ApexCharts card - A highly customizable graph card
Curious if there is a way to use variables as the template code was copied from button card…? Example use case: I have a lot of almost identical min/max/average/current single entity charts with a fair amount of config per series. Would be nice to template it using a variable or some other means entering the entity_id only once. Perhaps there is a obvious solution I’m just not seeing…?
Well, there’s the all_series_config but I disabled entity from there, I could allow it and it would match your use case I think.
I won’t support variables, as I do not plan to support javascript like in button card.
Would it be possible to have a fill that goes to and from another entity like in the middle graph here?
apexcharts-card/color_threshold.png at master · RomRider/apexcharts-card (github.com)
The use case would be to display the set point of a thermostat with the actual temperature as fluctuations around the set point.
Is it possible to use a secondary y-axis at present? I think the release notes for 1.7.0 mentioned something about extrema not being compatible with a secondary y-axis but I have not found any examples of multiple axis…
Hmm… the latest version seems to screw something with column chart… partially. I’m trying to show weather forecast for my location with min/max temperature as area chart and snow/rain as bars. It was working quite well until today morning I updated chart. Here is how it supposed to look (almost, white area should be column, as cyanish one - to show my intention I had to change graph type from column to area):
When I cahnge both snow and and rain to column, graph does not complete drawing:
Here is the code I use:
type: 'custom:apexcharts-card'
show:
  loading: false
apex_config:
  chart:
    height: 350
  fill:
    type: gradient
    gradient:
      type: vertical
      fill: dark
      shadeIntensity: 0
      stops:
        - 20
        - 100
      opacityFrom:
        - 0.1
        - 0.1
        - 1
      opacityTo:
        - 0.6
        - 0.6
        - 0.3
  plotOptions:
    bar:
      columnWidth: 50%
  yaxis:
    - show: true
      title: Temp
      min: -20
      max: 30
    - show: false
      title: Temp
      min: -20
      max: 30
    - show: true
      title: Snow
      min: 0
      max: 40
      opposite: true
    - show: false
      min: 0
      max: 40
graph_span: 6d
span:
  start: day
header:
  show: true
  title: Weather Forecast
series:
  - entity: weather.weatherbit_zielonka
    type: area
    fill_raw: last
    extend_to_end: false
    color: var(--yellowish)
    stroke_width: 2
    data_generator: |
      return entity.attributes.forecast.map((entry) => {
        return [new Date(entry.datetime).getTime(), entry.temperature];
    type: area
    fill_raw: last
    color: var(--cyanish)
    stroke_width: 2
    data_generator: |
        return [new Date(entry.datetime).getTime(), entry.templow];
    type: column
    fill_raw: last
    color: white
    stroke_width: 0
    data_generator: |
        return [new Date(entry.datetime).getTime(), entry.snow];
    type: column
    fill_raw: last
    stroke_width: 0
    data_generator: |
        return [new Date(entry.datetime).getTime(), entry.precipitation];
BTW. Is there any way to ‘group’ charts per axis and retain dynamic scaling? In my example I had to define same ranges for min/max temperatures to keep it proportional, but this removes scaling. Keeping it fully dynamic per serie causes that it could display lower temp as being higher that max one :slight_smile:
Any error in the javascript console? Did you skip the 1.6.0 version?
I didn’t find any way to make this work so far :frowning:
Hello Mirek,
I took over your configuration, unfortunately everything is dark with me.
Do you have any idea why?
I used dark sky.
Is there a way to add a day/night column in this chart?
I have a day/night sensor:
    sensors:
      day_night:
        friendly_name: "Day/Night"
        value_template: >-
          {% if is_state('sun.sun', 'above_horizon') %}
             Day
          {% else %}
             Night
          {% endif %}
        icon_template: >-
             mdi:weather-sunny
          {% else %}
             mdi:weather-night
          {% endif %}
ow
Chart
graph_span: 2d
span:
  start: day
  offset: '-12h'
header:
  show: true
  title: Temperature Forecast
now:
  show: true
  label: now
series:
  - entity: weather.openweathermap
    unit: °C
    attribute: temperature
    fill_raw: last
    group_by:
      func: avg
      duration: 1h
    type: line
    unit: °C
    show:
      in_header: false
    data_generator: |
TBH I’m not sure it’s good choice. AFAIK there is a lot controversy around that. I would left it as option to override HA selected mode.
I found the issue related to that. I’ll fix it soon. It has to do with colors. I’ve introduced support for transparency in colors (rgba(r, g, b, a)) but it seems to break apexcharts in some edge cases… So I’ll remove it again.
That’s because @mirekmal is using color variables var(--color-name). Change those to proper colors and it will work.
Yes, something like this should work if you add it to your series
series:
  - entity: sensor.day_night
    curve: stepline
    type: area
    # change 0 or 1 to suit your needs.
    transform: return x === "Night" ? 0 : 1;
There’s no way to make it scale to the min and the max. At least not for now…
I was thinking the same after having given it some more thoughts… So I’ll probably add it back.
yes, I like this:
    curve: stepline
    type: area
    transform: 'return x === ''Day'' ? 10 : 0 ;'
    color: grey
    stroke_width: 0
    opacity: 0.3
I have some more questions:
a) how can I remove “forcecast” and “Day/Night” in the legend?
b) why is the value of “Netatmo” and “previous” day the same?
vgl
graph_span: 2d
span:
  start: day
  offset: '-6h'
now:
  show: true
  label: now
color_list:
  - red
  - yellow
  - grey
  - blue
all_series_config:
  unit: °C
apex_config:
  chart:
    height: 300px
  yaxis:
    tickAmount: 6
header:
  show: true
  show_states: true
  colorize_states: true
series:
  - entity: sensor.openweathermap_temperature
    stroke_width: 2
    curve: smooth
  - entity: sensor.netatmo_locationxx_temperature
    type: line
    stroke_width: 2
    curve: smooth
    offset: '-1d'
    curve: smooth
    stroke_width: 1.5
    opacity: 0.7
    curve: smooth
    stroke_width: 1.5
    type: line
    unit: °C
    show:
      in_header: false
      legend_value: false
    data_generator: |
    curve: stepline
    type: area
    transform: 'return x === ''Day'' ? 0 : 10 ;'
    color: grey
    stroke_width: 0
    opacity: 0.3
    show:
      in_header: false
      legend_value: false
That is not possible unfortunately.
That is related to how you have built your chart:
  • because you use start: day, offset: -6h and graph_span: 2d: the chart starts at 6pm yesterday and ends at 6pm tomorrow
  • because you use on top of that offset -1d: it retrieves 2 days of data (graph_span: 2d) from 6pm yesterday - 1d (= 6pm 2 days ago) to 6pm tomorrow - 1d (= 6pm today).
Which means if you display the chart with your local time < 6pm, both values will always be the same.
So what you want is probably to offset by -2d on your serie.
Also the header always shows the latest available value in the chart for each serie. There’s already a feature request to change the behavior to display the value from “now”
ad b) is there a way for a solution without the requested feature?
no, not yet, that’s why it’s a feature request :smiley:
I believe that layout:minimal does not work in conjunction with different yaxis.
Any way one could remove the xaxis completely?
  xaxis:
    axisborder:
      show: false
    axisTicks:
      show: false
    labels:
      show: false
that leaves the x axis line, any idea how to remove it?
You have a typo in axisborder, it’s with a capital B
Like that:
xaxis:
  labels:
    show: false
  axisBorder:
    show: false
  axisTicks:
    show: false
  tooltip:
    enabled: false
:clap: amazing catch. Thank you, that did it!
That should now be fixed in the latest beta
Hi ALl,
what is the way to show only the last X minutes or X hours?
- type: custom:apexcharts-card
  graph_span: Xh
