I have installed grafana and have been able to graph the solar output data as I want it, however I don’t want to use grafana, but still can not get the data to display in home assistant using apex charts.
For the daily solar production the query is:
SELECT mean("value") FROM "solar" WHERE ("entity_id" = 'day') AND $timeFilter GROUP BY time($__interval) fill(none)
@RomRider - Hi, Yes I am doing the sensor for influx as below… However as stated earlier it is only returning the sum of all the influx data.
How do I get it to graph each months values ?
I have re-read the influxdb info many times, and can not figure it out. I have also searched the HA forums and googled, and can not find a solution. What info I do find is to do with using grafana and node red, which I dont want to use. I want to keep it as simple as possible, and use apex charts which I really like.
I really loce the card and use it throughout my lovelace. My power and gas consumption is done and now I am trying to show sleep data. I have a sensor that changes text (light_sleep, deep_sleep) to numbers (3, 4), so apexchart can make sense of it.
What I want is to name the labels in the y-axis to with the corresponding name. I looked up the apex guides, but when I try to use label formatter the card wont work. Any suggestions?
Hi all, is there already a way to also show distributed columns (no time series, e.g. link). My potential use case would be to show all room temperatures and valve status at a glance?
First up big ups for making this RomRider, its another amazing part of HA imo.
Second, was wondering if it was possible to either transform my ping data to cap at 100ms or to force a scale for the graph so the speeds look scaled correctly. I’m kinda interested in something to transform that says anything over 100 = 100
Native multi-y axis with auto-scaling support incoming
This means, no need to define min and max anymore with multiple y-axis and also a better UX (no need to define as much y-axis as the number of series).
The long awaited native multi-y axis support is finally there You can now have as many y-axis as there are series defined in your configuration, or less and it supports auto-scaling So you can now easily group some series together on an y-axis, and some other on other y-axis.
min and max support multiple types of format:
not set or auto (this is the default): if it is set to auto, the min or max will be automatically calculated
any number: if a number is set, the min or max will be fixed on the y-axis
~90: if the format is ~ followed by a number, the min or max will be defined as a soft bounds
min: ~90 and the min of the data in the series is 120: the y-axis min value will be 90
min: ~90 and the min of the data in the series is 60: the y-axis min value will be 60
'|+20|' or '|-20|': This will add/remove the value between | | from the min/max
min: '|-20|': The min of the data in the series is 32, the y-axis min will be 12 (= 32 - 20)
max: '|+10|': The max of the data in the series is 32, the y-axis max will be 42 (= 32 + 10)
Example:
type: custom:apexcharts-card
graph_span: 20min
yaxis:
- id: first # identification name of the first y-axis
apex_config:
tickAmount: 4
- id: second # identification name of the second y-axis
opposite: true # make it show on the right side
apex_config:
tickAmount: 4
all_series_config:
stroke_width: 2
series:
- entity: sensor.random0_100
yaxis_id: first # this serie will be associated to the 'id: first' axis.
- entity: sensor.random_0_1000
yaxis_id: second # this serie will be associated to the 'id: second' axis.
transform: 'return Number(x) + 30;' # We make it go fom 30 to 130
transform: 'return Number(x) - 30;' # We make it go from -30 to 70
Love that soft bounds are here! But I can’t get it to work with max.
This is what I’m trying to do. Electricity price is 99% of the days between 1-100 cents, but a few days per year it can be 200 cents. I want the y-axis to go from 0-100 since that gives me a good udnerstanding of the electricity price by just glancing at it. But the rare days when it’s higher than 100 cents I want the y-axis to reflect that.
series:
- entity: x.y
# yaxis_id: whatever # not needed anymore if you have only 1 yaxis
yaxis:
- # id: whatever # not needed anymore if you have only 1 yaxis
min: 0
max: ~100
Not getting it to work… But it is usually me that is the problem Do you see anything obvious? When trying the same for a graph of the electricity price I also get the Y scale from 0 to 5.
