Your sun.sun entity is probably excluded from the recorder and thus has no history
I have tried it but the Utility Meter is only stored for 10 days like the other sensors, so I need the long term statistics in order to show consumption / month for the last year and even to show the last 30 days. But if you find a way of doing this, please let me know
Since yesterday I have a error:
/// apexcharts-card version 2.0.1 /// value.all_series_config is not a ChartCardAllSeriesExternalConfig; value.all_series_config.extend_to_end is extraneous
To my knowledge I haven’t changed anything
type: custom:apexcharts-card
graph_span: 24h
span:
start: day
header:
show: true
title: Ticker - BTC-EUR 24hr
show_states: false
colorize_states: true
now:
show: true
apex_config:
legend:
show: true
all_series_config:
curve: straight
unit: EUR
fill_raw: last
stroke_width: 2
extend_to_end: false
float_precision: 0
group_by:
func: avg
duration: 30min
show:
legend_value: false
series:
- entity: sensor.bitvavo_total_asset_value_eur.....
anybody else having these issues?
Have a look in the release notes, extend_to_end
has been replaced with extend_to
thanks
Ah sorry I thought utility meter sensors had been added to the long term statistics by default with the update
I did see @RomRider is thinking of possibly adding Influxdb support which would do it.
I did try Influxdb but I missed having the more-info and history as changed back.
Would it be possible to add “type: diff” to the statistics funtionality? I guess it would solve the problem.
Sounds like that is what is missing, not implemented now but I think RomRider is working on something
I also have a xaxis-positioning and 0-value issue with the statistics functionality.
It’s working fine with “group_by”:
graph_span: 365day
span:
end: month
color_list:
- var(--label-badge-green)
header:
show: true
title: kosten | monat
show_states: true
standard_format: true
series:
- entity: sensor.ifx_goe_costs_total_year
type: column
float_precision: 2
show:
datalabels: true
group_by:
func: diff
duration: 30day
fill: zero
yaxis:
- min: 0
max: ~45
decimals: 0
apex_config:
tickAmount: 5
apex_config:
plotOptions:
bar:
columnWidth: 75%
xaxis:
tooltip:
enabled: false
card_mod:
style: |
#state__name, .apexcharts-xaxis-label, .apexcharts-yaxis-label {
font-size: 1em !important;
The same data is shown like this with “statistics”:
graph_span: 365day
span:
end: month
color_list:
header:
show: true
show_states: true
series:
- entity: sensor.goecharger_costs_monthly
type: column
float_precision: 2
show:
datalabels: true
statistics:
type: state
period: month
align: start
yaxis:
- min: 0
max: ~45
decimals: 0
apex_config:
tickAmount: 5
apex_config:
plotOptions:
bar:
columnWidth: 75%
xaxis:
tooltip:
enabled: false
card_mod:
style: |
Thank you, that was very helpful! I managed to get it to display a graph but I had to set it to 2days
minimum, if I set it to 1day
the graph turned up empty.
group_by:
func: diff
duration: 2day
fill: zero
So it feels like a workaround and I’m still hoping for a way to get it done properly “out of the box”
However, fixing this makes MOBILE app go all sentimental asking for extend_to_end
back with /// apexcharts-card version 1.10.0 /// error
That’s because your phone still runs an old cached version. Clear the cache of the app and it will be alright.
It’s on its way
I’ll release a beta later today and you’ll tell me if that works as I don’t have such a sensor to test with.
Will do!
Thank you stigvi for providing this example! I have been struggling with the exact same thing for weeks. Now I finally got it to work!
Hell together,
I made a chart for fuel price. This is how it looks:
My code:
header:
show: true
title: E10
show_states: true
series:
- entity: sensor.aral_drausnickstrasse_60_super_e10
name: Aral Drausnick
curve: stepline
- entity: sensor.aral_kleinsendelbacher_str_12_super_e10
name: Aral Neunkirchen
curve: stepline
- entity: sensor.elo_leitenackerstrasse_1_super_e10
name: Elo Uttenreuth
curve: stepline
show:
extremas: true
- entity: sensor.supol_artilleriestr_58_super_e10
curve: stepline
show:
extremas: true
apex_config:
decimalsInFloat: 3
I would like to have it with 3 digits like in the detail picture.
Can anybody help me?
Best regards,
Stefan
I’m not sure but do you need to put it in the y axis like this
apex_config:
yaxis:
show: true
decimalsInFloat: 3
I have added my fireboard temperature probe added to home assistant. I have installed Apex Charts and have one chart setup to read the temperature for when I BBQ or cook other food. I also have a new smoker coming that has this Fireboard built into it and will be added when that arrives.
For now I’m learning about Apex Charts and seeing what is possible. Does anyone know if I can have an input for Target temperature of a probe and have that added to the chart? Maybe have it show up as a red line and when that temperature is reached it can send my phone a notification.
This is what I have so far with an Ambient outside temperature from local weather METAR. Fireboard Probe 1 was my smoker pit temperature at the grate. And Fireboard Probe 2 was the brisket.
Here is the config for my apex chart. I added the red Now (not on the picture).
graph_span: 1.5h
now:
show: true
color: red
label: Now
header:
show: true
title: Fireboard History .!|!.
show_states: true
series:
- entity: sensor.kxx_temperature
name: Ambient (Outside)
- entity: sensor.fireboard.temp.channel.1
type: area
- entity: sensor.fireboard.temp.channel.2
type: line
So you can see just real basic chart from 3 sensors. It would be cool to be able to show a line for a set target temperature. And somehow calculate a cook time from where the current temperature is showing how long to get to that set target temperature. This may not be possible with Apexcharts but with other Home Assistant stuff. I just don’t know where to look. Hopefully someone has ideas for this.
Thanks!
Apologies if this has been discussed but I could not find an example in this long topic… Has anyone done something like a donut that compares device power usage vs total power usage like this?
THX, you are rigth. It works for y-Axis.
I tried it for header, but nothing
