Brilliant idea, kudo’s !
I have a small problem with my electric price graph. To show extremas, it seems like I have to use “group_by” to make it show up. But if I use group_by, the todays graph extends to the right all the way. Even though I have stated “extend_to_end: false”.
Is this a bug or can I stop the orange todays graph from filling up behind tomorrows blue price graph?
This is without group_by on the orange graph which is correct, but the two extremas values disappear:
Take a look at GitHub - markcocker/influxdb-query-to-entity: HACS Pyscript to query an InfluxDB database and copy key:value pair results into a Home Assistant entity and let me know what you think.
This is brilliant - I’ve been able to get a graph of the last 30 days of temperature/weather at home going in about 20 minutes,
- type: "custom:apexcharts-card"
header:
title: Weather - Last 30 Days
show: true
show_states: false
apex_config:
chart: { type: "area", height: 300 }
stroke: { show: true, lineCap: "square", dashArray: [0, 0, 10] }
dataLabels: { enabled: true }
legend: { show: false }
fill:
type: "gradient",
gradient:
shadeIntensity: 1,
inverseColors: false,
opacityFrom: 0.45,
opacityTo: 0.05,
stops: [20, 100, 100, 100],
yaxis:
- seriesName: "High"
title:
text: "Temperature (°C)"
show: false
- seriesName: "Rainfall"
title:
text: "Rainfall (mm)"
min: 0
opposite: true
series:
- entity: sensor.home_outsidetemp_max_30day
type: area
color: "da1e28"
stroke_width: 3
unit: "°C"
show:
extremas: true
data_generator: |
let res = [];
for (const [key, value] of
Object.entries(entity.attributes)) {
res.push([new Date(key).getTime(), value]);
return res.sort((a, b) => { return a[0] - b[0] });
- entity: sensor.home_outsidetemp_min_30day
type: area
color: "#0043ce"
stroke_width: 3
unit: "°C"
show:
extremas: true
data_generator: |
let res = [];
- entity: sensor.home_rain_30day
type: area
color: "#1192e8"
stroke_width: 2
unit: "mm"
show:
extremas: true
data_generator: |
let res = [];
graph_span: 30days
all_series_config:
type: line
group_by:
func: sum
duration: 1d
Is it possible to have a graph over a two years period displayed as two graphs in a one year period?
Where is the data for the two years? The Home Assistant recorder purge_keep_days default is 10 days.
If you want one graph with two series - one for last year and a separate one for this year, then use graph_span: 1year, add two series for the same sensor, and for the second series specify offset: -1year . For an example see GitHub - RomRider/apexcharts-card: 📈 A Lovelace card to display advanced graphs and charts based on ApexChartsJS for Home Assistant
If you trying to do somthing else, perhaps mock up what you’re trying to achieve?
Thanks for you suggestion.
The data come from an external Mysql database.
hello, I have the following code:
type: 'custom:apexcharts-card'
graph_span: 3d
header:
show: true
title: Balance Last Three Days
show_states: true
colorize_states: true
series:
- entity: sensor.nh_nicehash_totalbalance_usd
fill_raw: last
color: red
fill_raw: last
color: blue
apex_config:
yaxis:
- title:
text: USD
opposite: true
decimalsInFloat: 0
min: 55
- title:
text: BTC
labels:
show: true
decimalsInFloat: 5
min: 0.001
Is it possible to make min values to be dynamically calculated as min value of the entity being displayed?
I have a chart showing the last 30 days of electricity cost + usage. It would be nice to have an X axis annotation at each Monday, but I can’t see a way to nicely automate that. An alternative would be to have a binary sensor that turns on each Monday, and off for other days of the week, and use that as a chart series on a secondary Y axis. Anybody got something like this working?
To answer my own question, I ended up creating a series in the chart using data_generator…
config
- entity: sensor.octopus_electricity_agile_cost_30days
fill_raw: zero
type: area
color: grey
curve: stepline
name: Start of week
extend_to_end: true
opacity: 0.2
stroke_width: 1
data_generator: >
let res = [];
var startOfWeek = new Date();
startOfWeek.setHours(0,0,0,0);
startOfWeek.setDate(startOfWeek.getDate() - (startOfWeek.getDay() + 6) % 7);
var startOfWeekTime = startOfWeek.getTime();
var day = 2460601000;
res.push([startOfWeekTime, 1]);
res.push([startOfWeekTime- (8day), 0]);
res.push([startOfWeekTime-(14day), 1]);
res.push([startOfWeekTime-(22day), 0]);
res.push([startOfWeekTime-(28day), 1]);
res.push([startOfWeekTime-(36day), 0]);
return res.sort((a, b) => {return a[0] - b[0] });
Is it possible to transform both value 50 and 51 to booleans according to transform: 'return x == ''50'' ? 1 : 0;'?
How would one “transform” data_genetatored values?
- entity: weather.openweathermap
type: column
group_by:
func: avg
duration: 1h
show:
datalabels: false
in_header: false
data_generator: |
return entity.attributes.forecast.map((entry) => {
return [new Date(entry.datetime).getTime(), entry.precipitation];
I’ve tried adding the transform option but it gets ignored, I feel I need to add it in the data genetor somewhere but not very good with javascript or whatever it is.
Essentially, I’d like the precipitation value for the forecasted data to be multiplied by 4.
Hi everyone,
First of all, thank you for this amazing card!
I am trying to have only two y-axis for four series. Any clue how to do that?
graph_span: 10d
hours_12: false
y_axis_precision: 0
all_series_config:
stroke_width: 3
show:
legend_value: false
header:
show: true
title: Conso. quotidienne
show_states: true
standard_format: true
apex_config:
yaxis:
- show: true
decimalsInFloat: 0
forceNiceScale: true
- show: true
decimalsInFloat: 0
- show: true
opposite: true
decimalsInFloat: 0
- show: true
opposite: true
decimalsInFloat: 0
series:
- entity: sensor.gazpar_energy_price
type: column
group_by:
func: max
duration: 1d
- entity: sensor.myenedis_cost_yesterday_pdl
type: column
group_by:
func: max
duration: 1d
- entity: sensor.outside_temperature
name: T° ext. maximale
show:
in_header: false
offset_in_name: false
offset: '-1d'
group_by:
func: max
duration: 1d
name: T° ext. minimale
show:
in_header: false
offset: '-1d'
group_by:
func: min
duration: 1d
You can switch show: true to show: false on the two y-axis entries you don’t want to appear. Although I would recommend setting some max/min values so they align with the visible axis values to avoid confusion.
I love it, thank you @Kinetic21
When I combine two sensors in one diagram (with two y-axis) the automatic scaling changes it’s behavior in a manner, that only the max value seems to work and the min value is always zero.
Both diagrams show the same sensor in red, left combined with another sensor. Both no max or min.
Is there a way to have the y-axis scaling automic for max and min?
graph_span: 24h
header:
show: true
title: Außen
show_states: true
series:
- entity: sensor.xiaomiaqara_1_temperature
color: '#ff444f'
- entity: sensor.xiaomiaqara_1_humidity
color: '#00b4fb'
all_series_config:
type: area
curve: smooth
show:
extremas: true
group_by:
func: avg
duration: 5m
apex_config:
stroke:
width: 2
yaxis:
- decimalsInFloat: 0
opposite: true
fill:
type:
- gradient
gradient:
type: vertical
opacityFrom: 0.7
opacityTo: 0.3
tooltip:
x:
format: 'HH:mm'
Is it possible :
- to show the numbers of every month
- completely occupy the x-axis
Why does a duration of 31 days cause a column overflow?
graph_span: 365d
update_interval: 1hour
cache: true
span:
end: month
header:
show: false
apex_config:
xaxis:
labels:
format: MM
show: true
showAlways: true
yaxis:
forceNiceScale: false
decimalsInFloat: 0
chart:
type: area
height: 300
stroke:
show: true
width: 1
legend:
show: true
dataLabels:
enabled: false
distributed: true
fill:
type: gradient
gradient:
shadeIntensity: 0.1
opacityFrom: 0.25
opacityTo: 1
inverseColors: true
stops:
- 0
- 90
- 100
series:
- color: 'rgb(20,129,238)'
entity: sensor.conso_eau_mois
type: column
float_precision: 2
group_by:
func: max
duration: 30d
** EDIT** Nevermind, there was a spacing issue… seems to work now. Thanks for the example!!!
Hi Mark thanks for putting this up on github, I looked at it and am working on doing the same thing in nodered since I already have this up and there is an influxdb node. I just wanted to see if I am formatting the sensor the same as you for your data_generator function. Is the below correct?
