ApexCharts card - A highly customizable graph card
Awesome. Thanks for that.
Quick question: why does the card require enabling the recorder for an entity when only a pie or a donut is used? Ex:
type: 'custom:apexcharts-card'
chart_type: donut
series:
  - entity: sensor.energymonthlywatertank
The above won’t work if sensor.energymonthlywatertank is excluded from the recorder, even if only the last value of the sensor is needed for the chart.
The reason I’m asking is that I have over 15 “utility meter” that are updated every two seconds that basically count the kWh total of many different loads in my home. Enabling the recorder on those will chew up GB of data while I only need the last state; the integration total.
Let me know if I missed something.
Thanks !
Because you can also use group_by with those types of charts (which requires history). It could be an optimization for apexcharts-card, but it will require some rework to make it happen.
Better fill in a feature request on GH so that I don’t forget about it :slight_smile:
Hi all,
why did happen this?
The red line must go to 100% instantly…
  graph_span: 1d
  cache: true
  header:
    title: Deumidificatore/Umidificatore
    show: true
    show_states: true
    colorize_states: true
  apex_config:
    yaxis:
      min: 0
      max: 100
    xaxis:
      labels:
        format: hh
        show: true
        showAlways: true
    legend:
      show: false
    dataLabels:
      enabled: false
      distributed: true
  series:
    - entity: sensor.umidita_int_humidity
      type: line
      color: blue
    - entity: sensor.umidificatoretempl
      type: line
    - entity: sensor.deumidificatoretempl
      type: line
Not sure if you had solved this or not yet, but wanted to share since it was driving me crazy as well trying to extend the foreignobject element:
card_mod:
  style: |
    .apexcharts-canvas svg foreignObject {
      height: << height of card >> px;
I actually wanted to have the chart angle start at 0 but couldn’t figure out how to get the legend text to right-align when floating, so your example provided a happy solution (flip it and use the default left-align). Thanks!
You’ll want to use curve: stepline in the serie to have a “staircase” like chart. That’s because by default, it creates a smooth curve.
I have to ask you again @RomRider about the glitch in the drawing of the chart below. As you can see it looks like there are shaddows and the filling of the graph is not even. For some reason I get this from time to time but doing small changes like changing time span from 48h to 47h can sometimes fix it (see chart #2 below).
If I remember it correctly, adding fill_raw: last should fix it, but for some reason I still get the issue sometime. Any ideas?
type: custom:apexcharts-card
header:
  title: ''
  show: true
  show_states: true
  colorize_states: false
graph_span: 47h
apex_config:
  tooltip:
    enabled: false
  annotations:
    position: back
    yaxis:
      - 'y': 0
        strokeDashArray: 0
        borderColor: '#303030'
        borderWidth: 1
  yaxis:
    forceNiceScale: true
    labels:
      style:
        fontSize: 10px
        fontFamily: Segoe UI Light
  xaxis:
    axisBorder:
      show: false
    labels:
      style:
        fontSize: 10px
  legend:
    show: false
  chart:
    height: 225
  grid:
    show: false
    strokeDashArray: 3
    position: back
  dataLabels:
    enabled: false
  stroke:
    width: 1
  fill:
    type: gradient
    gradient:
      type: vertical
      shadeIntensity: 0.8
      inverseColors: false
      opacityFrom: 0.6
      opacityTo: 0
      stops:
        - 0
series:
  - entity: sensor.garaget
    type: area
    curve: smooth
    fill_raw: last
    color: '#404040'
    float_precision: 1
    transform: return x + 1;
    show:
      in_chart: true
  - entity: sensor.nibe_105703_40004
    type: area
    curve: smooth
    fill_raw: last
    color: fc7703
    float_precision: 1
  - entity: sensor.nibe_105703_43084
    type: column
    color: orange
    fill_raw: last
    show:
      in_chart: true
    group_by:
      func: avg
      duration: 20min
style: |
  ha-card {
     --ha-card-background: rgba(0, 0, 0, 0);
     box-shadow: none;
     margin: 8px 8px 28px 8px;
     font-size: 15px;
     text-align: left;
     font-family: Segoe UI Light;
   div#header__title {
     font-size: 15px;
  #state__value > #state {
    font-weight: 100;
Is there a way to show 7 kWh directly in the donut rather than the percentage (29 in this case) ?
I feel showing “29” for 29% is redundant, since the donut is already roughly showing that it is one third. 7 kWh is new data that I feel would be more useful at a glance.
Thanks for teaching me how to do this!
(is there a better way to ask questions rather than this thread, or this is it?)
RomRider,
Would that be an “issue” or a “pull request”? I don’t contribute to the project, so I feel a “pull request” is not appropriate. I’m puzzled.
It would be a feature request as an issue on github. I don’t believe what you are asking is possible with the library I use, I’d have to check further.
For the recorder feature request, it’s been opened as #169.
Thanks for checking about the labels. I’ve spotted at least two other user asking the same question in this thread or a variant of that question. Let me know if you’d like me to open a feature request for that one as well.
Thanks !
Anyone tried Apexcharts with Monitor Docker?
I have everything setup and have a sensor for every docker container. They look like any other sensor in Home Assistant with multiple attributes. One of the attributes is “memory” for example. However, if I try to graph the attribute with apexcharts it doesn’t work. Apexcharts just says “Loading…” forever with no errors.
  - type: custom:apexcharts-card
    update_interval: 30s
    graph_span: 24h
    series:
      - name: Test Container
        entity: sensor.docker_test_container #Changeme
        attribute: memory
        unit: '%'
I find this really strange as it works with any other sensor as long as you change the entity and attribute. Is there any reason why this doesn’t work with sensors produced by this integration but with any other? The only difference I can see is that the integration doesn’t use unique id’s on entities. Does that matter?
Your entity is probably excluded from the recorder
I love you!
Thanks so much, I totally forgot I had added sensor.docker_* to me recorder exclusion list.
Hi, i have created some Graphs with Apexchart.
Some of my Charts are not so smooth:
Here the code:
graph_span: 48h
header:
  show: true
  title: Pooltemperatur
  show_states: true
series:
  - entity: sensor.pooltemperatur
    stroke_width: 3
    type: area
Can someone tell me what i must chnage to see a “smoother” graph?
In “mini-graph-card” the graph is smooth:
Thanks for help.
Regards
Herbert
mini-graph-card uses an average function to draw the chart. You can reproduce the same behavior using group_by in apexcharts-card :slight_smile:
Ahh…great. Thanks for help
Can you share the code of the graphs that you made for the steps and sleep. And also from you power and gas. Thanks!
I would like an hourly overview of how much water has been used. Can you still change the number in the Y axis? Instead of 0.02 e.g. 20.0. And why am I not seeing any values for the columns?
header:
  show: true
  title: ApexCharts-Card
  show_states: false
series:
  - entity: sensor.wasserzaehler
    type: column
    group_by:
      func: diff
      duration: 60min
apex_config:
  yaxis:
    - show: true
      decimalsInFloat: 3
Can someone help?
Thx.
Herbert
Sure. Here you go:
Steps:
          - type: vertical-stack
            cards:
              - type: custom:button-card
                entity: sensor.google_fit_dick_steps
                show_icon: false
                show_state: true
                state_display: |
                    return `<font size=5><b>${entity.state}</b></font> / 6000 stappen`
                style: |
                  ha-card {
                    margin-top: 3px;
                    -webkit-box-shadow: none;
                    -moz-box-shadow: none;
                    box-shadow: none;
                    background-color: rgba(255, 255, 255, 0.0);
                tap_action:
                  action: navigate
                  navigation_path: /ui-map/family_dick_health_steps
                styles:
                  grid:
                    - grid-template-areas: '"n n graph" "s s graph" "bar bar bar"'
                    - grid-template-rows: min-content min-content min-content
                    - grid-template-columns: min-content
                  name:
                    - justify-self: start
                    - padding-left: 10px
                    - color: rgb(75, 204, 82)
                    - font-weight: bold
                  state:
                  custom_fields:
                    bar:
                      - height: 15px
                      - width: 100%
                custom_fields:
                  bar:
                    card:
                      positions:
                        icon: 'off'
                        indicator: inside
                      type: custom:bar-card
                      max: 6000
                      tap_action:
                        action: navigate
                      style: |
                        bar-card-value {
                          font-size: 1px;
                          color: rgb(75, 204, 82);
                        bar-card-markerbar {
                          background-color: rgba(255, 255, 255, 0.5);
                        ha-card {
                          margin-top: 7px;
                          text-align: left;
                          box-shadow: none;
                experimental:
                  color_threshold: true
                apex_config:
                  min: 0
                  tickAmount: 4
                  chart:
                    height: 250px
                  tooltip:
                    enabled: true
                series:
                  - entity: sensor.google_fit_dick_steps
                    color_threshold:
                      - value: 0
                        color: rgb(96, 130, 98)
                      - value: 6000
                    group_by:
                      func: max
                      duration: 1d
                      fill: zero
                    type: column
                graph_span: 7d
                span:
                  end: day
                header:
                  show: true
                  title: Afgelopen week
                  floating: false
                style: |
                  ha-card {
                    margin-top: 10px;
                    box-shadow: none;
Sleep
            cards:
                entity: input_text.sleeping_total
                show_icon: false
                show_state: true
                state_display: |
                    return `<font size=4><b>${entity.state}</b></font> geslapen.`
                style: |
                  ha-card {
                    margin-top: 14px;
                    box-shadow: none;
                tap_action:
                  action: none
                styles:
                  grid:
                  name:
                    - font-weight: bold
                  state:
                  custom_fields:
                    bar:
                      - height: 120px
                      - width: 100%
                      - margin-top: '-12px'
                custom_fields:
                  bar:
                    card:
                      type: history-graph
                      entities:
                        - entity: var.dick_sleep
                      hours_to_show: 24
                      style: |
                        ha-card {
                          margin-top: 7px;
                          box-shadow: none;
                          background-color: rgba(255, 255, 255, 0);
                experimental:
                chart_type: line
                series:
                  - entity: sensor.sleeping_states
                    curve: stepline
                    stroke_width: 2
                    color_threshold:
                      - value: 1
                        color: '#005580'
                      - value: 2
                        color: '#8095FF'
                      - value: 3
                        color: '#4DE1FF'
                      - value: 4
                        color: '#FF8C19'
                span:
                  start: day
                  offset: '-3h'
                graph_span: 12h
                apex_config:
                  tooltip:
                    enabled: false
                  chart:
                    height: 180px
                  yaxis:
                    tickAmount: 3
                    min: 1
                    max: 4
                    opposite: true
                    labels:
                      formatter: |
                        EVAL:function(value) {
                          if (value == 1) {
                            return "Diep";
                          } else if (value == 2) {
                            return "Licht";
                          } else if (value == 3) {
                            return "REM";
                          } else if (value == 4) {
                            return "Wakker";
                style: |
                  ha-card {
                    margin-top: -65px;
                    box-shadow: none;
                chart_type: pie
                series:
                  - entity: input_number.sleeping_state_rem
                    color: '#4DE1FF'
                    show:
                      as_duration: second
                  - entity: input_number.sleeping_state_light
                    color: '#8095FF'
                    show:
                      as_duration: second
                  - entity: input_number.sleeping_state_deep
                    color: '#005580'
                    show:
                      as_duration: second
                apex_config:
                  chart:
                    height: 250px
                style: |
                  ha-card {
                    margin-top: -25px;
                    box-shadow: none;
                experimental:
                apex_config:
                  min: 0
                  tickAmount: 4
                  chart:
                    height: 250px
                  tooltip:
                    enabled: true
                  yaxis:
                    tickAmount: 3
                    min: 4
                    max: 10
                    opposite: true
                    labels:
                      formatter: |
                          return value + " uur";
                series:
                  - entity: input_number.sleeping_total
                    color_threshold:
                      - value: 0
                      - value: 6
                    group_by:
                      func: max
                      duration: 1d
                      fill: zero
                    type: column
                graph_span: 7d
                span:
                  end: day
                header:
                  show: true
                  floating: false
                style: |
                  ha-card {
                    margin-top: -5px;
                    box-shadow: none;
Electricity, gas & water
        cards:
          - type: markdown
            style: |
              ha-card {
                font-size: 150%px;
                font-family: 'Open Sans', sans-serif;
                border-radius: 12px;
                text-align: center;
            content: >
              <b>Huidig verbruik:</b><br /><table><tr><td>Gasvebruik:
              </td><td>{{states.sensor.hourly_gas_consumption.state}} m3/h.
              </td><td> <i>(€ {{states.sensor.current_gas_cost.state }} per
              uur)</i></td></tr> <tr><td>Elektraverbruik:
              </td><td>{{states.sensor.power_consumption.state}} mWh. </td><td>
              <i>(€ {{ states.sensor.current_power_cost.state }} per
              uur)</i></td></tr> <tr><td>Waterverbruik:
              </td><td>{{states.sensor.watermeter_hourly.state}} L/h. </td><td>
              <i>(€ {{ states.sensor.current_water_cost.state }} per
              uur)</i></td></tr></table>
            yaxis:
              - id: electra
                apex_config:
                  decimalsInFloat: 2
                  tickAmount: 3
                  min: 0
                  max: 5
                  title:
                    text: kWh
                    style:
                      fontWeight: 600
              - id: gas
                apex_config:
                  decimalsInFloat: 2
                  tickAmount: 3
                  min: 0
                  max: 2
                  title:
                    text: m3h
                    style:
                      fontWeight: 600
              - id: water
                apex_config:
                  labels:
                    show: true
                    minWidth: 0
                    maxWidth: 1
                  decimalsInFloat: 0
                  tickAmount: 3
                  min: 0
                  title:
                    text: L/h
                    style:
                      fontWeight: 600
            series:
              - entity: sensor.power_consumption
                yaxis_id: electra
                group_by:
                  func: avg
                  duration: 10min
                  fill: 'null'
                type: line
                curve: straight
                stroke_width: 1
                unit: kW
                float_precision: 2
                color: rgb(255, 208, 0)
              - entity: sensor.hourly_gas_consumption
                yaxis_id: gas
                group_by:
                  func: avg
                  duration: 10min
                  fill: last
                type: line
                curve: straight
                stroke_width: 1
                unit: m3
                float_precision: 2
                color: rgb(125, 173, 129)
              - entity: sensor.watermeter_hourly
                yaxis_id: water
                group_by:
                  func: avg
                  duration: 10min
                  fill: last
                type: line
                curve: straight
                stroke_width: 1
                unit: L
                float_precision: 2
                color: rgb(122, 193, 255)
            graph_span: 1d
            apex_config:
              chart:
                height: 150px
              tooltip:
                enabled: true
                shared: true
                onDatasetHover:
                  highlightDataSeries: false
                x:
                  show: false
                'y':
                  show: true
            header:
              show: true
              title: Verbruik afgelopen 24 uur
              floating: false
            now:
              show: true
            style: |
              ha-card {
                font-size: 25px;
                text-align: center;
                margin-top: 8px;
                box-shadow: none;
              img {
                border-radius: 50px;
            series:
              - entity: sensor.total_water_cost
                group_by:
                  func: diff
                  duration: 1d
                  fill: zero
                type: column
                curve: stepline
                stroke_width: 4
                unit: €
                float_precision: 2
              - entity: sensor.total_gas_cost
                group_by:
                  func: diff
                  duration: 1d
                  fill: zero
                type: column
                curve: stepline
                stroke_width: 4
                unit: €
                float_precision: 2
              - entity: sensor.total_power_cost_low
                group_by:
                  func: diff
                  duration: 1d
                  fill: zero
                type: column
                curve: stepline
                stroke_width: 4
                unit: €
                float_precision: 2
                color: rgb(255, 247, 0)
              - entity: sensor.total_power_cost_normal
                group_by:
                  func: diff
                  duration: 1d
                  fill: zero
                type: column
                curve: stepline
                stroke_width: 4
                unit: €
                float_precision: 2
            graph_span: 7d
            stacked: true
            span:
              end: day
            header:
              show: true
              title: Kosten afgelopen week
              floating: false
            apex_config:
              chart:
                height: 180px
              tooltip:
                enabled: true
                shared: true
                onDatasetHover:
                x:
                  show: false
                'y':
                  show: true
              yaxis:
                - decimalsInFloat: 0
                  tickAmount: 4
                  min: 0
                  max: 12
                  title:
                    text: € per dag
                    style:
                      fontWeight: 600
            style: |
              ha-card {
                font-size: 25px;
                text-align: center;
                margin-top: 8px;
                box-shadow: none;
              img {
