Check the system monitor package on my github. It also uses a dockermon addon or you could use glances…
Could you add fill: 'null'
to the group_by
? The default being fill: last
it will fill the data for any missing value, including value from the future. I believe this should fix the issue, but I will make sure that we’re no filling data in the future with group_by
PS: The default HA graph will never show data from the future
This is now fixed in this commit and the 1.4.0 release
New Release
1.4.0 (2021-02-02)
Features
- series: Show/Hide a specific serie from the header or the graph (#36) (95c0433)
- Support for auto-entities (060e4c0)
- editor: Preview in the GUI card selector (d4cd7a3)
graph: New chart types
scatter
,donut
,pie
andradialBar
(#24) (a0e4f85) -
group_by: Add new
diff
function (57fd6a6) - series: Retrieve an attribute of your entity instead of the state (#32) (b76bf16), closes #29
Bug Fixes
group_by
was extending values into the future (2cb79d2) - Graph stopped updating following ddf6ca9 (bc54729)
- Sometimes card would stay in warning mode (ddf6ca9)
- Tooltip should not be in a fixed position (1762049)
func: Filter
null
values indiff
(cfe736c) -
header: Hide unit when
as_duration
is used (5686931) - header: State was sometimes multi-line (4187104)
Documentation
OK some weirdness I noticed yesterday. Just installed latest beta of HA and it’s zeroed out (most) all of my graphs:
The entities are in recorder and I can see states graphed for the entity eg:
It was fully populated before the update
Interestingly all my other ones are OK and this one is a bunch of template sensors I use…
What does your card config look like for those?
- type: custom:apexcharts-card
graph_span: 24h
header:
show: true
title: Fuel Prices Sydney
apex_config:
responsive:
- breakpoint: 765
options:
chart:
height: 500px
- breakpoint: 1025
options:
chart:
height: 400px
- breakpoint: 10000
options:
chart:
height: auto
stroke:
width: 3
curve: stepline
chart:
zoom:
enabled: true
toolbar:
show: true
tools:
zoom: true
zoomin: true
zoomout: true
pan: true
reset: true
plotOptions:
bar:
columnWidth: '50%'
legend:
showForSingleSeries: true
series:
- entity: sensor.syd17310
- entity: sensor.syd18253
- entity: sensor.syd18424
- entity: sensor.syd2436
- entity: sensor.syd643
- entity: sensor.syd663
For the entities not showing up, has the price changed in the last 24h?
no changes in price for the others
Alright, I’ll fix that
By looking closely, I can see that they are showing up but as points at the very end of the chart.
yes and they will become lines over next 24hr. (until I restart) It doesn’t seem to be reading the history
What happens with cache: false
here?
type: 'custom:apexcharts-card'
graph_span: 24h
header:
show: true
title: Fuel Prices Central Coast
cache: false
apex_config:
no change.
Are you running 1.4.0 now (does it show in the console)?. I can’t seem to reproduce
Also did you restart home assistant at some point between around 4pm and 10am?
also as I said… these are all template sensors… None of my other ones seem to be doing this
That would explain the result. While you reboot HA, it generated ‘unavailable’ states for those sensors (only the template ones as the other ones retrieve the last known state from history, not the template one). Those counts as null
in the chart, and null
= no line between the last state and null. The start of the line is around 10am on your graph which matches this theory.
I think HA displays the line between the last state and the last null
, and then starts the line again on the next non-null value. It seems different for apexcharts which doensn’t extend the line until the null
value. I don’t think there’s much I can do there appart from adding an option to fill the null
with values
but the regular history shows no gap
Edited the previous response with an explanation
This is most likely correct.
maybe… can we try that?
