Apexcharts tooltip info: Inconsistent behavior for shared tooltip
Hi there,
I found the apexcharts-card as a solution for a lovelace-integrated diagram with a proper way of displaying numbers clearly by scrubbing through the data.
This is what my card should look like:
Most of the time, it only shows one datarow in the tooltip, which makes it impossible to read all the dataseries in the diagram:
I can’t fully tell what circumstances cause the different behaviors. When I only get one series at the tooltip, I can switch to the lovelace configuration mode, in there it works. When i switch back, I only have one tooltip again.
I thought, the reason must be the varying timestamps, but I use the group_by method to decrease the amount of data. It also doesn’t make sense that it does work sometimes.
Any idea on this?
Thanks a lot
Alex
Here is the code for the card:
type: custom:apexcharts-card
  graph_span: 12hrs
  apex_config:
    tooltip:
      shared: true
    stroke:
      curve: smooth
    chart:
      height: 400
    xaxis:
      axisTicks:
        show: false
      axisBorder:
        show: false
      ticks:
        show: false
      axis:
        show: false
    legend:
      position: top
    grid:
      show: false
  experimental:
    color_threshold: true
  yaxis:
    - id: first
      decimals: 1
      apex_config: null
    - id: second
      opposite: true
      decimals: 0
      apex_config:
        tickAmount: 2
      min: 0
      max: 100
  all_series_config:
    stroke_width: 1.5
    group_by:
      func: avg
      duration: 10min
  series:
    - entity: sensor.battery_level
      yaxis_id: second
      type: line
      color_threshold:
        - value: 0
          color: firebrick
          opacity: 1
        - value: 50
          color: yellow
        - value: 100
          color: seagreen
      stroke_width: 2
    - entity: sensor.total_dc_power
      yaxis_id: first
      color: coral
      type: area
      opacity: 0.3
      transform: return x/1000;
      unit: kW
    - entity: sensor.export_power
      yaxis_id: first
      transform: return x*(-1)/1000;
      type: area
      opacity: 0.3
      unit: kW
      color: purple
    - entity: sensor.battery_charging_power
      yaxis_id: first
      type: area
      opacity: 0.3
      unit: kW
      color: seagreen
    - entity: sensor.battery_discharging_power
      yaxis_id: first
      type: area
      unit: kW
      opacity: 0.3
      color: seagreen
    - entity: sensor.import_power
      yaxis_id: first
      type: area
      opacity: 0.3
      unit: kW
      color: skyblue
    - entity: sensor.load_power
      yaxis_id: first
      type: area
      opacity: 0.3
      unit: kW
      color: firebrick
I encountered the same issue and managed to resolve it by implementing a fixed graph span, e.g.:
graph_span: 24
Additionally, I grouped the data by small time intervals.
I believe the problem stems from the fluctuating “time buckets” in a dynamically adjusting graph span upon each refresh.
Hey everyone,
After searching through hundreds of forum entries without finding a solution that worked for me, I finally came up with this approach to format series data in ApexCharts.
The solutions
              tooltip:
                shared: true
                intersect: false
dit not work for me!
If you’re looking to display values from multiple series with each value on a new line and rounded to two decimal places, here’s the formatter that worked for me - it is a realy simple one - there are more sophisticated out there
:blush:
            apex_config:
              tooltip:
                shared: true
                intersect: false
                x:
                  format: HH:00 - HH:59
                  show: true
                y:
                  formatter: |
                    EVAL: function(val1, { series, seriesIndex, dataPointIndex }) {
                      return `${series[0][dataPointIndex].toFixed(2)} ct/kWh<br>` +
                             `${series[1][dataPointIndex].toFixed(2)} kWh<br>` +
                             `${series[2][dataPointIndex].toFixed(2)} EUR<br>`;
                  title:
                    formatter: |
                      EVAL: function(seriesName) {
                        return ""
Hopefully, this helps someone else who’s been struggling to find a solution like I was!
Cheers!
For if you are still having the same issue:
I also struggled with showing all series for the tooltip for quite some time. What finally solved it is grouping on the x-axis. The series most likely have an irregular time interval or missing some values, thus do not share the same x axis points. (See the note below the example: tooltip – ApexCharts.js) This can be fixed with the group_by function. Here is my example (only the necessary config):
apex_config:
  xaxis:
    tooltip:
      enabled: false # Disable the x-axis tooltip
  tooltip:
    shared: true # One tooltip for all series
    intersect: false # Also show tooltip when not hovering exactly on a point
    x:
      format: HH:mm - HH:mm # Cleaner time formatting
      show: true
all_series_config:
  group_by: # Fix irregular time for the shared tooltip to work
    duration: 5min
    func: avg
    fill: last
Make sure to set the duration accordingly. Good luck!
PS: I also disabled the x-axis tooltip, since the time is already in the tooltip.
Just as a note this does not work in firefox
Also found other thread on this Apex Chart - Tooltip help - #4 by vincentiano
:frowning:
And also in HA mobile app - it does seem to work for a moment when you load the page fresh after edit but when you touch lines or legends it calapses and shows only one
