Still the same issue
type: custom:apexcharts-card
chart_type: radialBar
series:
- entity: sensor.humidity
- entity: sensor.temperature
apex_config:
plotOptions:
radialBar:
offsetY: 0
startAngle: 0
endAngle: 270
hollow:
margin: 5,
background: 'transparent'
dataLabels:
name:
show: false
value:
show: false
legend:
show: true
floating: true
fontSize: '16px'
position: 'left'
offsetX: 0 # change this to move the legend left of right
offsetY: 15 # change this to move the legend up or down
labels:
useSeriesColors: true
markers:
itemMargin:
vertical: 3
Also this type of chart only works well with percentages, the idea is not to display a temperature or anything else.
Then i get this: value.chart_type is extraneous
You are not using the last version then.
Using 1.4.0
I can tell you you’re not Clear your browser cache.
It does work if you can get thru the version problem solved and make your your indenting is correct, YAML is not very forgiving. Good hunting!
Cleared browser cache, reinstalled card and choose 1.4.0, cleared again, did the same thing with 1.5.0 dev, didnt help either.
But dproffer kinda comfirmed it working so the problem is at my end. Ill keep checking. Thank you so much.
“The biggest /facepalm”
I installed this card manually yesterday, and trough hacs today. I forgot to remove the manual resource from lovelace settings So i actually had 2 version installed.
Keep up the good work.
post your yaml code, put it inbetween two lines with three back ticks on each line, this will format it properly. For example here is yaml that created above:
- type: custom:apexcharts-card
series:
- entity: sensor.freezer_govee_humidity
- entity: sensor.freezer_govee_temperature
apex_config:
plotOptions:
radialBar:
offsetY: 0
startAngle: 0
endAngle: 270
hollow:
margin: 15,
dataLabels:
name:
show: false
value:
show: false
legend:
show: true
floating: true
fontSize: '16px'
position: 'left'
offsetY: -20 # change this to move the legend up or down
labels:
markers:
itemMargin:
vertical: 3
Thanks alot.
Glad to hear you got it work. Lots of useful visualization possibilities with this card and Home Assistant!
Yeah, when i figure out how to import the codes from https://apexcharts.com/javascript-chart-demos/radialbar-charts/multiple-radialbars/ to HA card Some makes sense some dont, i guess im learning alot now.
How can I add the state of a switch entity as a bar thats either 1 or 0 ? I would like to overlay the status of a heater switch with the current temperature in the room. I can easily plot the temp, and was hoping that the switch state would plot the same just enumerating to 0 or 1… but is doesnt and just shows as ‘n/a’. Is there a specific approach I need to take ?
Non numerical sensors are not supported at the moment.
In the meantime, you could create a sensor template (1 = on, 0 = off) based on your switch state.
ok - thanks - I’ll need to work out how to do that…
Is the forceNiceScale implemented and I just don’t know how to use it properly or isn’t it an option?
The y-axis numbering/scale is a bit irregular
Everything which is available in ApexCharts is available in the card through the apex_config
object.
So for that to happen add this to your card config:
apex_config:
yaxis:
forceNiceScale: true
Also it’s not irregular, it’s just truncated, if you increase the y_axis_precision: 2
you’ll see more decimals
Thanks for the fast reply! That code didn’t give any effect but it was due to me having “tickAmount” in the code. Looks beautiful now!
