Try looking for extend to: now
in the docs.
Hi, my sensor has to much data, so apexcarts loading really long.
Did Apexcarts has something like “Dots per Hour” like mini graph card or something?
I just have data on each second, if i load a full day, its to much
Guys need help here.
I am trying to plot apex graph with this code and got error:
Entity not available: nordpool_kwh_oslo_nok_3_10_025
This is the code:
type: custom:apexcharts-card
header:
show: true
title: Nordpool Prize -> 48 hours
show_states: false
graph_span: 2d
span:
start: day
series:
- entity: nordpool_kwh_oslo_nok_3_10_025
data_generator: |
return entity.attributes.raw_today.map((entry) => {
return [new Date(entry.start), entry.value];
type: column
show:
legend_value: false
in_header: false
extend_to: end
data_generator: |
return entity.attributes.raw_tomorrow.map((entry) => {
type: column
show:
legend_value: false
in_header: false
What am I doing wrong?
Entity IS available and I use it in some other chart.
Shouldn’t it be sensor.nordpool_kwh_oslo_nok_3_10_025 rather than just nordpool_kwh_oslo_nok_3_10_025?
Hi Mirek and thank you for help.
I figure it out last night and everything set in place. Have had both today and tomorrow prices. But since this morning, I got just today price for some reason…
When using long term statistics I can’t get Apex to show the current month, only previous months. So now in September the chart shows data until end of august, and I wouild like the numbers for September (so far to be shown in the graph. Has anyone been able to solve that?
graph_span: 32w
update_interval: 5min
series:
- entity: sensor.last_meter_consumption_vagen
type: column
color: 2eb9ff
statistics:
type: sum
period: month
align: middle
group_by:
func: diff
duration: 4w
fill: last
start_with_last: true
Some time ago I tried and failed to embed apexchart into custom button card in a way to fill button card without any margins.
That time I was asking in several places for help but got no answer. Few days ago I decided to do another go and finally, I managed to achieve it myself. Hope it will help others.
There are two crucial things to remember:
- the parent element which contains the chart, must have set
display
CSS property toblock
allowing ApexChart (not the card) to know the wrapping element size. In HA scope it’s display is often set to flex. - in order to remove completely various elements allocating space around the graph,
sparkline: enabled: true
has to be set in ApexChart config (not the card).
Hope it help others
Here is the result:
And the code:
- type: custom:button-card
template: customcard_31wrapper
custom_fields:
graph:
card:
style: |
ha-card .apexcharts-legend-text {
color: var(--tile-state-text-color, rgba(0, 0, 0, 0.4)) !important;
font-size: 14px !important
hours_12: false
graph_span: 72h
apex_config:
chart:
sparkline:
enabled: true
legend:
position: top
floating: false
grid:
show: false
yaxis:
- id: temp
min: ~0
max: ~35
show: false
- id: hum
show: false
min: ~0
max: ~90
series:
- entity: sensor.childroom_temperature
yaxis_id: temp
color: var(--accent-color)
stroke_width: 1
type: area
opacity: 0.2
- entity: climate.trv_childroom
transform: return entity.attributes.temperature
yaxis_id: temp
stroke_width: 1
type: line
opacity: 0.2
- entity: sensor.childroom_humidity
yaxis_id: hum
color: '#3498db'
stroke_width: 1
type: area
opacity: 0.1
and button card templates used in the snippet above:
customcard_style:
styles:
card:
- padding: 10px
- padding-top: 3px
- padding-bottom: 3px
- box-shadow: rgba(0, 0, 0, 0.3) 0px 1px 3px 0px
- border-radius: var(--ha-card-border-radius, 12px)
- user-select: none
name:
- justify-self: start
- padding-left: 0px
- font-weight: 500
- font-size: 14px
- align-self: middle
- padding-top: 20px
img_cell:
- justify-content: start
- align-items: start
- margin: none
icon:
- margin-top: 5px
- width: 30px
- height: 30px
customcard_31wrapper:
template: customcard_style
aspect_ratio: 3/1
variables:
entity_temp: ''
entity_hum: ''
styles:
card:
- padding: 0px
grid:
- grid-template-areas: '"graph"'
- grid-template-columns: 1fr
- grid-template-rows: 1fr
custom_fields:
graph:
- padding: 0px
- margin: 0px
- align-items: end
Is it possible to plot a point every time a sensor changes?
I track my mileage between charges on my ev. This value is set every time the EV is plugged in. This might be often or might be not so often. No set schedule.
Right now my graph is covered over a period of time and the value is tracked daily which isn’t what I want.
Question from a ApexCharts noob. I would like to color my thresholds using a state, like the example below. Is this supporded and if so, what would that syntax for that be?
color_threshold:
- value: 2
color: midnightblue
- value: { { states('sensor.mysensor) } }
color: steelblue
And/or is it possible to achieve this using an state_attr?
Wouldn’t be every 30m or 1h often enough?
I don’t think so, for example
01/01 = 80
07/01 = 75
10/01 = 25
20/01 = 100
The sensor value stays the same until it’s changed. I would want the 4 points above plotted but instead I get 7 points at 80 then 3 at 75 and then 10 at 25 and so on….
Does someone know how to have sensor value as well as the mean over 7 days of that sensor value in the same graph?
Here my config:
card_mod:
class: top-level-graph
graph_span: 28d
span:
end: day
header:
show: true
title: Reproduktionswert r0 [4w]
show_states: true
colorize_states: true
yaxis:
- align_to: 0.1
decimals: 2
apex_config:
yaxis:
forceNiceScale: true
markers:
colors: white
strokeColors: black
strokeWidth: 2
hover:
stroke:
width: 3
annotations:
position: back
yaxis:
- 'y': 0
y2: 1
fillColor: green
opacity: 0.5
- 'y': 1
y2: 50
fillColor: red
opacity: 0.5
legend:
show: false
tooltip:
x:
format: ddd dd MMM
series:
- entity: sensor.rki_covid_germany_r7
type: column
float_precision: 2
group_by:
func: last
duration: 1d
type: line
float_precision: 2
group_by:
func: avg
duration: 7d
style: |
ha-card {
font-size: 20px;
But with that, I see a value for tomorrow and it displays only one value every 7 days but not the 7 day mean for all days.
I eventually managed to solve it myself. Just add another sensor with the correct attribute/value and hide it from the chart.
header:
show_states: true
series:
- entity: sensor.nordpool_kwh_se3_sek_0_10_0
name: Timpris just nu
color: orange
type: column
show:
in_chart: false
I would love this as well. The energy dashboard uses it for the tracked device chart. I don’t think we can apply that style yet though.
Hey! I have a montly utility meter that resets each month. How could I get this to show montly usage in Apex Chart?
Thanks!
Hi, Nice graphs. How do you get the max and min values marks?
Take a look at “extremas” here:
I set my ac cooling state as represented with the blue lines to 70 for each time its cooling with this
transform: ‘return x === ‘‘cooling’’ ? 70 : 0;’.
how can I represent the blue lines to equal the current temperature of? so instead of the on off states set to 70 no matter what, I would like it to match the current temperature.
could someone guide me
update_delay: 3s
update_interval: 1min
apex_config:
chart:
height: 250px
yaxis:
- id: first
opposite: true
- id: second
now:
show: true
label: Now
color: red
graph_span: 1d
series:
- entity: climate.lyricstat3db4c9
attribute: current_temperature
stroke_width: 3
curve: stepline
color: rgb(125, 0, 250)
yaxis_id: first
type: area
opacity: 0.1
show:
extremas: true
- entity: climate.lyricstat3db518
stroke_width: 3
curve: stepline
color: rgb(69, 0, 196)
yaxis_id: second
type: area
opacity: 0.1
show:
extremas: true
attribute: hvac_action
transform: return entity.attributes.current_temperature
stroke_width: 1
color: rgb(157, 154, 252)
type: column
show:
legend_value: false
transform: 'return x === ''heating'' ? 70 : 0;'
stroke_width: 1
color: rgb(252, 154, 154)
type: column
show:
legend_value: false
yaxis:
- min: 60
max: 80
Thank you!
Much appreciated.
I copied the “Now” feature and it works but only copying “extremas: true” didn’t change anything. Maybe it will come later when the data is actually updated?
