ApexCharts card - A highly customizable graph card
I have a donut card that isn’t working as expected on safari:
However on chrome it looks like this:
Another one on safari
Anyone have any ideas?
Browsers still have various rendering of CSS , but maybe there is something in your code also … so … who knows ?
When using two y-axis for a line / area chart (i.e. primary and secondary axis), is there a simple way to ensure that the 0 values for both axis is on the same horizontal line?
One way to do this I guess would be to specify the minimum and maximum values of each axis, however, the values of both the primary and secondary axis can vary quite a bit from day to day so I’d rather not specify the min and max if I can avoid this (as doing so can mean that on ‘low’ days the graph will look very small in comparison to the maximum values set).
here is the code:
type: custom:apexcharts-card
chart_type: donut
series:
  - entity: sensor.boiler_supply_3_1d
  - entity: sensor.downstairs_lights_8_1d
  - entity: sensor.downstairs_sockets_2_1d
  - entity: sensor.fridge_and_garage_7_1d
    name: Fridge & Garage
  - entity: sensor.kitchen_1_1d
  - entity: sensor.kitchen_lighting_and_understair_lighting_5_1d
    name: Kitchen + Understair Lighting
  - entity: sensor.ring_kitchen_and_dining_9_1d
  - entity: sensor.upstairs_lights_4_1d
  - entity: sensor.upstairs_sockets_6_1d
  - entity: sensor.washer_dryer_10_1d
yep, works fine in FF and EDGE (out of the box ) , but i assume you already knew that … And very simple “graph/donut”, so hardly a CSS/script issue, And i got all 10 entities.
So i suggest you start with “flush” your caches, and look at those device/browsers where it doesn’t work … sorry i don’t have and never will have Safari ( but it seems working on 1 of your devices/safari, so thats what you should focus on)
Possibly a simple solution but I just cannot find it. I created below chart and would like to add the time as a label (too). It now shows the y-axis value but how can I add the x-axis value in the form of hh:mm ?
in this case 18:59
This is how I did it (last couple lines):
series:
  - entity: sensor.fibaro_plug_61_power
    yaxis_id: energy
    show:
      legend_value: false
    type: area
    curve: straight
    stroke_width: 2
    group_by:
      func: avg
      duration: 1h
Not sure what you want to accomplice, but maybe this url can give you a hint
Formatting Axes Labels
Datetime
PS: remember to get rid of the {brackets}
Thanks, the idea was/is to have the time on top of the column but as a lable on the x-axis is fine too
However, whatever I try the formatting does not do anything to the x-axis.
As an example, this…still showing date only
apex_config:
  xaxis:
    labels:
      datetimeFormatter:
        hour: HH:mm
EDIT: I tried format: h and then it shows the values 12, so apparently it does not have any time but the tooltip does show time…need to dig further
hello how can I get the correct graph that doesn’t go straight horizontal since it hasn’t finished its run yet?
then how could i monitor only from sunrise to sunset?
yeah, i think it depends to some extend what your sensor(index) deliver, but also whether it’s and Hourly-Graph, or Day-graph(as you have)
When i look at 2 of my “Day” graph, i have 2 different, values in the Label( 1 with Day/Date and one with Date/Day/Hour"whole hour") and various formatting
i.e
tooltip:
                x:
                  format: HH. mm.
placed under apex_config:
And
tooltip:
enabled: true
Placed under … apex_config:/xaxis …well look below :slight_smile:
thou your "timestamp, is very “unique” :slight_smile: , as my timestamp follows the group by/etc.
          - type: custom:apexcharts-card
            experimental:
              color_threshold: true
            graph_span: 24H
            span:
              start: hour
            header:
              show: false
              show_states: false
            all_series_config:
              stroke_width: 0
              group_by:
                func: raw
                duration: 1d
                start_with_last: true
            apex_config:
              stroke:
                curve: stepline
              grid:
                padding:
                  top: 0
                  right: 0
                  bottom: 0
                  left: -20
                strokeDashArray: 0
                xaxis:
                  lines:
                    show: false
                yaxis:
                  lines:
                    show: false
              chart:
                height: 340
              legend:
                show: false
              xaxis:
                position: top
                labels:
                  style:
                    colors: '#87bf50'
                    fontWeight: 600
                    fontSize: 14px
                  format: DD HH mm
                tooltip:
                  enabled: true
              yaxis:
                labels:
                  style:
                    colors: '#FFBF00'
                    fontWeight: 400
                    fontSize: 14px
                  align: left
                  offsetX: -15
                decimalsInFloat: 2
                tickAmount: 10
              tooltip:
                x:
                  format: HH. mm
            series:
              - entity: sensor.energy_price_xx
                yaxis_id: sek1
                unit: Sek
                type: area
                extend_to: now
                data_generator: |
                  return entity.attributes.raw_today.map((entry) =>
                    var date = new Date(entry.time)
                    return [date, entry.total];
                show:
                  legend_value: false
                  datalabels: false
                opacity: 0.5
                color_threshold:
                  - value: 0.4
                    color: green
                  - value: 0.6
                    color: cyan
                  - value: 0.8
                    color: blue
                  - value: 1
                    color: yellow
                  - value: 1.2
                    color: orange
                  - value: 1.5
                    color: red
                float_precision: 2
                yaxis_id: sek2
                unit: Sek
                type: area
                extend_to: now
                data_generator: |
                  return entity.attributes.raw_tomorrow.map((entry) =>
                show:
                  legend_value: false
                  datalabels: false
                opacity: 0.5
                color_threshold:
                  - value: 0.4
                    color: green
                  - value: 0.6
                    color: cyan
                  - value: 0.8
                    color: blue
                  - value: 1
                    color: yellow
                  - value: 1.2
                    color: orange
                  - value: 1.5
                    color: red
                float_precision: 2
            card_mod:
              style: |
                ha-card {
                  background: url({{state_attr("camera.tpc2_sd_stream","entity_picture")}});
                  background-repeat: repeat;
                  background-size: 100% 100%;
                  color: red;
                  height: 314px !important;
                  width: 520px !important;
                  margin: -10px 0px 0px -15px;
                  padding: 0px 0px 0px 0px;
  - type: custom:text-divider-row
    text: Current Electricity Per Unit
    align: center
Tooltips works with Day-Columns also “HH mm”
PS: Sorry for the mess, gotta get out of the door now
extend_to: now …look above
Thanks for this, will check later this week…apreciate the feedback :slight_smile:
hello sorry but I understand, below my code
tell me how should i change the code
cards:
  - type: horizontal-stack
    cards:
      - type: sensor
        entity: sensor.solar_autconsumo_totali_giornalieri
        detail: 2
      - type: sensor
        entity: sensor.solar_consumi_totale_giornaliero
        detail: 2
    cards:
        graph_span: 24h
        span:
          start: day
        header:
          show: true
          title: POWER
          show_states: true
          colorize_states: true
        all_series_config:
          stroke_width: 2
          opacity: 0.6
          type: area
        apex_config:
          chart:
            height: 350
            zoom:
              type: x
              enabled: true
              autoScaleYaxis: false
            toolbar:
              show: true
              autoSelected: zoom
            xaxis.type: datetime
          stroke:
            width: 1
            curve: smooth
        series:
          - entity: sensor.solaredge_ac_power
            unit: Kw
            color: green
            group_by:
              func: avg
              duration: 5min
          - entity: sensor.solar_consumi
            type: line
            color: red
            group_by:
              func: avg
              duration: 5min
    cards:
        header:
          show: true
          title: Yield Daily
          show_states: true
        apex_config:
          chart:
            height: 350
            zoom:
              type: x
              enabled: true
            toolbar:
              show: true
              autoSelected: zoom
        series:
          - entity: sensor.solar_produzione_totale_giornaliero
            color: Green
            type: column
            group_by:
              func: max
              duration: 24h
          - entity: sensor.solar_immissioni_totali_giornalieri
            color: blue
            type: column
            group_by:
              func: max
              duration: 24h
          - entity: sensor.solar_autconsumo_totali_giornalieri
            color: orange
            type: column
            group_by:
              func: max
              duration: 24h
        graph_span: 15d
        span:
          end: day
type: vertical-stack
Hey,
ty for the charts. Much better than default ones.
I’m unable to make color_threshold work.
Here is the code:
  - entity: sensor.power_grid_power
    stroke_width: 0
    color: '#11aa77'
    show:
      header_color_threshold: true
    type: area
    color_threshold:
      - value: 8000
        color: red
      - value: 0
        color: black
      - value: -8000
        color: green
    group_by:
      func: avg
      duration: 10min
And I get a complete solid green block:
imagen
Any hints?
card-mod 3.2.2
ha 2023.4.5
Btw by swapping from default charts to apex charts my rasbperry went from 1.5W to 2.5-3W consumption.
ok…
as mentioned like my code above …
extend_to: now
under the specific serie(series)
Have you added:
experimental:
That was it!
I started reading from 2020 and I thought “well it wont be experimental anymore” :smiley:
Tyvm.
BTW I wanted to add that I use 2 cards in a rapberry 3 a+
Power used to be 1.4-1-6W and now raised to 2.5-3W.
Are there any power saving measures like pre-render mode or similar? Lovelace cards send a “png” for the chart, that is why it must be so power efficient.
I’m not blaming the apxcharts, I love them, but hey its double the power :confused:
Power increase is to render these two cards (left refresh 60s, right refresh 90s) [raspi os + firefox]
imagen
Hi, I have several sensors that provide me with the daily total (production, consumption, inputs, self-consumption) I would like to create a bar graph that gives me the total of these sensors for each day in 14 days.
I made this code but it doesn’t work well, it shows much higher and absolutely incorrect values.
what am I doing wrong?
cards:
    cards:
        header:
          show: true
          title: Yield Daily
          show_states: true
        apex_config:
          chart:
            height: 350
            zoom:
              type: x
              enabled: true
            toolbar:
              show: true
              autoSelected: zoom
        series:
            color: Green
            type: column
            group_by:
              func: max
              duration: 24h
            color: blue
            type: column
            group_by:
              func: max
              duration: 24h
            color: orange
            type: column
            group_by:
              func: max
              duration: 24h
        graph_span: 15d
        span:
          end: day
Im trying to compare ack.yield today with ack.yeild yesterday, see sqreenshot.
Skärmbild 2023-04-21 101958
This is my code, but I only get total ack.yield för yesterday in the top right corner.
Is it possible to only show this value as yesterdays value for now()?
graph_span: 24h
header:
  title: Produktion
  show: true
  show_states: true
span:
  start: day
now:
  show: true
  color: red
show:
  last_updated: true
apex_config:
  yaxis:
    - min: 0
  xaxis:
    tooltip:
      enabled: false
series:
  - entity: sensor.inverter_daily_yield
    group_by:
      duration: 1min
    float_precision: 2
    extend_to: now
    data_generator: ''
    stroke_width: 3
    show:
      extremas: false
      in_header: true
      legend_value: false
    offset: '-1d'
    type: column
    float_precision: 2
    data_generator: ''
    show:
      extremas: false
      in_header: false
      legend_value: false
    offset: '-24h'
    name: Diff vs. igår
    group_by:
      duration: 1min
    type: column
    float_precision: 2
    data_generator: ''
    show:
      in_chart: false
      extremas: false
      in_header: true
      legend_value: false
