the graphical editor, use the menu to add the resource:
Make sure, advanced mode is enabled in your user profile (click on your user name to get there)
Navigate to Configuration → Lovelace Dashboards → Resources Tab. Hit orange (+) icon
Enter URL /local/apexcharts-card.js and select type “JavaScript Module”.
Restart Home Assistant.
Problem here is step 2: I dont have a “configuration” in my HA just a section called “Settings” There is no lovelace dashboards in their though hence I dont see resources either and cannot complete
Thanks for helping a noob out here and to also include me in being able to use these cool graphs
Something seemed to have gone wrong during the installation from HACS, however a reinstall fixed it.
Were it not though that I couldnt complete the instructions in the installation description, so not sure if this is due to the HA version or maybe they need an update?
the different energy series are using sensors which return null when their value is zero, and apexcharts ignores them for drawing the series when they are null
I have automation which sets the active tariff (off-peak, shoulder, peak) into an input_helper at the correct times, and I have 1 of 3 conditional cards displaying depending on which tariff is active, so it always shows the current tariff’s draw and ignores the others
(Solar panels are zero because we are in the middle of an upgrade and they are disconnected)
Looking for a little help here with an annoying (and probably easy to fix!) issue that I am having with my charts. I will paste the code below… but the problem is that the Gravity line isn’t showing the correct data and updating (I can look at another chart of that variable and it is updating properly - steadily dropping from 1.045 to current 1.039). There is also no chart line for the battery or the thermTemp… can anyone spot what is wrong with this? I’m trying to get the 2 temp sensors using the same y axis, the fridge and heaters are just boolean step charts for on/off
The naming is correct in the code below (including the batterry typo!).
I suspect a very small change could fix this, but I cant work out what!
OK, I am struggling with what I should use to even attempt to display this. As I have some experience with Apex I was thinking maybe, but I am not sure.
Goal: Displaying Pokemon Stats for the standard categories. Here’s a picture of what would be “nice” from Pokedex:
Since this data is driven in something I have built for randomly selecting a Pokemon, the data of course changes. All the values and categories are loaded into a sensor already. In fact I can display this data with a simple Markdown like this:
type: markdown
content: |-
## Stats
{% for st in state_attr("sensor.random_pokemon","stats") -%}
{{ st.stat.name }} {{ st.base_stat }}
{% endfor %}
Which looks like this:
SO I have no issues getting the name and value to plot. Apex seem though to be more of a time-based plot and not a simple one time value. I have no care about “time” as this randomly changes during the day as Pokemon are changed. There is no “history” only a single point in time and a value and that single point has names not time (i.e. 6 series … or 7 if you count the sum). Note that the sensor has many, many things only one of which is the “stats” as an attribute and those vakue are buring deeper as you can see in the Markdown template to get to the values/names. It is not a simple single attribute for each nor would I want to create more sensors based on the master sensor as the data is there.
So is Apex charts good for this? Or something else? Does anyone have a starting point for me that can help me?
You can see the discussion here about creating the original sensor:
I would also note that I am not tied to a “bar” view, maybe a circular chart is better.
Simple entities. I need those to be an attribute hanging off a sensor that needs jinja or JS to get the value and name. But maybe it is a decent stating point
Maybe I can attempt to wrap it in a custom templatable entry or? Is “series” in that case templatable is the question.
What does it need?
!) no one should assume that those stats are in the order, it should be able to be written as “for each stat” (maybe I use multiple entity card??"
2) The max should probably be like 110% greater than the largest value (maybe I use jinja custom template card?)
3) The display when mousing over the series should NOT display the percent, it should display the value (can’t believe this does not exist, I just must be missing something)
I use mutliple yaxis (2) and use 6 series. The first one uses the first yaxis and the other 5 series uses the second yaxis.
Everything fine, but if hide the first series of the five ones, the yaxis is hidden also. The reminaing 4 series don´t have a yaxis:
I expect its because the radial bar card expects values from 0-100%. This is from the Apex Charts docs:
Keep in mind that the value of these charts must be in percentage (between 0 and 100). You can still display the original value in labels, but the data presented in series must always be in a percentage.
What you really need is the bar chart I think but it isn’t currently available. Edit: here is the actual Apex Charts code that will drop the %. You will have to work out how to put it into the card syntax:
plotOptions: {
radialBar: {
dataLabels: {
total: {
show: true,
label: 'TOTAL',
formatter: function (w) {
return w.globals.seriesTotals.reduce((a, b) => {
return a + b
}, 0) / w.globals.series.length
value: {
show: true,
fontSize: '14px',
formatter: function (val) {
return val
