ApexCharts card - A highly customizable graph card
Here is the same curve in both “apexcharts-card” and “history-graph”. It’s possible to see two differences. The part of the curve during the 11th of march with the minimum value is increasing slightly in “apexcharts-card” but not in “history-graph”, and during the 12th of march is the phenomena is easy to spot.
I guess (without having any detailed knowledge of the data format) that when a sensor is reporting the same value several times the value is stored once with with a start time and an end time to reduce storage and that “apexcharts-card” might miss the end time. That could be an explanation.
Super, now that’s a very clear picture of the problem.
There was a recent change to how the database stored data.
It now only stores values when changed, so you are correct in your thinking.
There is a fill parameter in the series options, fill_raw.
Setting this to zero might solve the problem.
Note, the parameter goes before any group options.
Seems that I found bug where line is put in wrong place compared to both yaxis scales. Check out gray line with values 6.5 and 5.2 and it’s placed way to high. It’s placed correctly on the brush bellow.
Here is pic:
Config:
type: custom:apexcharts-card
header:
  show: true
  title: Average Outside Temperature vs Pellet Usage
  show_states: false
  colorize_states: true
update_interval: 1h
yaxis:
  - id: temp
    show: true
    opposite: true
    decimals: 0
  - id: weight
    show: true
    opposite: false
    decimals: 0
span:
  start: isoWeek
  offset: '-26day'
graph_span: 30d
apex_config:
  tooltip:
    x:
      format: MMMM dd, yyyy.
  xaxis:
    tooltip:
      enabled: false
  stroke:
    dashArray:
      - 0
      - 0
      - 3
      - 5
      - 7
all_series_config:
  stroke_width: 2
  show:
    in_brush: true
experimental:
  brush: true
brush:
  selection_span: 7d
series:
  - entity: sensor.outside_home_temperature_average
    type: line
    yaxis_id: temp
    color: '#eb7757'
    opacity: 1
    extend_to: false
    group_by:
      func: last
      duration: 1d
    show:
      extremas: true
  - entity: sensor.pellet_consumption_today
    type: column
    yaxis_id: weight
    extend_to: false
    group_by:
      func: last
      duration: 1d
    color: '#a9d950'
    opacity: 1
  - entity: sensor.average_temperature_tomorrow
    type: line
    yaxis_id: temp
    extend_to: false
    color: '#e6a037'
    offset: '-1day'
    opacity: 1
    show:
      offset_in_name: false
    group_by:
      func: last
      duration: 1d
  - entity: sensor.average_temperature_today_plus_2
    type: line
    yaxis_id: temp
    extend_to: false
    color: '#e6dc22'
    offset: '-2day'
    opacity: 1
    show:
    group_by:
      func: last
      duration: 1d
  - entity: sensor.average_temperature_today_plus_3
    type: line
    yaxis_id: temp
    color: '#999999'
    offset: '-3day'
    opacity: 1
    show:
    group_by:
      func: last
      duration: 1d
Also I have question related to these forecast lines. Currently they start at good point because they are recently created but is there a way to define starting date for specific entity inside series?
Was trying to use data_generator but can’t find a way to loop over entities instead of attributes.
i am trying to execute a transform command using config-template-card. The variable maxp contains a number from 10 to 50, transform also works if I insert the value directly. But not as a variable ${maxp}. What am I doing wrong?
  series:
    - entity: sensor.processor_use
      transform: "return Math.min(${maxp}, x);"
Wondering if someone can help, as I can’t seem to get the cosmetics right on this one.
I have the following card, that will show monthly data over 12 months. However as you can see in the below screenshot, the x-axis is grouped in the center of the card, rather than being spread across the full width of the card.
I don’t seem to have this issue with other cards I have created.
Any thoughts on anything I could try? I seem to have been going in circles without much success.
Thanks for any help or suggestions!
header:
  show: true
  title: Monthly Energy Savings
  show_states: true
  floating: false
  disable_actions: true
graph_span: 12month
span:
  end: month
show:
  last_updated: true
stacked: true
apex_config:
  chart:
    height: 295
  stroke:
    show: false
  legend:
    show: false
yaxis:
  - min: 0
    max: ~10
    decimals: 0
    apex_config:
      tickAmount: 4
series:
  - entity: sensor.battery_savings_monthly
    name: Battery So Far This Month
    color: '#5692A9'
    type: column
    float_precision: 2
    statistics:
      type: state
      period: month
      align: end
  - entity: sensor.solar_savings_monthly
    name: Solar So Far This Month
    color: '#F29C38'
    type: column
    float_precision: 2
    statistics:
      type: state
      period: month
      align: end
  - entity: sensor.battery_solar_savings_monthly
    name: Total So Far This Month
    color: '#598EBE'
    type: line
    float_precision: 2
    show:
      datalabels: true
    statistics:
      type: state
      period: month
      align: end
ist it possible to show the graph only until the current time?
…I tried some configuration with span, start and and…but finally I didn’t find a solution for me.
i want to show the graph from the current day until the current time.
thanks in advance
extend_to: now
perfect, thank you
Would love to see your code for this :slight_smile:
Did you end up getting anywhere with this…im also trying to alter the marker
I now dispense with the variable with config-template-card, although the function would sometimes be interesting in order not only to set span variably. Nevertheless, I am very pleased with the CPU chart. To get a better resolution, I have set the maximum here to 30%, of course the transform-command can also be removed:
update_interval: 30sec
experimental:
  color_threshold: true
now:
  show: true
graph_span: 48h
style:
  title: ''
  top: 7%
  left: 75%
header:
  title: CPU über 24h (max=30)
  show: true
series:
    transform: return Math.min(30, x);
    color_threshold:
      - value: -10
        color: green
      - value: 0
        color: green
      - value: 15
        color: yellow
      - value: 20
        color: orange
      - value: 22
    color: orangered
    type: line
    statistics:
      period: 5minute
    stroke_width: 1
    show:
      extremas: true
Is it possible to change the title of the card using templates but without using config-template-card?
Hi @ThomasM - how did you get the date to show on the xaxis at the 12:00am tick?
Has anyone had any success setting tickAmount with separate y-axes? I have the following, but can’t find a way to incorporate tickAmounts that works.
graph_span: 24h
apex_config:
  stroke:
    width: 2
    curve: smooth
  xaxis:
    tooltip:
      enabled: false
  annotations:
    yaxis:
      - 'y': '1.14'
        borderColor: orange
header:
  show: false
series:
  - entity: sensor.pillings_lock_water_level_stage
    yaxis_id: level
  - entity: sensor.pillings_lock_flow_logged
    yaxis_id: flow
yaxis:
  - id: flow
    show: true
    min: 0
    max: 60
    decimals: 0
  - id: level
    show: true
    min: 0.8
    max: 1.6
    decimals: 2
    opposite: true
If I put it under the yaxis section of apex_config then nothing happens. If I put it under the individual yaxis ids further down, then HA complains that:
/// apexcharts-card version 2.0.2 /// value.yaxis[0] is not a ChartCardYAxisExternal; value.yaxis[0].tickAmount is extraneous
I’ve had a look at the card docs, this thread, and the ApexCharts.js documentation, but can’t figure out what’s wrong. Thanks!
Where did you get the idea of defining Y outside apex_config: ?
PS: I don’t see ( in you code ) where you “tried” to put “tickamount”, And i don’t see a Yaxis-section in your apex-config
This is the correct method if you are using the HA implementation of yaxis.
yaxis:
  - id: flow
    show: true
    min: 0
    max: 60
    decimals: 0
    apex_config:
      show: true
      showAlways: true
      showForNullSeries: true
      tickAmount: 6
      labels:
Ah, perfect - thank you!
hmmmm i have been wondering few times, seeing some peoples code, so your saying there is 2 “official” ways of making it work in HA ( the correct way(ha-implementation) and apexchart-config-way) ?
I find it easier to define most config under “apex-config” and “all_series_config:”
Both methods are correct. It’s the user’s choice which method they use.
There’s also a third way, and that is to just use ApexCharts and use the Webpage card to access a localhost html document. For this you would need to be running HA in a docker enviroment and have knowledge of the Apache HTTP Server (localhost), html and javascript.
As you can see from the image below, it’s dry with no rain forecasted for the next 2 hours !!
Did anyone encounter these errors?
Error: <svg> attribute height: Expected length, "NaN" and Error: <path> attribute d: Expected number, "M 0 NaN".
When _windowResize is called. Somewhere the script tries to find a dimension that returns NaN.
– Ingrid
