ApexCharts card - A highly customizable graph card
This is indeed how I would like to have the background and the text. But I only get this when if I use the dark mode (which I don’t wont to have permanently activate).
Thanks for the update. I’ve pushed this back to priority number 1 billion for the moment. If I ever get around to it and find a working solution, I’ll post it here.
Would love to know this yaml if you are sharing.
Thanks.
Ok, in the end I found a solution that is satisfactory for me, which uses highs and lows of the forecast. From these, the average is calculated. No gaps, no overlaps. I’m happy with it.
    data_generator: |
      return entity.attributes.forecast.map((entry) => {
        let cur_hour = new Date(Date.now()).getHours();
        let result  = (entry.temperature + entry.templow) / 2;
        return [new Date(entry.datetime).setHours(cur_hour), result];
Bildschirmfoto 2023-12-07 um 21.37.02
full code
type: custom:apexcharts-card
graph_span: 9d
span:
  start: day
  offset: '-3d'
header:
  show: false
  title: Temperatur
now:
  show: true
  label: jetzt
apex_config:
  chart:
    height: 200px
    dropShadow:
      enabled: true
      opacity: 0.3
  grid:
    show: true
  legend:
    show: false
  tooltip:
    enabled: true
  xaxis:
    type: datetime
    labels:
      datetimeFormatter:
        month: ddd
        day: ddd
    axisTicks:
      show: false
    axisBorder:
      show: false
yaxis:
  - show: true
    decimals: 0
    apex_config:
      tickAmount: 2
update_interval: 1h
all_series_config:
  stroke_width: 4
  unit: °C
series:
  - entity: weather.wetterstation
    attribute: temperature
    fill_raw: last
    extend_to: now
    color: orange
    opacity: 0.9
    curve: smooth
    group_by:
      func: avg
      duration: 1h
  - entity: weather.forecast_home
    color: orange
    opacity: 0.5
    data_generator: |
This issue is marked as completed on Nov 13, 2022
I did give it a try. I can configure a ccomplete apexchart as scatter but not just one of the dataseries while the others in the same card are lines.
Did you ever get it working @AleXSR700 ?
I would love to have some help with this quite unique case, hoping someone has done this.
I have not found any information about how to manipulate normal history entity state and that particular datetime of state inside ApexChart. I would like to move simple semsor containing float value and show all last week values in ApexChart shifted 1 week forward.
Can data_generator manipulate entity.state object this way?
Do you want to change the dates of last week’s values? If not then why not use offset? Provide and example as this may help instead of theoretical stuff
Thank you, offset was just the thing I was looking for! Now I hope I can manipulate data a bit more with transform and additional calculations.
Only thing left is to scale the offset data to the right way as it seems to stick with original data. :slight_smile:
I’m a bit baffled with my multi-Y axis config as the main chart does not honor the yaxis_id, but the brush honors it. I just can not find what’s wrong it, deleted series by series but no avail, -7d offset stays not multiplied on main chart. :open_mouth:
Long shot, if someone else can spot the reason in the chart code?
type: custom:config-template-card
variables:
  MOVINGAVERAGE: states['sensor.nordpool_price_today_average_whole_day_longterm_mean']
entities:
  - ${MOVINGAVERAGE.entity_id}
card:
  graph_span: 13d
  span:
    start: day
    offset: '-7d'
  apex_config:
    xaxis:
      labels:
        datetimeFormatter:
          day: dd ddd
    chart:
      height: 300%
  yaxis:
    - id: tanaan
      decimals: 0
      apex_config:
        tickAmount: 4
    - id: power
      opposite: true
      decimals: 0
      min: 0
    - id: temperature
      opposite: true
      decimals: 0
  show:
    last_updated: true
  experimental:
    brush: true
    color_threshold: true
  brush:
    selection_span: 13d
    apex_config:
      xaxis:
        labels:
          datetimeFormatter:
            day: dd ddd
  header:
    title: Sähkön hinta, tuulivoima ja lämpötila
    show: true
    show_states: true
    colorize_states: true
  now:
    show: true
    label: Nyt
  series:
    - entity: sensor.fingrid_wind_power_generation_forecast_hourly
      yaxis_id: power
      name: Windpower gen forecast
      type: line
      curve: stepline
      stroke_width: 2
      color: grey
      data_generator: |
        return entity.attributes.events.event.map((d, index) => {
          return [new Date(d["start_time"]).getTime(), entity.attributes.events.event[index]["value"]*1];
      show:
        header_color_threshold: true
        legend_value: false
        in_header: false
        name_in_header: false
        extremas: true
    - entity: weather.openweathermap
      yaxis_id: temperature
      curve: stepline
      stroke_width: 2
      color: purple
      data_generator: |
              return [new Date(entry.datetime).getTime(), entry.temperature];
      show:
        legend_value: false
        in_header: false
        extremas: true
    - entity: sensor.weather_combined_temperature
      curve: stepline
      stroke_width: 2
      extend_to: now
      color: purple
      show:
        legend_value: false
        in_header: false
        extremas: true
    - entity: sensor.nordpool_fi
      yaxis_id: tanaan
      show:
        in_brush: true
        in_chart: true
        extremas: true
        in_header: raw
        legend_value: false
      type: column
      data_generator: |
        return entity.attributes.raw_today.map((start, index) => {
          return [new Date(start["start"]).getTime(), entity.attributes.raw_today[index]["value"]];
      color_threshold:
        - value: ${MOVINGAVERAGE.state * 1}
          color: lightblue
        - value: ${MOVINGAVERAGE.state * 33}
          color: darkgreen
        - value: ${MOVINGAVERAGE.state * 75}
          color: goldenrod
        - value: ${MOVINGAVERAGE.state * 125}
          color: darkred
      yaxis_id: tanaan
      show:
        in_brush: true
        in_chart: true
        extremas: false
        in_header: false
        legend_value: false
      type: column
      data_generator: |
        return entity.attributes.raw_tomorrow.map((start, index) => {
          return [new Date(start["start"]).getTime(), entity.attributes.raw_tomorrow[index]["value"]];
      color_threshold:
          color: lightblue
          color: darkgreen
          color: goldenrod
          color: darkred
    - entity: sensor.nordpool_price_now_euro
      yaxis_id: tanaan
      show:
        in_brush: true
        in_chart: true
        extremas: false
        in_header: false
        legend_value: false
      type: column
      transform: return x * 100;
      color_threshold:
          color: lightblue
          color: darkgreen
          color: goldenrod
          color: darkred
      yaxis_id: tanaan
      offset: '-7d'
      show:
        in_brush: true
        in_chart: true
        extremas: false
        in_header: false
        legend_value: false
      type: column
      transform: return x * 100 * 3
      color_threshold:
          color: lightblue
          color: darkgreen
          color: goldenrod
          color: darkred
After eliminating all other bells and whistles from chart, I definetely do not get why multi-Y is behaving like this:
graph_span: 14d
span:
  start: day
  offset: '-7d'
yaxis:
  - id: first
experimental:
  brush: true
brush:
  selection_span: 14d
series:
    yaxis_id: first
    offset: '-7d'
    show:
      in_brush: true
      in_chart: true
    type: column
    transform: return x * 3
    yaxis_id: first
    show:
      in_brush: true
      in_chart: true
    type: column
could please sure your code for this one?
How can I make some series not showing up when hoovering over it? In this graph only the yellow bars are important.
Hi All, I am having some issues with my Energy graphs - I have it configured to show monthly data, but for some reason if I compare it with the actual sensor history/statistics, it is clearly visible that the Apex card is missing data for some reason.
Screenshot of Apex charts
Configuration
graph_span: 12months
header:
  show: true
  title: Monthly energy consumption
  show_states: true
span:
  start: month
  offset: '-11 months'
series:
  - entity: sensor.p1_meter_5c2faf042e4c_total_power_import
    color: '#3b0145'
    type: column
    group_by:
      func: delta
      duration: 1 month
    show:
      datalabels: true
  - entity: sensor.p1_meter_5c2faf042e4c_total_power_export
    color: green
    type: column
    group_by:
      func: delta
      duration: 1 month
    show:
      datalabels: true
  - entity: sensor.gas_meter
    name: Gas consumption
    color: '#450101'
    type: column
    group_by:
      func: delta
      duration: 1 month
    show:
      datalabels: false
  - entity: sensor.vadgalamb_temperature
    color: '#f0b002'
    type: line
    group_by:
      func: avg
      duration: 1 month
Screenshot of starting value (LTS) from the 1st of December
Screenshot of last recorded values from today
If you check the values, you can see that the delta is around 443 kWh, yet the card only shows around 374 kWh.
Any idea why?
I would like to improve this graph, it show’s the rainfal per month of the last 7 years, but with 7 bars per month the bars disappear at the edge of the graph. ‘Today’ marker is also out of the chart. Finally the extreme-labels do not appear above the right bar. I always want the chart to begin in January 1st and end in December 31th. If I change this, the monthly sums are calculated wrongly.
graph_span: 1y
header:
  show: true
  title: Neerslag
  show_states: true
now:
  show: true
  label: Nu
span:
  end: year
yaxis:
  - id: first
    show: true
    opposite: true
    min: 0
    max: 250
  - id: second
    show: false
    opposite: true
    min: 0
    max: 250
apex_config:
  legend:
    show: true
    position: right
    labels:
      colors: '#fff'
  chart:
    height: 460px
    zoom:
      enabled: true
    foreColor: black
  yaxis:
    opposite: true
    labels:
      rotate: 45
      style:
        colors: '#fff'
  xaxis:
    labels:
      rotate: 0
      rotateAlways: true
      format: MMM
      style:
        colors: '#fff'
    datetimeFormatter:
      month: MMM
      day: dd MMM
      hour: HH:mm
    format: MMM
  dataLabels:
    enabled: true
    dropShadow:
      enabled: true
    background:
      enabled: true
      borderWidth: 2
      borderColor: '#dddd00'
      foreColor: '#fff'
      opacity: 0.5
      borderRadius: 50
experimental:
series:
  - entity: sensor.ws2900_daily_rain_rate
    color: '#eeeeee'
    type: column
    opacity: 0.5
    offset: '-6y'
    show:
      extremas: true
      in_header: false
    yaxis_id: first
    statistics:
      type: state
      period: day
    group_by:
      func: sum
      duration: 1month
    color: '#cccccc'
    type: column
    opacity: 0.5
    offset: '-5y'
    show:
      extremas: true
      in_header: false
    yaxis_id: first
    statistics:
      type: state
      period: day
    group_by:
      func: sum
      duration: 1month
    color: '#aaaaaa'
    type: column
    opacity: 0.5
    offset: '-4y'
    show:
      extremas: true
      in_header: false
    yaxis_id: first
    statistics:
      type: state
      period: day
    group_by:
      func: sum
      duration: 1month
    color: '#7777aa'
    type: column
    opacity: 0.5
    offset: '-3y'
    show:
      extremas: true
      in_header: false
    yaxis_id: first
    statistics:
      type: state
      period: day
    group_by:
      func: sum
      duration: 1month
    color: '#5555aa'
    type: column
    opacity: 0.5
    offset: '-2y'
    show:
      extremas: true
      in_header: false
    yaxis_id: first
    statistics:
      type: state
      period: day
    group_by:
      func: sum
      duration: 1month
    color: '#3333aa'
    opacity: 0.5
    show:
      extremas: true
      in_header: false
    yaxis_id: first
    type: column
    offset: '-1y'
    statistics:
      type: state
      period: day
    group_by:
      func: sum
      duration: 1month
    color: Yellow
    opacity: 0.5
    type: column
    statistics:
      type: state
      period: day
    group_by:
      func: sum
      duration: 1month
    yaxis_id: first
    show:
      datalabels: true
      in_header: true
all_series_config:
  stroke_width: 0.5
  show:
    legend_value: false
  curve: straight
Have you tried to use diff instead of delta with start_with_last: true ?
Code
chart_type: donut
layout: minimal
header:
  show: true
  title: Verbrauch
  show_states: true
series:
  - entity: sensor.daily_imported_energy
    color: cornflowerblue
    show:
      legend_value: false
      datalabels: percent
    float_precision: 1
  - entity: sensor.daily_direct_energy_consumption
    color: orange
    show:
      legend_value: false
      datalabels: percent
    float_precision: 1
apex_config:
  legend:
    show: false
  dataLabels:
    formatter: |
      EVAL:function(value) {
        return value.toFixed(0) + "%";
  plotOptions:
    pie:
      startAngle: -120
      endAngle: 120
      donut:
        labels:
          show: true
          name:
            show: false
          total:
            show: true
            formatter: |
              EVAL:function(w) {
                return w.globals.seriesTotals.reduce((a, b) => {return a + b}, 0).toFixed(0).toLocaleString()+ " kWh";
Unfortunately, i don’t know how to bring the unit below the value.
It’s exactly the same. It is as if it leaves out the statistics part of the data and only considers the delta between the lowest and highest point of the sensor history. As history turns into statistics, the value changes on the graph each day.
But how do I fix this?
Thank you very much!
Hi. I am using a RadialBar chart. This works great if the data is a percentage.
What if I want to display a temperature (35 - 65 degrees) over the whole range of the radial bar (which works with a simple transform) AND also display the actual temperature (rather than a %).
In my example below, a temp of 35 correctly shows as a minimum on the radial bar, but rather than ‘0%’, I would like the display to be ‘35’. And a temp of 65 correctly displays as a maximum reading on the radial bar, but rather than ‘100%’, I would like the display to be ‘65’.
Is it possible to achieve this?
chart_type: radialBar
header:
  show: false
apex_config: null
series:
  - entity: sensor.hwc_percentage_remaining
    color: '#E91E63'
  - entity: sensor.hwc_temp
    color: '#FF9101'
    transform: return (x - 35) * 3.33
Hello everyone
I am also working with the Apex-Card at the moment and have already made a lot of progress thanks to the forum. But there is one point where I am not making any progress. My wife would like to have her weight fluctuations visualized as we have long-term statistics thanks to the Bluetooth scales. I have been able to create a suitable design, but I can’t set the 0 value or recognize which value the apex card has come up with.
The fluctuations in the card are between 54 and 56 kg, but I would like to set the desired weight as the “0” value so that I can see the fluctuations based on this value.
I am also considering doing the same with the ideal temperature in the rooms (if this is possible with the value)
Does anyone have any ideas?
Thanks in advance
graph_span: 60days
experimental:
apex_config:
  legend:
    show: false
  xaxis:
    labels:
      format: dd.MM.
header:
  title: Gewichtsschwankung
  standard_format: true
  show: true
series:
  - entity: sensor.influx_aileen_weight_365days
    float_precision: 1
    type: area
    stroke_width: 0
    color_threshold:
      - value: 1
        color: red
      - value: 0
        color: yellow
      - value: -1
        color: green
    group_by:
      func: diff
      duration: 7d
    data_generator: |
      let res = [];
      for (const [key, value] of Object.entries(entity.attributes)) {
          let d = new Date(key).getTime();
          if (d > 0)
             res.push([d, value]);
      return res.sort((a, b) => { return a[0] - b[0] });
Is there some “magic” for accessing the history / statistic data? I have tested with several sensors that do have historical data stored for them, but cannot seem to get it to show on apex charts, just “N/A”. I’ve tested several options, but nothing works. Here is one example:
header:
  show: true
  title: Statistics Test Card
  show_states: true
series:
  - entity: sensor.house_consumption_kwh
    stroke_width: 2
    statistics:
      type: max
      period: 5minute
      align: middle
    curve: stepline
Result:
…and as said, have tested with different sensors, different options etc. Something I need to enable somewhere before this works?
