ApexCharts Card - Bar Chart Issue
Hi
I am having some issues with creating a bar chart with Apex Chart.
  1. Some of the data is being cut off. There are 5 bars and the last one is being cut off.
  2. The x-axis spacing is not consistent.
  3. The last x-axis label is not being displayed.
type: custom:apexcharts-card
view_layout:
  grid-area: m1
graph_span: 6month
stacked: false
span:
  end: month
apex_config:
  legend:
    position: top
    horizontalAlign: left
  grid:
    show: true
    strokeDashArray: 0
    xaxis:
      lines:
        show: true
    yaxis:
      lines:
        show: true
    row:
      colors: grey
      opacity: 0.5
    column:
      colors: grey
      opacity: 0.5
  plotOptions:
    bar:
      dataLabels:
        orientation: vertical
        position: top
        background:
          enabled: false
          borderWidth: 0
  dataLabels:
    enabled: true
    style:
      fontSize: 10px
      colors:
        - grey
        - grey
        - grey
        - grey
        - grey
      fontWeight: normal
    background:
      enabled: false
  tooltip:
    enabled: false
  xaxis:
    type: datetime
    labels:
      format: MMM yyyy
  title:
    text: Monthly Production
    align: center
    style:
      fontWeight: regular
      color: grey
      fontSize: 18px
series:
  - entity: sensor.sensor_inverter_calculated_pv_energy_monthly
    type: column
    color: rgb(255, 155, 48)
    group_by:
      func: last
      duration: 1month
      start_with_last: false
    show:
      datalabels: true
      legend_value: false
      as_duration: month
    fill_raw: last
  - entity: sensor.sensor_inverter_calculated_load_energy_monthly
    type: column
    color: rgb(95, 182, 173)
    group_by:
      func: last
      duration: 1month
    show:
      datalabels: true
      legend_value: false
  - entity: sensor.sensor_inverter_calculated_grid_energy_in_monthly
    type: column
    color: rgb(84, 144, 194)
    name: Grid Import 💡
    group_by:
      func: last
      duration: 1month
    show:
      datalabels: true
      legend_value: false
  - entity: sensor.sensor_inverter_calculated_battery_energy_out_monthly
    type: column
    color: rgb(151, 90, 182)
    name: Battery Discharge 🖱️
    group_by:
      func: last
      duration: 1month
    show:
      datalabels: true
      legend_value: false
  - entity: sensor.sensor_inverter_calculated_battery_energy_in_monthly
    type: column
    color: yellow
    name: Battery Charge 🔋
    group_by:
      func: last
      duration: 1month
    show:
      datalabels: true
      legend_value: false
Here is another example of the data being cut off.
view_layout:
  grid-area: daily1
graph_span: 6d
stacked: false
span:
  end: day
apex_config:
  legend:
    position: top
  grid:
    show: false
  plotOptions:
    bar:
      dataLabels:
        position: top
        background:
          enabled: false
          borderWidth: 0
  dataLabels:
    enabled: true
    style:
      fontSize: 10px
      colors:
        - grey
        - grey
        - grey
        - grey
        - grey
      fontWeight: normal
    background:
      enabled: false
  tooltip:
    enabled: false
  xaxis:
    labels:
      format: dd MMM
  title:
    text: Daily Production
    align: center
    style:
      fontWeight: regular
      color: grey
      fontSize: 18px
series:
  - entity: sensor.sensor_inverter_calculated_pv_energy_daily
    type: column
    group_by:
      func: last
      duration: 1d
    show:
      datalabels: true
      legend_value: false
    fill_raw: last
  - entity: sensor.sensor_inverter_calculated_load_energy_daily
    type: column
    group_by:
      func: last
      duration: 1d
    show:
      datalabels: true
      legend_value: false
  - entity: sensor.sensor_inverter_calculated_grid_energy_in_daily
    type: column
    name: Grid Import 💡
    group_by:
      func: last
      duration: 1d
    show:
      datalabels: true
      legend_value: false
  - entity: sensor.sensor_inverter_calculated_battery_energy_out_daily
    type: column
    group_by:
      func: last
      duration: 1d
    show:
      datalabels: true
      legend_value: false
  - entity: sensor.sensor_inverter_calculated_battery_energy_in_daily
    type: column
    color: yellow
    group_by:
      func: last
      duration: 1d
    show:
      datalabels: true
      legend_value: false
Some solutions on it? Thanks!
