ApexCharts card - A highly customizable graph card
Click the “pencil” in top right corner, the click pencil to the left, edit view, chose Panel view
If you want more cards in your view, you should either use Grid, or start with a vertical-stack
You use most likely Masonry-View
Thank you very much.
I’m struggling with setting dynamically axis min and max.
I haved used custom:config-template-card successfully for dynamic graph span, but cannot do it for min/max, because it’'s a numeric value that confic template card gives to apex chart. Numeric values are given with ‘-7384.97’ meaning number between singlequotes, but Apex does not accept single quotes. For span add the “h” character to the numeric value and then confic template card gives the result without singlequotes and it works.
here is my code:
type: custom:config-template-card
variables:
  hours: '`${states[''input_number.total_nordpool_hours_available''].state -1}h`'
  maxY: '`${states[''sensor.maximum_forecast_value''].state}`'
  minY: '`${states[''sensor.minimum_forecast_value''].state}`'
entities:
  - input_number.nordpool_available_hours
  - sensor.maximum_forecast_value
  - sensor.minimum_forecast_value
card:
  type: custom:apexcharts-card
  graph_span: ${hours}
  span:
    start: minute
  header:
    show: true
    title: EMHASS  Optimization Plan
    show_states: true
    colorize_states: true
  now:
    show: false
    label: now
  yaxis:
    - min: ${minY}
      max: ${maxY}
      decimals: 2
      apex_config:
        forceNiceScale: true
        tick_amount: 4
  series:
    - entity: sensor.p_pv_forecast
      curve: stepline
      stroke_width: 2
      color: '#FFD966'
      show:
        in_header: false
        legend_value: false
      data_generator: |
        return entity.attributes.forecasts.map((entry) => {
          return [new Date(entry.date), entry.p_pv_forecast];
    - entity: sensor.p_load_forecast
      curve: stepline
      type: line
      color: '#5AB4DE'
      show:
        in_header: false
        legend_value: false
      stroke_width: 2
      data_generator: |
          return [new Date(entry.date), entry.p_load_forecast];
    - entity: sensor.p_grid_forecast
      curve: stepline
      color: '#FF7E7E'
      type: area
      show:
        in_header: false
        legend_value: false
      stroke_width: 1
      data_generator: |
          return [new Date(entry.date), entry.p_grid_forecast];
    - entity: sensor.p_batt_forecast
      curve: stepline
      color: '#8CC63F'
      type: area
      show:
        in_header: false
        legend_value: false
      stroke_width: 1
      data_generator: |
        return entity.attributes.battery_scheduled_power.map((entry) => {
          return [new Date(entry.date), entry.p_batt_forecast];
    - entity: sensor.total_cost_fun_value
      unit: €
      show:
        legend_value: false
        in_chart: false
    - entity: sensor.solcast_pv_forecast_forecast_today
      unit: kWh
      name: Solar Production Forecast
      show:
        legend_value: false
        in_chart: false
  view_layout:
    position: main
And error:
/// apexcharts-card version 2.0.4 /// Bad yaxis min/max format: -7375.97
graph_span: 11h
span:
  start: minute
header:
  show: true
  show_states: true
now:
  show: false
  label: now
yaxis:
  - min: '-7375.97'
    max: '6255.39'
    decimals: 2
    apex_config:
      tick_amount: 4
series:
    curve: stepline
    stroke_width: 2
    color: '#FFD966'
    show:
      in_header: false
      legend_value: false
    data_generator: |
    curve: stepline
    type: line
    color: '#5AB4DE'
    show:
      in_header: false
      legend_value: false
    stroke_width: 2
    data_generator: |
    curve: stepline
    color: '#FF7E7E'
    type: area
    show:
      in_header: false
      legend_value: false
    stroke_width: 1
    data_generator: |
    curve: stepline
    color: '#8CC63F'
    type: area
    show:
      in_header: false
      legend_value: false
    stroke_width: 1
    data_generator: |
    unit: €
    show:
      legend_value: false
      in_chart: false
    unit: kWh
    show:
      legend_value: false
      in_chart: false
view_layout:
  position: main
Problem is here. Should be without single quotes to work:
yaxis:
  - min: '-7375.97'
    max: '6255.39'
Would be nice if apex chart accept the values in single quotes. If anyone have some ideas how to overcome this, would be great
Try this to see if it solves your issue:
variables:
  maxY: '`${states[''sensor.maximum_forecast_value''].state *1}`'
  minY: '`${states[''sensor.minimum_forecast_value''].state *1}`'
Thanks for your reply, but nope, still has single quotes:
/// apexcharts-card version 2.0.4 /// Bad yaxis min/max format: -12000
yaxis:
  • min: ‘-12000’
    max: ‘13804.11’
It seems thay every numeric value from config-template-card will be handled in apex chart with single quotes. Or to precise, config-template-card will serve numeric values with single quotes.
EDIT: This did the trick:
 yaxis:
    - min: '${parseFloat(minY)}'
      max: '${parseFloat(maxY)}'
How possible is it to get the additional Apexchart types available in this - especially the polar chart would be uniquely useful as there’s no other chart like this for home assistant?
hi,
i have to apex charts below each other using the vertical stack.
but how can i align them properly?
the second chart (not the axes) starts a little bit more to the left, than the first one.
can i adjust this in any way?
Anyone can advise how can I display entity attribute instead of entity value?
span:
  offset: '-1sec'
apex_config:
  chart:
    type: area
    height: 250
  stroke:
    show: true
    width: 1
    curve: smooth
  legend:
    show: false
  dataLabels:
    enabled: true
  fill:
    type: gradient
    gradient:
      shadeIntensity: 0.1
      opacityFrom: 0.25
      opacityTo: 1
      inverseColors: true
      stops:
        - 0
        - 90
        - 100
header:
  show: true
  show_states: true
graph_span: 12h
update_interval: 1h
series:
  - color: rgb(138,43,226)
    entity: sensor.home_pm2_5
    attribute: percent
    type: column
  - color: rgb(235,10,104)
    entity: sensor.home_pm1
    attribute: percent
    type: column
  - color: rgb(19,173,24)
    entity: sensor.home_pm10
    attribute: percent
    type: column
all_series_config:
  curve: smooth
  stroke_width: 30
  statistics:
    type: mean
    period: hour
  show:
    extremas: true
When I’m trying like above:
`entity: sensor.home_pm10
attribute: percent`
it doesn’t work.
I would like to separate power and temperature into 2 different axis on the left and right side. How can I do that?
I would like to draw a graph of daily usage of electric power. I am drawing a sensor sensor.emporiavue2_total_daily_energy and graph looks like this.
Now, the problem. I am drawing the value of sensor.emporiavue2_total_daily_energy and graph says today’s total daily power consumption is 4580 Wh. However, current reading of this value on other card says that the correct value is 4815 Wh. Why?
Another thing: I would like that labels on a bar chart have unit also (so 4580 Wh and not just number). And maybe a legend under the graph?
And the third question. I am showing daily energy consumption on a header (left). I would like additionally show current total power (emporiavue2_total_power), but just in header, not in the graph. How to do that?
Hi.
I’m trying to dynamically show/hide an entity in my graph. To do this I’ve got a sensor that returns a boolean as true/false.
When I try and put this for the in_chart value I just get told that it isn’t a boolean…
  - entity: sensor.heat_pump_state4
    opacity: 0.6
    stroke_width: 0
    color: 4CAF50
    type: area
    show:
      legend_value: false
      in_header: false
      in_chart: {{ states('sensor.heat_pump_state4_truefalse') }}
    curve: smooth
    yaxis_id: State
I get this error:
/// apexcharts-card version 2.0.4 /// value.series[4] is not a ChartCardSeriesExternalConfig; value.series[4].show is not a ChartCardSeriesShowConfigExt; value.series[4].show.in_chart is not a boolean
And it seems to get returned to apexcharts as a null:
    opacity: 0.6
    stroke_width: 0
    color: 4CAF50
    type: area
    show:
      legend_value: false
      in_header: false
      in_chart:
        '[object Object]': null
    curve: smooth
    yaxis_id: State
Devtools clearly shows that it does indeed return a true/false boolean…
Maybe this will work?
      in_chart: ${{ states['sensor.heat_pump_state4_truefalse'].state }}
That returns a “not a boolean” too, doesn’t seem to get parsed to anything, not even object. And is just returned as a string:
Screenshot_20240429_144101
Solved by using config-template-card:
variables:
  heat_pump_state4: states['sensor.heat_pump_state4_truefalse'].state
entities:
  - sensor.heat_pump_state4_truefalse
        in_chart: ${heat_pump_state !== 'False'}
For the chart_type: donut, is there a way to stack one donut within another?
I’d like to show the balance of phases as a thin like within the breakdown of my loads. (combining these two charts)
Did you ever find a way to achieve this?
What am I doing wrong, I just can’t get the extrema’s to show in my column graph…
Chart
My yaml:
apex_config:
  chart:
    height: 180px
experimental:
  color_threshold: true
graph_span: 23h
span:
  start: day
  offset: +1h
update_interval: +1h
header:
  show: true
  standard_format: true
  show_states: true
now:
  show: true
  label: NU
series:
  - entity: sensor.current_electricity_price_all_in
    color_threshold:
      - value: 0
        color: green
      - value: 0.2
        color: orange
      - value: 0.3
        color: red
    show:
      extremas: true
      in_header: raw
    stroke_width: 3
    type: column
    float_precision: 2
    data_generator: |
      return entity.attributes.prices.map((record, index) => {
        return [record.from, record.price];
  - entity: sensor.lowest_energy_price_today
    float_precision: 2
    show:
      in_chart: false
      in_header: raw
  - entity: sensor.highest_energy_price_today
    float_precision: 2
    show:
      in_chart: false
      in_header: raw
yaxis:
  - decimals: 2
    min: 0
    max: '|+0.10|'
Perfect, no more 32.999999999999997 LOL (or similar)
Hi, is there any option to show/hide serie in graph, clicking on header label? For example if there are 3 series (and 3 labels), clicking on label 1 i can switch show/hide respective series 1? Thanks
I found out that the data from the last hour are not present on the graph. After midnight (let’s say at 0:35), I can see value 0 Wh on a graph, but current value of sensor.emporiavue2_total_daily_energy is above 0.
Why?
