NdR
(Andrea Montanari)
May 27, 2021, 2:12pm
1008
Thank you again @RomRider
Unfortunatelly this isn’t working.
This is the setup:
Sensor:
sensors:
xch_farm:
friendly_name: Farm CHIA
unit_of_measurement: 'XCH'
value_template: '1'
attribute_templates:
farm: "[ ['2021-05-22T05:30:00.000Z', 0.00499446], ['2021-05-23T05:30:00.000Z', 0.01417467], ['2021-05-24T05:30:00.000Z', 0.01414641], ['2021-05-25T05:30:00.000Z', 0.01311282], ['2021-05-26T05:30:00.000Z', 0.01513299], ['2021-05-27T05:30:00.000Z', 0.01439478] ]"
Dev Tools output:
sensors:
xch_farm:
value_template: '1'
Card:
type: 'custom:apexcharts-card'
header:
show: true
title: ApexCharts-Card
show_states: true
colorize_states: true
graph_span: 2d
span:
start: week
apex_config:
dataLabels:
enabled: true
series:
- entity: sensor.xch_farm
type: line
data_generator: |
return JSON.parse(entity.attributes.farm).map((entry) => {
return [new Date(entry[0]).getTime(), parseFloat(entry[1])];
NdR
(Andrea Montanari)
May 27, 2021, 2:32pm
1010
Ok @RomRider , I did a thing.
I used Jinja2 and create a real array in the sensor attributes.
sensors:
xch_farm:
value_template: '1'
farm: |
"date": "2021-05-22T05:30:00+00:00",
"value": 0.00499446
"date": "2021-05-23T05:30:00+00:00"",
"value": 0.01417467
"date": "2021-05-24T05:30:00+00:00"",
"value": 0.01414641
Now the array is working, BUT with this card setup:
header:
show: true
show_states: true
graph_span: 2d
span:
start: week
apex_config:
dataLabels:
enabled: true
series:
type: line
data_generator: |
return entity.attributes.farm.map((entry) => {
return [new Date(entry.date), entry.value];
I finally “see something” in the graph. But no values are showed. Maybe too many decimals?
You need to increase the yaxis definition:
float_precision: 10
y_axis_precision: 10
Try not to burn your hard-drive
NdR
(Andrea Montanari)
May 28, 2021, 7:39am
1012
@RomRider thank you very much for your help. It worked perfectly!
Hahahahha I’ll do my best
NdR
(Andrea Montanari)
May 28, 2021, 9:43am
1013
One more thing @RomRider
On the iOS app I have this kind of glitch on the “now” label.
Is that my fault?
Probably safari’s fault nothing I can or you can do about it.
NdR
(Andrea Montanari)
May 28, 2021, 9:48am
1015
Ok no problem Label removed
How do I remove future values from the graph if the X axis is time?
I don’t want this horizontal line
graph_span: 24h
span:
start: day
header:
show: true
title: Napięcie paneli
show_states: true
series:
- entity: sensor.pv_voltage_a
curve: smooth
fill_raw: 'null'
group_by:
duration: 20min
func: avg
y_axis_precision: 1
Nassau
May 30, 2021, 3:01am
1018
Similar to some others in this thread, I wanted to make a radial graph for CPU/RAM/Disk usage. The problem so far is the bottom of the graph being cut off:
Adjusting the offset can make the graph visible, but the legends are still cut off with an adorable little scroll bar. It looks like a “foreignobject” container is causing this, but I can’t seem to adjust with the ApexCharts options or card-mod:
Any suggestions to fix this?
Not much we’ll be able to help with without your config
Nassau
May 30, 2021, 9:36am
1020
chart_type: radialBar
graph_span: 1s
header:
show: false
apex_config:
chart:
foreColor: 'rgb(148,148,148)'
offsetY: -50
height: 350
legend:
show: true
position: left
floating: true
offsetX: 200
offsetY: 200
plotOptions:
radialBar:
inverseOrder: true
offsetY: 0
startAngle: -180
endAngle: 90
hollow:
background: transparent
dataLabels:
name:
show: true
value:
show: true
series:
- entity: sensor.golfquest_pc_cpu_usage
Wow, I made a mental note at least three times to not forget that when I was scanning through this thread.
karma
(karmah)
May 30, 2021, 8:35pm
1021
Hello everybody.
Is it possible to create a monthly chart (12 months) with the ApexCharts Card?
span:
end: day
graph_span: 7d
header:
show: true
title: Fatura
show_states: true
apex_config:
tooltip:
enabled: true
yaxis:
- show: true
decimalsInFloat: 0
axisTicks:
show: true
opposite: true
axisBorder:
show: false
color: '#e74c3c'
labels:
style:
colors: '#e74c3c'
fontSize: 12px
fontWeight: bold
fontFamily: Raleway
forceNiceScale: true
series:
- entity: sensor.total_pagar_shelly_em_casa
type: column
show:
extremas: true
group_by:
func: last
duration: 1d
color: '#e74c3c'
TommyWelle
(Tommy Welle Jacobsson)
June 1, 2021, 8:29am
1023
Hello
Anyone know why my charts suddenly wont show up anymore? They do if i create a new one, but not with this exact code. Is there anything in my code that has change that makes it break?
update_interval: 15min
graph_span: 1d
layout: minimal
header:
show: true
show_states: true
floating: true
now:
show: false
label: Stua
color: white
series:
- entity: sensor.multi_stua_temp
color: '#e74c3c'
type: line
group_by:
func: max
duration: 30min
extend_to_end: true
- entity: sensor.multi_stua_fuktighet
show:
datalabels: true
color: '#3279a8'
type: line
group_by:
func: max
duration: 30min
extend_to_end: true
apex_config:
chart:
height: 180px
xaxis:
tickAmount: null
labels:
format: HH
stroke:
width: 3
curve: smooth
dataLabels:
enabled: false
legend:
show: false
_BaQs
(Pierre )
June 1, 2021, 7:56pm
1024
loving your graphs, but on my side the redering is very bad!
any idea ?
Have you figured it out? I’m also looking for this
I tried asking about this 10 days ago but I got no answer .
you want it like this chart right?
It is not possible at the moment because grouping by month doesn’t group by actual months but by some number of days which is fixed.
I have no plan at the moment to introduce that feature, but will think about it for the future.
I don’t know what is wrong, but when I try to use the min and max for the y-axis, I cannot get it to work. As soon as I change a min or max value, I see the correct values on the y-axis for 0.1 second, and then it seems some auto-range is performed?
It is said in the documentation that min
and max
shouldn’t be under apex_config
but straight under your yaxis
entry.
